HP X360 convertible battery blown fuse error, not charging
This topic has been answered.
  • drscoot
    • Dec 2020
    • 44
    • Belgium
    HP Modelnumber: 14-dh0061nb​
    This laptop had a shorted cap on a Vcore section. After replacement is works again. But there is still a battery issue.
    The battery is HT03XL and with the built-in component test from HP, in the Power section, I get an error: Logic State: Calibration required (20), Charge state: Blown Fuse (42)
    I have another same battery, also with error: Logic State: Very Weak (70), Charge state: Blown Fuse (42)
    And a third battery TF03XL (looks identical) with error: Logic State: OK (0), Charge state: Blown Fuse (42)
    All these 3 batteries are charging normally in an other laptop. So I don't believe the 3 blown fuses. In fact the laptop runs OK from the battery, until it is empty.
    So when I plug in a charger, I get an orange led, in Windows I see the battery symbol that power is connected (flash symbol), but the battery isn't charging! But the laptop is working OK. When I measure voltage at the battery conntecor +/- I see 11.50V and no change with or without charger attached. I use an HP charger capable of outputting 19/6A, tried others also.
    Now here is my unexplained find:
    when I attach my benchpowersupply set to 19.5V 2A to this laptop it takes all the power it can get; the full 2A, in such way that the voltage drops to 14V. If I set the current limit on the benchpowersupply even higher to 3A, it takes 3A! I don't get any powerled, not white not orange.
    Of course the first 2 mosfets getting >65°C then. But it looks the battery is charging, When I measure the batteryvoltage again I see12.50V, when I disconnect the charger it drops again to 11.50V or even 11.60 when I let it charging at 2A for 5min.
    When I use then benchpowersupply on another similar laptop with these same 3 batteries I do get orange led and a more normal loading current 19V 1.5A
    For my benchpower supply I use an HP bluetip charge cable that I recuped form a broken charger. If I recall right, there are 3 leads, black white and blue in this cable. White or blue is sort of signal wire, I think I have this connected with a resistor to + ( a tip I found earlier somewhere).
    Maybe this is the reason why I get a charge with the benchpowersupply and not with the HP 6A charger?
    But what is the issue then with this logic board? Is there another component failed due to the badcap at the Vcore circuit?
  • Answer selected by drscoot at 12-17-2023, 05:18 PM.
    motanya
    • Nov 2021
    • 160
    • Kenya
    Check the resistance between the two ends of the 1st two mosfet, normally near the charging port connector. Any of them with low resistance needs to be replaced
    • motanya
      • Nov 2021
      • 160
      • Kenya
      • mcplslg123
        • Jun 2015
        • 7262
        • india
        Compare AD_ID voltage with
        01.Original adapter
        02.DC power supply
        • drscoot
          • Dec 2020
          • 44
          • Belgium
          [QUOTE=mcplslg123;n3163542]Compare AD_ID voltage with
          what do you mean with AD_ID voltage? Where can I measure this?
          • drscoot
            • Dec 2020
            • 44
            • Belgium
            So a little update here. motanya was right! The very first mosfet (SM4378 N-channel) only measured 2 ohms. I think it got damaged when there was a shorted cap, pulling much amps and overheating this mosfet. I replaced it with AON 6426 and now it is charging OK.
            I still have that battery fuse error when using the Diagnostic Power test, but that is related to the recup HP charge cable that I use on the bench supply. With the orginal HP adapter no fuse error! Also this HP test cable is only charging when the laptop is OFF.
            I wondering if there is way to use such recup HP test cable (recovered from a broken charger) on bench power supply, that fully works like an HP adapter?
            Thanks to Motanya for the tip!
            • mcplslg123
              • Jun 2015
              • 7262
              • india
              AD_ID can be measured on the dc jack itself(usually brown wire). If you want to use a hp adapter cable with dc supply,then centre pin must be connected. Only red/black goes to dc supply. So connect a 330K resistor between centre pin(AD_ID) wire and +19V wire(red). that will create AD_ID voltage for 65W adapter and motherboard will ceognise dc supply as 65W hp adapter. The solution is already posted in this forum.
              PS: Always make it a habit to check first dc-in mosfet for short when ever main rail is shorted. 90% of the cases,it'll result in a shorted 1st dc-in mosfet.
                NVDC charger configuration...
                11-05-2024, 03:28 PM
                ISL6257HRZ ISL6257HRZ-T Laptop Battery Charger Datasheet
                Highly Integrated Narrow VDC Battery Charger for Notebook Computers
                The ISL6257HRZ ISL6257HRZ-T is a highly integrated battery charger controller
                for Li-Ion/Li-Ion polymer batteries. ISL6257 is designed for
                Narrow VDC applications where the system power source is
                either the battery pack or the regulated output of the charger.
                This makes the max voltage to the system equal to the max
                battery voltage instead of the max adapter voltage. Operating
                at lower system voltage can improve...
                11-05-2024, 04:43 PM
              • Bowline
                by Bowline
                06-11-2025, 10:13 AM
                Bauer tool battery pack charging with a HERCULES charger modification
                The Bauer power tool battery charger just has to many issues with the charger over heating because I several HERCULES Hercules battery chargers that are 3 amp charge and because they have gone on quite a few times over the years before they came out with the fan cooling battery charger I going to modify one so I can charge Bauer battery packs faster than the crape battery charger that they have
                Here is how this modification is going to be done I taking a 1.5 amp hour battery enclosure and gutting it removing the battery cells and replacing some Ryobi 1.5 amp hour battery pack that...
                05-06-2023, 12:17 PM
                Milwaukee M18 HD12.0 (12 amp hour battery pack) unbalanced failure charger refusing
                I have two Milwaukee 12 amp hours battery packs that have an issue with battery cells very unbalanced these are probably over 4 years old and been heavily used in the past but now get occasionally used heavily and when I went to use the grinder tool the battery lost battery battery power very quickly so I decided to open it up and found some battery cells voltage from 3.6 to 4.1 no wonder the battery charger was not fully charging them 3 out of 4 LEDs were on meaning that it was only 75% charged
                So I have put them on the battery testing machine to drain each battery cell down to...
                09-04-2022, 04:45 PM
