LCD 19" BENQ T905 problems
  • chriz74
    • May 2011
    • 16
    #121
    Re: LCD 19" BENQ T905 problems
    Originally posted by retiredcaps
    If the power LED is green or yellow, the power supply and logic card are likely to be working. That is, 1200AP40 is working.
    Yes, led is alright but BENQ logo is not showing.
    • icewolfca
      • 3
      #122
      I replaced the transistors and most caps. It now powers on and shows windows for about 1 second and then goes blank. What would cause it to work and then stop? Thank you.
      • retiredcaps
        • Apr 2010
        • 9271
        #123
        "2 seconds to black" is described in post #13 and #14 at
        https://www.badcaps.net/forum/showthread.php?t=10419
        Focus on
        1) bad caps
        2) bad inverter transformer
        3) bad ccfl and/or wiring
        Also, please post pictures of your boards as described in misc suggestions #1 in the same URL above.
        PS. You MUST resolder all the inverter transformer pins on Benq boards.
        PPS. Did you recheck the transistors to make sure they are not shorted after you installed them?
        --- begin sig file ---
        --- end sig file ---
        • icewolfca
          • 3
          #124
          Focus on
          1) bad caps
          1) I replaced most caps. After reading your post I replaced more caps. I need order some more.
          2) I resolder the inverter transformers prior to posting here.
          3) I sure hope not
          but I did check my soldering job and there was a short or two and I fixed those. It now stays on and there are no issues any more. So it is all good . I am just starting and i lack proper tools. But I am getting there. Thank you for the quick reply and I LOVE this forum.
          Josh
          • chriz74
            • May 2011
            • 16
            #125
            update:
            I replaced all 5707 (4), 9024n (2) and the fuses. Lamps are still not working, led goes from orange to green when signal arrives from pc. I still can't see the BENQ logo.
            • chriz74
              • May 2011
              • 16
              #126
              .. well the NCP 1200ap40 is gone. It reads 300V on pin 8. Does anyone have a working one? It doesn't seem that easy to find.
              • jannu47
                • Jul 2011
                #127
                Okay, has anyone following problem: First, the benQ logo shows about second or two, then blinks and, then shuts down the hole monitor. Fine, i have read all the messages on here, so i decided to replace the "bad" elite caps, all C5707´s, where half are burned, picofuse and re-solder all transformers.. And test.. Voila! We got a picture! :-) Also i read someone has got the picture, but about minute or two... So i decided to surf via net, use some youtube etc.. About one hour.. And we got the picture. So i assume that problem was fixed? Then i press the power button on the monitor and shut it down. Now, nothing came up, when i press pwr button.. Not even BenQ logo.. powerled stays green hole time, but no picture... Any quess, what goes wrong?
                PS. Sorry about my bad english, hope that somebody can get a clue of this :-)
                • alexanna
                  • Mar 2010
                  • 1346
                  #128
                  Check and see if the pico fuse has gone open
                  • jannu47
                    • Jul 2011
                    #129
                    Thanx Alexanna for a quick response! Yeap, it was that! Picofuse has blown for first time and when i replaced it, the original fault came back.. A quick second or two benQ flash and then all black.. So it seems, that somehow the C5707´s burned again? Maybe those 9024N´s got to something to do with it? (I ask couple on resellers, but they don´t have them...) So i decided to use old ones... Well, they work (at once at least), because i got the picture once, only with new C5707´s...
                    • dantetrade
                      • Jul 2011
                      #130
                      Hi, I got the same problem, my screen lit up for a few sec and went black. I followed the instructions: desolved/resolved transformers, K's,... Bought package on ebay (5.5ÂŁ) of 4transistors C5707 + 2 Fets 9024n. Replaced these and ... screen works like new. My thanks to you all.
                      Important !!! Use the original transistors Sanyo 400 HFE. Replacements give only 200 HFE and just last for a sec.
                      • enoteco
                        • Dec 2011
                        #131
                        standard problem screen switch of after few sec,
                        following hints at post #21 and replacing C5707+9024n + picofuse;
                        now my my monitor work like a sharm .
                        Thank you all.
                        • ^Active^
                          • Apr 2012
                          • greece
                          #132
                          Hi I had the same problem so i decided to change one of the capacitors that was faulty. The monitor powered up normaly and i let it run for about an hour for a test. When i decided to shut it down by the power button it wasnt responding so i pulled out the power cord and now when i plug in the power the monitor doesnt work at all .. no green light no nothing . Any suggestions?
                          • selldoor
                            Slow Learner
                            • 7870
                            #133
                            @active- Main suggestion would be to read this thread from beginning to end.
                            You will uncover the main problems. Start with easy things check the power cord and and fuse in plug (if you have fused plugs in Greece) check the cap you replaced.
                            Check the fuse/s on the board. Check the transistors. When you have done that come back and advise what you have found.
                            • ^Active^
                              • Apr 2012
                              • greece
                              #134
                              I have already done all these sorry forgot to mention it and i have read the forum also . Could it be the 1200ap40 that is causing the problem?
                              • jetadm123
                                • 2169
                                #135
                                Good focused photos of the top and bottom of YOUR power board will help members point things out for you to check. There were different variations of your power supply used in the T905 and without photos, it's difficult to provide help. Use the "manage attachments" option to attach your photos.
                                • jet
                                  • Apr 2012
                                  • 58
                                  Hi All,
                                  My first post here. Has anyone sourced an equivalent part to the FU9024N. I am in Canada and would like to find some local. Seems to me that part is week anyway. I read in another thread of someone modifying the circuit around the FU9012N but the link was dead. Any help appreciated.
