Help with dead Commodore 1802
  • roadrash
    • Oct 2015
    • 490
    • U.K.
    #101
    Re: Help with dead Commodore 1802
    Originally posted by stj
    i'll go over the schematic again on saturday
    When i turn it on a can hear a faint bong sound which might be the audio amp. I checked and there is 240v at the filter cap..
      • 30985
      you should have 340v DC at the cap more or less.
      the sound is probably the degausing coil around the edge of the crt.
      • roadrash
        • Oct 2015
        • 490
        • U.K.
        #103
        Well I actually get 245v volts measuring between the filter cap we replaced and L802, but I measure between the filter cap and chassis ground I get 11v.
        Its encouraging that it makes that bong when its powered up as it just used to blow that resistor before but I still have the light bulb in place of the large resistor at present or should I remove that as well now so its back to what was original.
          • 30985
          worth a try, it;s obviously not drawing enough current to damage a resistor
          • roadrash
            • Oct 2015
            • 490
            • U.K.
            #105
            Well it blew the resistor again but not the fuse and once I solder the light bulb back in place of the resistor its still powering up in that I get that bong sound, but the tube heaters not glowing or anything. This is frustraiting. It the bong sound means its powering up then why doesnt anything ele. where do I measure the PSU output from, I want to see if when its going bong is it actually powering up and giving any power out and if so how much.
            • R_J
              • 9535
              The "BONG" sound is just the deqausing coil. Unplug it. It has nothing to do with the power supply. look at the schematic, The deqausing coil is in series with the ptc PR801 and it is connected across the a/c line.
              • roadrash
                • Oct 2015
                • 490
                • U.K.
                #107
                Thanks for that info RJ.
                I decided that the only way I will find this hopefully is to check every single component one by one and any that dont give me the result I expect I remove from circuit to test again. So far ive tested quite a few caps, resistors and a few transistorsand so far all are testing ok except a resistor that is showing as a short. Its red,red,red & gold which is 2.2k I think. Should that be detected as a short?
                • R_J
                  • 9535
                  Maybe, it depends on what is across it in the circuit. I could guess where it is. The only 2.2k in the power supply circuit is R806 (they mark the locations) If it checks shorted Q806, C824 could be shorted.
                  How are you checking it? What resistance does it check?
                  • roadrash
                    • Oct 2015
                    • 490
                    • U.K.
                    #109
                    Your spot on its r806 and i removed it to check i was seeing those colours as reds and not an orange or something. Once i removed it and hooked up to my component tester it shows as 2.2k or within tolerence. Since then ive contined and checked every component within the psu area and nothing else is reading as abnormal. That surely leaves only things like inductors and transformers doesnt it?
                    • R_J
                      • 9535
                      So did you figure out why R806 was checking shorted in circuit?
                        • 30985
                        you cant really test the psu chip with a meter.
                        • roadrash
                          • Oct 2015
                          • 490
                          • U.K.
                          #112
                          Not entiely sure but might be because I had my meter on diode setting so it beeps, but when isolated, it gives a reading of 71.59k so its within tolereance isn't it. Its a a big grey cap and marked as 3w 68k. Another resistor I was suspicious about as it was showing as a short or beeping on my meter and I lifted one end to isolate was R808. But again when isolated measures ok at 2243 ohms so this I beleive is also ok. Could some of these readings be beacause these all go through the big transformer T801.
                          Since then I removed the L805 again and reconnected the bulbs like we had before and powered it up again and looked back through this thread and took some voltage reading again now I have a better idea wheer everything is and here is what I got:
                          At filter cap C803 =165V AC
                          On T801 at pin 2 and pin 4 there is = 165 V DC on both
                          At the pins 4 & 5 of the LOPT = 10V DC
                          I hope these make sense.
