Help with dead Commodore 1802
  • roadrash
    • Oct 2015
    • 490
    • U.K.
    #81
    Re: Help with dead Commodore 1802
    Originally posted by stj
    just a thought, check the mains smoothing cap - the big electrolytic.
    I temoved it and my component tester says consistanty its around 54nf when it should be 150uf 400wv. I still have this resistor showing a dead short that isba red,purple,silver,silver
      • 30956
      red purple silver silver is 2.7ohms 10% i think - that's probably less than your test-leads, so it's fine
      • roadrash
        • Oct 2015
        • 490
        • U.K.
        #83
        So if that filter cap is 54nf is it ok? Its marked as 150uf and 400wv. Isn't 54nf nano farad?
          • 30956
          yes, it's fuckered as AVE would say!
          that could have been the fault.
          • R_J
            • Jun 2012
            • 9534
            That main cap. being open would cause the problem. I had a power smps recently that had a near open main filter and it would blow the main fuse even though everything else (fet etc.) checked ok. All I needed to replace was the main filter and the power supply worked.
            • roadrash
              • Oct 2015
              • 490
              • U.K.
              #86
              Right so I just use a 150uf 400v one then?
              What is 400wv or is that just volts?
              • R_J
                • Jun 2012
                • 9534
                WV= Working Voltage. Thats how they some were marked in the past. it just means Voltage rating of the cap.
                  • 30956
                  you can use 450v if it helps it fit the board better
                  a rubicon BXW series is probably a good choice if the size matches.
                  • Agent24
                    I see dead caps
                    • Oct 2007
                    • 4940
                    • New Zealand
                    #89
                    Some older capacitors may also have two voltage markings; WV for Working Voltage, and SV for Surge Voltage.
                    -David VanHorn
                      • 30956
                      try tweeking the focus control - if you know your cables are well shielded
                        • 30956
                        focus can drift as components age - try ajusting it.
                        • roadrash
                          • Oct 2015
                          • 490
                          • U.K.
                          #92
                          At last the replacement capacitor arrived.
                          Ive soldered it in a plugged it in and nothong happened and neither of the light bulbs we soldered in lit up. Should they have? Should i remove that bulb bridging where the resistor was and solder back in the resistor now.
                            • 30956
                            check your fuses - the lamps should do something even if the cap was not fitted
                            • roadrash
                              • Oct 2015
                              • 490
                              • U.K.
                              #94
                              There is 250v ac entering the psu and the fuse is ok.
                                • 30956
                                refit / connect everything other than the big resistor and try.
                                • roadrash
                                  • Oct 2015
                                  • 490
                                  • U.K.
                                  #96
                                  Ok done that and it powered up without blowing anything but can see anything like the power light iluminate but at least i dont think anything blew.
                                  • roadrash
                                    • Oct 2015
                                    • 490
                                    • U.K.
                                    #97
                                    That was a bit unclear. Ive plugged it in and its taken power without blowing anything so thats got to be good. I still have the light bulb in place instead of the big resistor but I removed the light bulb and soldered back in the coil. I can sometimes faintly hear something when i turn it on but otherwise it doesnt do anything.
                                      • 30956
                                      so the only lamp is inplace of the inrush resistor?
                                      then it should be glowing.
                                      • roadrash
                                        • Oct 2015
                                        • 490
                                        • U.K.
                                        #99
                                        No the lamp thats in place of the resistor doesnt glow and the heater on the tube isnt glowing either.
                                          • 30956
                                          i'll go over the schematic again on saturday
                                          • double_DD
                                            How can I be sure that my EC chip is dead?
                                            by double_DD
                                            As the title suggests, how can I be sure that my EC chip is really dead?
                                            I've recently gotten into this hobby of laptop repairs, and have successfully brought back to life a couple with some easy fixes, mostly shorted caps.
                                            Now I'm working on HP Probook 455 G8, that had some "devil" run around on 3V line, burning a bunch of stuff. Luckily I have a dead 455G7 (for spare parts) so I managed to fix it (swapped burned parts) to a point that it will charge (both on barrel jack and usb-c), but it doesn't want to turn on. There is a 3V3 on a keyboard...
                                            03-12-2025, 07:47 AM
                                          • disorder
                                            ps5 edm-033 dead after hdmi/usb ports destroyed
                                            by disorder
                                            hello guys,
                                            i need help to repair a edm-033 ps2
                                            history : as always hdmi port and usb ports destroyed after unplugged
                                            after change them, ps5 dead too : 1 beep, no blue light. after inspection 1.8v power was shorted, and because of dead panasonic chip. after remove it : no short anymore
                                            so i changed it
                                            now i have got 5v stby,, 3.3v stby, 3.3v power, 1.8v power and no short on them
                                            but the ps5 is dead again : 1 beep, near 10 seconds with power lines and then off, no blue light ...
                                            i don't see any projection of liquid metal on pcb.
                                            01-14-2025, 12:48 PM
                                          • Beton
                                            Finding a dead short component
                                            by Beton
                                            Hi guys!
                                            I searched for the term "dead short" in the forum but no specific thread came up however if I'm just blind and couldn't see the thread talking about this please forward me to that direction.
                                            So my problem is I don't know how to find the source of a dead shorted voltage rail. Dead short = ~0 ohm resistance.
                                            I have two VGAs (HD 4850 and HD 4870), both dead shorted to ground on the memory rail. I have the boardview file for the 4870 and the memory rail consists around ~7892346 capacitors...
                                            I have a bench PSU and if I try to inject voltage the voltage...
                                            12-10-2021, 01:05 PM
                                          • zunasthegreat
                                            Chieftec GPS-450-AA with dead 20N60C3
                                            by zunasthegreat
                                            Hello everyone hope all doing well!
                                            I have this PSU (GPS450-AA delta oem) around for like 4-5 years and I had it recapped early 2020 or 2021 with mostly UCC KY and Nichicon PW's. The bulk was and still is fine, the original Ltec's were bloated and empty. The previous issue was some major coil whine noise and at times random shutdowns when going idle. Today it started tripping the mains breaker and I think I have dead APFC mosfets (20N60C3). Right now upon checking I have the Q1 and Q3 FETs dead so far and I guess those are responsible for the PFC circuit. The only thing I care is If there...
                                            09-01-2024, 07:12 PM
                                          • FiguringITout
                                            MSI Raider GE75 - Not posting, probable dead CPU
                                            by FiguringITout
                                            Hello, today I'm working on this lovely MSI Raider GE75 gaming laptop which I bought to flip. Unfortunately, I believe the CPU is toast but I wanted a second opinion before I chucked it into my spare parts bin. I will not have most tools with me today as I'm away from my workbench but I have the basics (a good multimeter, a horrible iron, a solid screwdriver, and my trusty thermal cam). I do not have the original 230w charger, but I have a Dell 180w which was sold with the device and reportedly "worked fine for them".
                                            Specs: I7-10750H, RTX 2060, 32GB RAM (unknown manufacturer)...
                                            07-25-2024, 07:27 AM
