Help with dead Commodore 1802
    • 31199
    Re: Help with dead Commodore 1802
    so a refresh of the facts,
    with the coil out and just the psu & audio sections running your still burning resistors??
    • roadrash
      • Oct 2015
      • 490
      • U.K.
      #62
      Yes thats right. Ive done as was said and checked all componnets in the PSU area for shorts incuding ceramics caps ansd cant find anything shorted. I wonder is there a way we can also isolate the audio section so we can just make sure its in the audio section.
        • 31199
        you can lift L808 to isolate the audio stage.
        im starting to wonder if the transformer could be breaking down, but few people have the equipment to check one,
        (although i do)
        • roadrash
          • Oct 2015
          • 490
          • U.K.
          #64
          Please anyone how to I isolate everything except the PSU to trace this fault..
            • 31199
            desolder coil L808
            then you only have the psu running.
            the str device could be bad btw, you cant test those with a meter properly.
            • roadrash
              • Oct 2015
              • 490
              • U.K.
              #66
              desolder coil L808
              I know this thread is a bit old now but I have to make a choice now what to do with this monitor, I did what you said STJ and the problem keeps being there is a short somewhere in the PSU which is still blowing the Wire wound resistor. I checked every component in the PSU which currenty has L808 removed and a light bulb soldered across C812 as you suggested.
              If I cant resolve this I will have no choice but to dump it which I absolutely hate doing to such rare items. Is there one last thing I can try before I have to give up?
                • 31199
                yes,
                but it's a pain in the ass.
                replace the 10w resistor with a 15-25w lamp to save resistors,
                then remove the transformer T801 and see what happens.
                if the lamp goes full-on then we start to lift things 1 by one to find the cause.
                my suspicion is a diode is failing at full voltage but looking o.k. on a meter that only tests with about 3v
                i have seen this a number of times and it's a pain to track down.
                • roadrash
                  • Oct 2015
                  • 490
                  • U.K.
                  #68
                  yes,
                  Thanks a lot STJ for that reply. That 15-25w lamp do you mean AC 240v bulb? like we use here.
                    • 31199
                    yes, it will act like a resistor but instead of blowing it will just get brighter.
                    • roadrash
                      • Oct 2015
                      • 490
                      • U.K.
                      #70
                      Really good idea that STJ. I managed to get a nice little 240v 20w halogen bulb and removed the resistor soldering the bulb it its place.
                      Before I power up the monitor I want to check this will do the job.
                        • 31199
                        is that really a 240v lamp? i thought the ones with straight pins where 12v?
                        • roadrash
                          • Oct 2015
                          • 490
                          • U.K.
                          #72
                          Yes its got U shape pins (see attached) and I had to solder them to a couple bits of wire I soldered into the holes the resisitor goes. I hope this will do.
                            • 31199
                            it will work for the task, although a not-halogen bulb has slower inrush.
                            • roadrash
                              • Oct 2015
                              • 490
                              • U.K.
                              #74
                              So would have been better with a standard incandescent bulb like in a bedside lamp cos i thought about them but they are quite big still.
                              • roadrash
                                • Oct 2015
                                • 490
                                • U.K.
                                #75
                                Just powered it on and the light bulb flashed for anout 8-10 secs and then it stopped and now monitor doesnt turn on any more.
                                  • 31199
                                  that's good, the faulty part may have burned out.
                                  check the fuse though
                                  • roadrash
                                    • Oct 2015
                                    • 490
                                    • U.K.
                                    #77
                                    I checked and fuses are ok and so far I have checked all the diodes they test with the multimeter as ok. So must be something else like maybe the STR54041 regulator i already replaced earlier or another transistor thats now failed. What do your best guest to go for 1st?
                                      • 31199
                                      no idea, i would probably be using a meter on the board.
                                      but testing all transistors is simple - there arent many.
                                      • roadrash
                                        • Oct 2015
                                        • 490
                                        • U.K.