                          I get confused whether we are dealing with AC or DC voltages because although with AC there is no positive (+ ) & negative (- ) and I can use either of the 2 240v inputs from the mains. With DC voltage there is polarity and I dont know where I should be putting the black probe to. I usually connect the black probe to a heatsik or the outer connection on a RCA jack as the negative and these are usualy Negative. Am I doing this right? I am not sure at which point in the circuit (diodes) the voltage is recified and we get a Positive and negative voltage. Once I can get my head round this I shouldnt be as confused checking voltages whether AC or DC. Where is the best place to use as a reference negative side when taking a DC voltage.
                            • 30985
                            after the mains input diodes - it's all DC
                            • R_J
                              • 9535
                              I don't know how many times I have said it but you can NOT use the BEEP function for testing components. Most meters will beep between 0Ω and 150Ω
                              As for the a/c or DC. You can check for A/C only to the two input (~) of the bridge rectifier, after that it is DC with reference to HOT ground (- of input capacitor C803) for any measurements in the primary side of T801, All DC measurements on the secondary side use the chassis for ground.
                              If you are measuring 165v AC on C803 you are using the wrong ground!
                                • 30985
                                the input is isolated, for testing the psu the ground must be on the same component.
                                • roadrash
                                  • Oct 2015
                                  • 490
                                  • U.K.
                                  #116
                                  Thank you both for that help and its spot on as usual. RJ I know exactly what you mean about the meter beep. It's not a accurate way of checking for continuity as how many times has my meter beeped a short when its just a low resistance. You got that right too STJ I forgot we isolated the PSU so using any part our of that area to take a measurement is not going to be valid. Why did I not think of that. I am learning loads here and a lot more confident working on things like monitors now than I was when I would be reluctant to delve around in one if it was playing up. And it would get dumped eventually. I am going away for a week so wont get anything done now until I get back but I am more and more confident that with your help we will get this thing sorted now like we did before.
                                  At least you will get a break from me for a week lol.
                                  Speak again when I get back. Cheers!
                                  • roadrash
                                    • Oct 2015
                                    • 490
                                    • U.K.
                                    #117
                                    I have just realised there is a fault with my multimeter as its only showing 160v and not 240v. This would mess the things up a bit. Ive had a lot of problems with meters going wrong like incorrect reading of resistance and now on this meter its voltages that are wrongly measured. Can you reccomend me a good reliable digital meter on Ebay thats not going to coast a arm and leg.
                                    For examle I have a really nice USpro EM129 automotive meter here that for some reason gives incorrect resistance readings but there isnt any information about how I can calibrate it, if thats possible. The meter I have been using to test this monitor is a XL830L I bought from Ebay only about 6 months ago and is my 2nd one to go wrong now.
                                    • roadrash
                                      • Oct 2015
                                      • 490
                                      • U.K.
                                      #118
                                      Ok I will have to use my other automotive meter for voltage checking. I am a little confused here. I know you said that everything after the mains input diodes is DC. The mains input diodes are these the diodes marked 4700 500V x4 on the schematic? It might be easier for me for the time being until I learn a bit more if you could give me the positions as to where to take the reading from. Sorry its a pain I am still getting to grips with the stage where AC is coverted to DC and the place where DC & polarity +- takes effect.
                                      • R_J
                                        • 9535
                                        This is the a/c path and where the 4 diodes (in a bridge configuration) convert to DC. After that it gets more complicated as the STR54041 IC takes that DC and switches it, at HIGH FREQUENCY (around 20KHz) into A/C to drive the transformer.
                                        • roadrash
                                          • Oct 2015
                                          • 490
                                          • U.K.
                                          #120
                                          Hey RJ thats really helpful of you. Sorry been a delay in getting back to you as ive been unwell all week with my MS. Anyway what yiou did there makes it a lot more plain where the AC and DC changen and where I take the measurements from. Going by your Shematic I now find I am getting no readings where I had some before.
                                          At filter cap C803 there is no AC voltage. (before I was using one off the AC inputs as a pole but now if I measure across the capacitors 2 contacts -+ there is no voltage reading and I checked fuse again and its ok. Should be a voltage across the 2 poles of C803?
