Guest - Try our new boardview, Bios, & schematic search. Over 1.1 million files for download!
How can I be sure that my EC chip is dead?
  • double_DD
    • Mar 2024
    • 63
    • Croatia
    As the title suggests, how can I be sure that my EC chip is really dead?
    I've recently gotten into this hobby of laptop repairs, and have successfully brought back to life a couple with some easy fixes, mostly shorted caps.
    Now I'm working on HP Probook 455 G8, that had some "devil" run around on 3V line, burning a bunch of stuff. Luckily I have a dead 455G7 (for spare parts) so I managed to fix it (swapped burned parts) to a point that it will charge (both on barrel jack and usb-c), but it doesn't want to turn on. There is a 3V3 on a keyboard connector that does go to 0V when PWRBTN is pressed and this does go to EC chip, I've followed the path. There is also 3V_alwaysON present on EC chip. There is no shorts on any of the caps around EC.
    EC in question is Nuvoton NPCX797HA1BX.
    The way my current level of understanding is, if EC chip has 3V Vcc, and PWRBTN reaches to EC chip, then the EC chip must be dead. Or?
    Is there something else that might be dead, thus preventing the laptop to turn on?
    When any charger is connected, the LED on the PWRBTN very shortly turns ON, and then goes back to OFF. Nothing happens when the button is pressed, also there is no current change on the charger.
    455G7 does appear to have the same EC chip, my last idea is to try and swap them (I know they usually need to be programmed and I don't have the programmer, but I've seen that on some HP's programming happens on board).
    Any suggestions will be highly appreciated.
    Thanks in advance!
  • rumpumpel1
    • Jul 2019
    • 199
    • germany
    yes, several hundred other parts, which may be defective.
    What is the current consumption (without battery)? Is it constant? Is there any initial peek?
    • double_DD
      • Mar 2024
      • 63
      • Croatia
      Thanks for the reply.
      I've opened another thread, please see here.
      Thanks.
      • acedogblast
        by acedogblast
        11-02-2024, 05:13 PM
      • DynaxSC
        ASRock B650M PRO RS - BIOS CHIP 25Q256JW BLOCKED BY STATUS REGISTERS
        by DynaxSC
        Hi
        I have then desoldered the chip, backupped the contents, and tried to earease the chip in order to program stock image, but the chip is locked by status registers SREG2 (TB) and SREG6...
        08-04-2025, 12:20 PM
        Common SPI bios chip programming Questions and Answers
        by SMDFlea
        Q: I have a bios request,i can`t post my backup as i can`t read from the chip.
        A: If you can`t read from it how do you expect to write to it ?.
        Q: Why is my bios chip unreadable ?.
        A: The programmer is faulty or has a worn or broken zif socket.
        The USB cable is frayed,connector pins worn or some other physical damage.
        Not enough amperage or voltage to power the programmer properly.
        Bad...
        09-02-2021, 04:40 PM
      • zunasthegreat
        Dead corsair VS450 with blown TNY chip (cwt)
        by zunasthegreat
        I have this Corsair VS450 PSU which lies dead and has an exploded TNY chip. Upon removing primary side parts like mosfets, the bulk cap and the bridge rectifier I've found that the primary cap is also a goner. (Photos)
        The mosfets and the diode are fine and survived the collapse it seems. The TNY chip is shattered and from the online review/sources it was probably a TNY176~177....
        08-30-2025, 03:11 AM
      • chonkyrabbit
        Need help disassembling xx30 thinkpad battery BMS chip firmware
        by chonkyrabbit
        Hi there,
        I need some help reverse engineering a BMS chip from a battery for an xx30 thinkpad. The Laptop uses a challenge-response type of system to verify if a battery is genuine:
        The laptop writes four bytes to 0x3C and then reads 0x3C. The battery responds with "Lenovo JapanXXXX", with the Xs corresponding to four response bytes. For example "0xDC 0x42 0x5B 0x82" to BMS => "Lenovo Japan0x9F 0x76 0x97 0x2E" from BMS.
        What I know so far:
        • It's an 51F51 BMS chip based on the R2J24020F group. Karosium has already figured out how to dump
        01-21-2026, 10:32 AM