                                        #79
                                        I had a few of these nice little oven lights turn up today and ive solderd one in to replace the halogen one so it might be better. I will start removing all semiconductors now one by one (except the caps & diodes that ive checked), until I find whats failed. At least there are not too many.
                                          • 31199
                                          just a thought, check the mains smoothing cap - the big electrolytic.
                                          • double_DD
                                            How can I be sure that my EC chip is dead?
                                            by double_DD
                                            As the title suggests, how can I be sure that my EC chip is really dead?
                                            I've recently gotten into this hobby of laptop repairs, and have successfully brought back to life a couple with some easy fixes, mostly shorted caps.
                                            Now I'm working on HP Probook 455 G8, that had some "devil" run around on 3V line, burning a bunch of stuff. Luckily I have a dead 455G7 (for spare parts) so I managed to fix it (swapped burned parts) to a point that it will charge (both on barrel jack and usb-c), but it doesn't want to turn on. There is a 3V3 on a keyboard...
                                            03-12-2025, 07:47 AM
                                          • disorder
                                            ps5 edm-033 dead after hdmi/usb ports destroyed
                                            by disorder
                                            hello guys,
                                            i need help to repair a edm-033 ps2
                                            history : as always hdmi port and usb ports destroyed after unplugged
                                            after change them, ps5 dead too : 1 beep, no blue light. after inspection 1.8v power was shorted, and because of dead panasonic chip. after remove it : no short anymore
                                            so i changed it
                                            now i have got 5v stby,, 3.3v stby, 3.3v power, 1.8v power and no short on them
                                            but the ps5 is dead again : 1 beep, near 10 seconds with power lines and then off, no blue light ...
                                            i don't see any projection of liquid metal on pcb.
                                            01-14-2025, 12:48 PM
                                          • zunasthegreat
                                            Chieftec GPS-450-AA with dead 20N60C3
                                            by zunasthegreat
                                            Hello everyone hope all doing well!
                                            I have this PSU (GPS450-AA delta oem) around for like 4-5 years and I had it recapped early 2020 or 2021 with mostly UCC KY and Nichicon PW's. The bulk was and still is fine, the original Ltec's were bloated and empty. The previous issue was some major coil whine noise and at times random shutdowns when going idle. Today it started tripping the mains breaker and I think I have dead APFC mosfets (20N60C3). Right now upon checking I have the Q1 and Q3 FETs dead so far and I guess those are responsible for the PFC circuit. The only thing I care is If there...
                                            09-01-2024, 07:12 PM
                                          • Beton
                                            Finding a dead short component
                                            by Beton
                                            Hi guys!
                                            I searched for the term "dead short" in the forum but no specific thread came up however if I'm just blind and couldn't see the thread talking about this please forward me to that direction.
                                            So my problem is I don't know how to find the source of a dead shorted voltage rail. Dead short = ~0 ohm resistance.
                                            I have two VGAs (HD 4850 and HD 4870), both dead shorted to ground on the memory rail. I have the boardview file for the 4870 and the memory rail consists around ~7892346 capacitors...
                                            I have a bench PSU and if I try to inject voltage the voltage...
                                            12-10-2021, 01:05 PM
                                          • FiguringITout
                                            MSI Raider GE75 - Not posting, probable dead CPU
                                            by FiguringITout
                                            Hello, today I'm working on this lovely MSI Raider GE75 gaming laptop which I bought to flip. Unfortunately, I believe the CPU is toast but I wanted a second opinion before I chucked it into my spare parts bin. I will not have most tools with me today as I'm away from my workbench but I have the basics (a good multimeter, a horrible iron, a solid screwdriver, and my trusty thermal cam). I do not have the original 230w charger, but I have a Dell 180w which was sold with the device and reportedly "worked fine for them".
                                            Specs: I7-10750H, RTX 2060, 32GB RAM (unknown manufacturer)...
                                            07-25-2024, 07:27 AM