                                          I will have to look in to this further because there is something amiss here. Now I use your schematic RJ, I am getting no readings where I was getting something before.
                                          I will sleep on it and start again tomorrow with a fresh start when I am not so fatigued.
                                          thanks again..
                                          • double_DD
                                            How can I be sure that my EC chip is dead?
                                            by double_DD
                                            As the title suggests, how can I be sure that my EC chip is really dead?
                                            I've recently gotten into this hobby of laptop repairs, and have successfully brought back to life a couple with some easy fixes, mostly shorted caps.
                                            Now I'm working on HP Probook 455 G8, that had some "devil" run around on 3V line, burning a bunch of stuff. Luckily I have a dead 455G7 (for spare parts) so I managed to fix it (swapped burned parts) to a point that it will charge (both on barrel jack and usb-c), but it doesn't want to turn on. There is a 3V3 on a keyboard...
                                            03-12-2025, 07:47 AM
                                          • disorder
                                            ps5 edm-033 dead after hdmi/usb ports destroyed
                                            by disorder
                                            hello guys,
                                            i need help to repair a edm-033 ps2
                                            history : as always hdmi port and usb ports destroyed after unplugged
                                            after change them, ps5 dead too : 1 beep, no blue light. after inspection 1.8v power was shorted, and because of dead panasonic chip. after remove it : no short anymore
                                            so i changed it
                                            now i have got 5v stby,, 3.3v stby, 3.3v power, 1.8v power and no short on them
                                            but the ps5 is dead again : 1 beep, near 10 seconds with power lines and then off, no blue light ...
                                            i don't see any projection of liquid metal on pcb.
                                            01-14-2025, 12:48 PM
                                          • Beton
                                            Finding a dead short component
                                            by Beton
                                            Hi guys!
                                            I searched for the term "dead short" in the forum but no specific thread came up however if I'm just blind and couldn't see the thread talking about this please forward me to that direction.
                                            So my problem is I don't know how to find the source of a dead shorted voltage rail. Dead short = ~0 ohm resistance.
                                            I have two VGAs (HD 4850 and HD 4870), both dead shorted to ground on the memory rail. I have the boardview file for the 4870 and the memory rail consists around ~7892346 capacitors...
                                            I have a bench PSU and if I try to inject voltage the voltage...
                                            12-10-2021, 01:05 PM
                                          • zunasthegreat
                                            Chieftec GPS-450-AA with dead 20N60C3
                                            by zunasthegreat
                                            Hello everyone hope all doing well!
                                            I have this PSU (GPS450-AA delta oem) around for like 4-5 years and I had it recapped early 2020 or 2021 with mostly UCC KY and Nichicon PW's. The bulk was and still is fine, the original Ltec's were bloated and empty. The previous issue was some major coil whine noise and at times random shutdowns when going idle. Today it started tripping the mains breaker and I think I have dead APFC mosfets (20N60C3). Right now upon checking I have the Q1 and Q3 FETs dead so far and I guess those are responsible for the PFC circuit. The only thing I care is If there...
                                            09-01-2024, 07:12 PM
                                          • FiguringITout
                                            MSI Raider GE75 - Not posting, probable dead CPU
                                            by FiguringITout
                                            Hello, today I'm working on this lovely MSI Raider GE75 gaming laptop which I bought to flip. Unfortunately, I believe the CPU is toast but I wanted a second opinion before I chucked it into my spare parts bin. I will not have most tools with me today as I'm away from my workbench but I have the basics (a good multimeter, a horrible iron, a solid screwdriver, and my trusty thermal cam). I do not have the original 230w charger, but I have a Dell 180w which was sold with the device and reportedly "worked fine for them".
                                            Specs: I7-10750H, RTX 2060, 32GB RAM (unknown manufacturer)...
                                            07-25-2024, 07:27 AM
