Guest - Try our new boardview, Bios, & schematic search. Over 1.1 million files for download!
ps5 edm-033 dead after hdmi/usb ports destroyed
  • disorder
    • Sep 2015
    • 159
    • france
    hello guys,
    i need help to repair a edm-033 ps2
    history : as always hdmi port and usb ports destroyed after unplugged
    after change them, ps5 dead too : 1 beep, no blue light. after inspection 1.8v power was shorted, and because of dead panasonic chip. after remove it : no short anymore
    so i changed it
    now i have got 5v stby,, 3.3v stby, 3.3v power, 1.8v power and no short on them
    but the ps5 is dead again : 1 beep, near 10 seconds with power lines and then off, no blue light ...
    i don't see any projection of liquid metal on pcb.
    what can i check now, i'm lost ...
    thank you !
  • LaPCon_IT
    • Sep 2022
    • 84
    • Malta
    You mean it stays on for 10 seconds without blue light? Unusual. But if it does, maybe something is overheating.
    Also, check UART and HDMI chip/port area for missing components.
    • disorder
      • Sep 2015
      • 159
      • france
      hello
      some news, bad news
      i finally find that f7002 is blown, a find dead short on 1.8v line.
      i have injected 1.2v 2amp courant, the only thing heating up is the other side of the board, circuit with A2 buck converter (right?) ,
      on this side : (check the picture) short to ground is indicated
      when i inject on test point 1 : the coil at the right heating up, and when i injected at the upper side of this coil , the chip heating up
      when i inject on test point 2 : nothing is hot....nothing !!!
      i don't know what to search now
      • LaPCon_IT
        • Sep 2022
        • 84
        • Malta
        Test point 2 is ground. Remove the capacitor next to the red circle and check, if the short is still present. If yes, remove the chip and test again.
        I assume F7002 is the one on the picture? I don't have edm-033 on hand right now. If yes, check for shorts to ground on both sides of the fuse.
        • disorder
          • Sep 2015
          • 159
          • france
          hello
          some more precise informations, sorry for bad quality of picture (the picture above was taken on internet and not exactly correspond at edm-033)
          2 pictures here with mesures description and diode mode readings :
          picture 1 : side of APU and at f7002 location. here fuse is blown but no short at its sides, the short is on the 1.8v line (i think it is) at the extreme right.
          picture 2 : on the opposite side of APU but exactly at the same location of f7002 circuit, here short on the bottom line. i think it is the same line as the APU side where i found the short.
          i have remove all caps on this line and de A2 marked chip (opposite side of APU) and nothing change : i always have that damned short.
          thank you for help
          • LaPCon_IT
            • Sep 2022
            • 84
            • Malta
            Short means how many ohms? Did you inject voltage into the shorted rail after removing both the caps and the chip?
            • disorder
              • Sep 2015
              • 159
              • france
              hello
              yes, i try removing caps and the chip but short always there, and nothing get warm..
              don't know where this 1.8v voltage line goes elsewhere, maybe i could finally find the short
              • LaPCon_IT
                • Sep 2022
                • 84
                • Malta
                1.8V, among other things, goes to the southbridge chip. You said that USB ports ware also damaged. Data lines from USB go to SB as well. Maybe it is damaged.
                When you inject voltage, what the current draw is? Do you use bench power supply and thermal camera?
                • Andreasbest
                  [Solved] Fujitsu Lifebook E558 USB / HDMI / DisplayPort / LAN / 3.5" jack dead
                  by Andreasbest
                  Hello.
                  I just solved a mystery with the right USB or HDMI/Displayport or Ethernet or 3.5" jack of Fujitsu Lifebook E558 going suddenly dead.
                  I realized i had 6 pieces of the same model with the exact same issue, nothing on google, neither schematics so i had to dig in my self and provide feedback here in case someone else has the same issue.
                  I found out that the USB daughterboard is connected to the mainboard with 2 wide and non bending flex tapes that are 2mm longer than they should and this results in a constant pressure on flex connector and therefore eventually it cracks...
                  11-26-2024, 11:50 AM
                • aliougm
                  Marantz SR4003 AVR HDMI board issue, seeking for help
                  by aliougm
                  I have problem with my AVR(Marantz SR4003) HDMI board issue. I connect to my TV but screen color distorted,see attached picture.
                  Connection as below:
                  Set-top box HDMI output >AVR 3 HDMI input/one HDMI output>HDTV HDMI port
                  If I bypassed AVR then HDTV screen color be good.
                  I take out HDMI board from AVR and check services manual the schematic shown the HDMI signals path:
                  3 HDMI input port > SIL9185 chip(HDMI switch) > SIL9033 chip(HDMI receiver) > SIL9030 chip(HDMI transmitter) > HDMI output port
                  I replaced all...
                  04-30-2022, 12:21 PM
                • Data45000
                  Denon AVR-X2600H DAB - HDMI Ports dead
                  by Data45000
                  Hi there,
                  I just wanted to watch another episode of Luficer last night and had turned on my AVR with the FireStick.
                  Suddenly I heard a dull bang. "Poof"
                  I noticed that several HDMI inputs no longer work at all. Some only work when a PC signal is present or only one signal on the whole input side.
                  Often the picture goes black or it jerks up and down as if the signal is present briefly, but then disconnects in a loop.
                  However, the front HDMI works perfectly...
                  Would anyone have an idea what is defective here...
                  04-17-2023, 04:59 AM
                • spleenharvester
                  Toshiba 50UL2063DB randomly rebooting with HDMI-CEC and/or HDMI-ARC enabled
                  by spleenharvester
                  I have this TV hooked up to only an AppleTV 4K and a Creative soundbar. Originally HDMI-CEC and HDMI-ARC wouldn't work at all, I replaced all the HDMI cables with decent UGREEN cables meeting the latest standards, now it all works perfectly but once or twice a day the TV itself reboots while watching a program, the AppleTV keeps running. I haven't fully pinned down whether it is ARC or CEC causing it yet. All are running latest firmware.
                  I assume it is just HDMI-CEC being buggy as usual on a shitty Vestel machine, but can anyone think of anything I can try before disabling it?
                  03-12-2025, 03:42 PM
                • japlytic
                  Certain DisplayPort-HDMI cables can disable HDMI CEC communication
                  by japlytic
                  With a setup including a TV and AV receiver where HDMI Consumer Electronics Control (CEC) and Audio Return Channel (ARC) functions were working, these two functions stopped working after changing some connections (not the one between the AV receiver and TV), so I believed it was a corrupt setting in the AV receiver or TV, but when I disconnected a passive DisplayPort-HDMI cable (which a Multimode DisplayPort connector supports HDMI with a low cost passive cable or adaptor) connected to a home theatre PC, HDMI CEC and ARC functionality was restored.
                  An examination of the HDMI CEC wiring...
                  07-10-2022, 09:48 PM
