Help with dead Commodore 1802
  • R_J
    • Jun 2012
    • 9588
    Re: Help with dead Commodore 1802
    If the lamp is in place of this inductor then it will still pass the voltage to that part of the circuit, It might be slightly low, likely around 100vdc. You can remove the lamp from the 121 volt line and reconnect the coil, I suspect you will then get a full width screen also.
      • 31199
      btw, can you take a picture of the power switch?
      i want to see if it's like the one on the phillips CM8833-II (commodore 1084-s)
      • roadrash
        • Oct 2015
        • 490
        • U.K.
        #183
        These switches are a nuisance and I can't find replacements anywhere and end up bridging the contacts and turning it on/off at the mains wall plug.
        • roadrash
          • Oct 2015
          • 490
          • U.K.
          #184
          Ok I found I had put it back in when you asked me to earlier put everything back. I am begining to think it might be safe now to put the resistor R801 back in now.
          I currently have 2 bulbs in place of this resistor.
          I am still a bit unsure as we still never found what was causing that short.
          What do you think?
            • 31199
            does that switch normally solder to the board, or have wires on it?
            if it's wires then a replacement wouldnt be hard.
            on the 8833-II i removed the pushbutton from the case and fitted a rocker switch instead.
            i'll get photo's over the weekend if you want.
            not exactly original, but on the 8833-II the switch is at the back out of sight.
            • roadrash
              • Oct 2015
              • 490
              • U.K.
              #186
              Yes it has wired connections and the switch assembly is screwed onto the plastic casing.
                • 31199
                https://www.rapidonline.com/power-pcb
                • roadrash
                  • Oct 2015
                  • 490
                  • U.K.
                  #188
                  Thanks for that STJ that's a great help. Ive got quite a few Commodore and Phillips CM monitors for all the Amiga kit I have here. I sold My Original Amiga A1000 and Amiga branded matching 1081 monitor last year. I still have a few A500's, a A1200 and my big A2000 with hard drive and IBM XT bridgeboard inside. I've got tons of software too. If your looking for anything Commodore just ask.
                  • roadrash
                    • Oct 2015
                    • 490
                    • U.K.
                    #189
                    I want to thanks both of you guys STJ & RJ for helping me finally get this commodore monitor fixed. I put the Wire wound resistor back it and it doesnt blow now and the display fills the screen and i can hear audio too. I will give it a test with a video signal when I more time but I am glad its finally fixed and I doubt I could have done that without the
                    help from you two.
                    I have learned loads and just hope I don't forget it all as I have big Issues with memory problems caused by my Multiple Sclerosis which is most difficult as I find it hard to learn new things and make them stay in my memory although I can remember all my past history.
                    I've got it all stored on my hard drive so if i ever need to use it again I can. RJ that Schematic that you did for me showing where it changed from to DC was brilliant and made it all a lot easier for me to understand.
                    Thanks again guys your brilliant and cant thank you enough.
                    cheers!
                    Jon
                    • R_J
                      • Jun 2012
                      • 9588
                      If the small spst part of the switch is not used, this might work: https://www.conrad.com/p/pwl-2p1tl-6...h-1-pcs-701606
                      There is also the ALPS SDGA3P
                        • 31199
                        there is no standby trigger on the CBM monitors, just DPST mains switching.
                        • roadrash
                          • Oct 2015
                          • 490
                          • U.K.
                          #192
                          you should check the B+ voltage and compare it to the manual - it can be ajusted.
                          it's DC btw.
                          Just wondering what is this B+ adjustment and I cannot see anything in the manual about it. The manual only mention static & dynamic convergence.
                          • roadrash
                            • Oct 2015
                            • 490
                            • U.K.
                            #193
                            found one on ebay. i will just have to swap over LED.
                            https://www.ebay.co.uk/itm/RVFM-PT-M...MAAOSwgARa58oX
                            • R_J
                              • Jun 2012
                              • 9588
                              There is no B+ adjustment, just check if it is close to the 121vdc as indicated on the schematic, if it's off a couple volts either way, thats not an issue.
                              • double_DD
                                How can I be sure that my EC chip is dead?
                                by double_DD
                                As the title suggests, how can I be sure that my EC chip is really dead?
                                I've recently gotten into this hobby of laptop repairs, and have successfully brought back to life a couple with some easy fixes, mostly shorted caps.
                                Now I'm working on HP Probook 455 G8, that had some "devil" run around on 3V line, burning a bunch of stuff. Luckily I have a dead 455G7 (for spare parts) so I managed to fix it (swapped burned parts) to a point that it will charge (both on barrel jack and usb-c), but it doesn't want to turn on. There is a 3V3 on a keyboard...
                                03-12-2025, 07:47 AM
                              • disorder
                                ps5 edm-033 dead after hdmi/usb ports destroyed
                                by disorder
                                hello guys,
                                i need help to repair a edm-033 ps2
                                history : as always hdmi port and usb ports destroyed after unplugged
                                after change them, ps5 dead too : 1 beep, no blue light. after inspection 1.8v power was shorted, and because of dead panasonic chip. after remove it : no short anymore
                                so i changed it
                                now i have got 5v stby,, 3.3v stby, 3.3v power, 1.8v power and no short on them
                                but the ps5 is dead again : 1 beep, near 10 seconds with power lines and then off, no blue light ...
                                i don't see any projection of liquid metal on pcb.
                                01-14-2025, 12:48 PM
                              • zunasthegreat
                                Chieftec GPS-450-AA with dead 20N60C3
                                by zunasthegreat
                                Hello everyone hope all doing well!
                                I have this PSU (GPS450-AA delta oem) around for like 4-5 years and I had it recapped early 2020 or 2021 with mostly UCC KY and Nichicon PW's. The bulk was and still is fine, the original Ltec's were bloated and empty. The previous issue was some major coil whine noise and at times random shutdowns when going idle. Today it started tripping the mains breaker and I think I have dead APFC mosfets (20N60C3). Right now upon checking I have the Q1 and Q3 FETs dead so far and I guess those are responsible for the PFC circuit. The only thing I care is If there...
                                09-01-2024, 07:12 PM
                              • Beton
                                Finding a dead short component
                                by Beton
                                Hi guys!
                                I searched for the term "dead short" in the forum but no specific thread came up however if I'm just blind and couldn't see the thread talking about this please forward me to that direction.
                                So my problem is I don't know how to find the source of a dead shorted voltage rail. Dead short = ~0 ohm resistance.
                                I have two VGAs (HD 4850 and HD 4870), both dead shorted to ground on the memory rail. I have the boardview file for the 4870 and the memory rail consists around ~7892346 capacitors...
                                I have a bench PSU and if I try to inject voltage the voltage...
                                12-10-2021, 01:05 PM
                              • FiguringITout
                                MSI Raider GE75 - Not posting, probable dead CPU
                                by FiguringITout
                                Hello, today I'm working on this lovely MSI Raider GE75 gaming laptop which I bought to flip. Unfortunately, I believe the CPU is toast but I wanted a second opinion before I chucked it into my spare parts bin. I will not have most tools with me today as I'm away from my workbench but I have the basics (a good multimeter, a horrible iron, a solid screwdriver, and my trusty thermal cam). I do not have the original 230w charger, but I have a Dell 180w which was sold with the device and reportedly "worked fine for them".
                                Specs: I7-10750H, RTX 2060, 32GB RAM (unknown manufacturer)...
                                07-25-2024, 07:27 AM