                                  Joe
                                  • hua3
                                    • Nov 2012
                                    • 5
                                    • italy
                                    #137
                                    Originally posted by dvorav
                                    Hi 2 All,
                                    I got the new parts (IRFU9024Ns) recently. So I mannaged to change one 9024N and pico fuse 3.A. Guess what! Monitor is up and running. I'll let it run for a while to see if the fix is permanent. So far it seems that IC 52 CJ5YK TL1451A is good. And I think it will be for some time
                                    Thanks for reading and replying. I hope this thread will help to someone.
                                    See ya
                                    My LCD 19" BENQ T905 has the same problem: no power and no light of the power led. I checked that all the caps are ok (not blown), fuse is not broken, all the IRFU9024 have no any fried evidence. There is voltage on the 400 V cap when connect the power plug. Any one can help me to restart the monitor?
                                    • selldoor
                                      Slow Learner
                                      • 7870
                                      #138
                                      What voltage on the 400v cap?
                                      Which fuse?
                                      We need pictures
                                      Welcome to the forum-
                                      We can help a lot more if you please post good clear pictures of the whole chassis, and then pictures of each board, front and back and close up of connectors, (max resolution 2000x2000 and 2MB) using the manage attachments button, which is found by clicking "go advanced" under quick reply.
                                      Examples of what is needed
                                      https://www.badcaps.net/forum/attach...1&d=1290283049
                                      https://www.badcaps.net/forum/attach...7&d=1280167246
                                      It will be useful if you can say what the supposed fault was and a bit about yourself - skills tools etc.
                                      • hua3
                                        • Nov 2012
                                        • 5
                                        • italy
                                        #139
                                        Dear Selldoor,
                                        Thanks for your quick reply. The voltage on the 400v cap c605 = 316V.
                                        the 2 fuses measured on board are 0 ohm for f 601, and 0 ohm for the picofuse fp 601 respectively. I attached here the pictures of board both sides. Please help me to find the problem and give me instruction for resolving it.
                                        • hua3
                                          • Nov 2012
                                          • 5
                                          • italy
                                          #140
                                          Dear Selldoor,
                                          the 2 fuses measured on board are 0 ohm for f 601, and 0 ohm for the picofuse fp 801 respectively. I attached here the pictures of board both sides. Please help me to find the problem and give me instruction for resolving it.
                                          • Caspar
                                            BENQ GW2780-T power board blown
                                            by Caspar
                                            Hi all, I am looking for some help in ID'ing some parts in an attempt to fix a power supply from a GW2780-T monitor. The power supply PN is 715G7300-P02-006-0V3R. I have been looking around for the PN and it appear the board was used by other OEMs as well (ASUS, Viewsonic). If anyone has a schematic, it would be helpful.
                                            Quick look on the underside of the board, I can see:
                                            -D905 is blown - ? value
                                            -R920 is open - 1Ω ?W
                                            -R927 is open - 20Ω ?W
                                            On top side, I see:
                                            -R931 open - 0.68Ω ?W
                                            Metered short:
                                            -P9NK65ZFP...
                                            06-01-2022, 05:16 PM
                                          • jean luc ferre
                                            laptop hp g72 b52sf screen problems
                                            by jean luc ferre
                                            on this laptop hp g72 b52sf i have screen problems as you can see with the photo joined in attachments.
                                            the used graphic card is "intel hd graphics" and the id of the integrated screen is : "monitor/SEC3354".
                                            i verified the driver of the péripherals and they are ok. i verified the definition and settings of the graphic card and of the screen : definition 1600x900 and refreshment frequency :60hz. (they are the sames for the graphic card and the screen).
                                            i don't understand the reasons of the white stripe at the bottom of the screen below the task...
                                            06-07-2025, 03:27 PM
                                          • drscoot
                                            HP X360 convertible battery blown fuse error, not charging
                                            by drscoot
                                            HP Modelnumber: 14-dh0061nb​
                                            This laptop had a shorted cap on a Vcore section. After replacement is works again. But there is still a battery issue.
                                            The battery is HT03XL and with the built-in component test from HP, in the Power section, I get an error: Logic State: Calibration required (20), Charge state: Blown Fuse (42)
                                            I have another same battery, also with error: Logic State: Very Weak (70), Charge state: Blown Fuse (42)
                                            And a third battery TF03XL (looks identical) with error: Logic State: OK (0), Charge state: Blown Fuse (42)
                                            All these 3 batteries are charging...
                                            12-15-2023, 05:54 AM
                                          • Hondaman
                                            USB problems?
                                            by Hondaman
                                            Recently I discovered my SSD died (OCZ/Toshiba 240 GB). It was in a USB enclosure, attached to the Linksys WRT-AC1200 router. Since then I removed the USB enclosure and attached it to my Win7 PC (AMD 8150 CPU, 970 chipset, 64 GB RAM). I also gathered one or two other USB enclosures to figure out what is going on.
                                            (I suspect that I lost quite a few MP3 and FLAC files I recently ripped from my audio CDs, I think I lost very little un-replaceable stuff.)
                                            I think it is IMPOSSIBLE for Win7 to have any problems with a USB enclosure as long as Win7 knows how to speak to the...
                                            08-12-2024, 03:26 PM
                                          • swerg
                                            Part selection for possible blown inductor on ASUS GX531-GW-AB76 laptop mobo
                                            by swerg
                                            Hey everyone,
                                            I'm a novice trying to repair my laptop. The LCD screen has an image, but no LED backlight for the image. It also produces an image when connected to an external monitor.
                                            I have found what I believe to be a blown inductor labeled "L4502" and "120 Ohm" in the schematics (zoomed in image, blue arrow to blown component). I have included an image of the general area of the mobo and an excerpt from the schematics as well.
                                            I am having trouble selecting a replacement component, which I believe to be a 120 Ohm ferrite bead, from the components...
                                            06-06-2024, 03:39 PM
