USB problems?
  • Hondaman
    • Sep 2008
    • 1105
    USB problems?
    Recently I discovered my SSD died (OCZ/Toshiba 240 GB). It was in a USB enclosure, attached to the Linksys WRT-AC1200 router. Since then I removed the USB enclosure and attached it to my Win7 PC (AMD 8150 CPU, 970 chipset, 64 GB RAM). I also gathered one or two other USB enclosures to figure out what is going on.
    (I suspect that I lost quite a few MP3 and FLAC files I recently ripped from my audio CDs, I think I lost very little un-replaceable stuff.)
    I think it is IMPOSSIBLE for Win7 to have any problems with a USB enclosure as long as Win7 knows how to speak to the motherboard's USB controller chips. But one or more of my USB enclosures makes Win7 give a message that it is trying to obtain drivers, and it never succeeds. So obviously it IS possible for Win7 to have problems with the USB enclosure's chips, OUTSIDE the motherboard's USB chips.
    (Clearly in the future, I will need to use Linux (perhaps an awk script invoking the "cp" copy command) to back up files to the USB enclosure, then after the initial backup, copy only those files that I updated [docs / spreadsheets mostly]. The command line is a valuable tool indeed.) (I've dual-booted since my Windows 3.1 / Caldera Linux days with my K5-166 MHz CPU, so I have long had that "safety net" of Linux.)
    Any idea what's going on here? If I buy a modern USB enclosure, will I have even more problems? Will Linux also have a problem seeing the drive, in addition to Win7?
  • eccerr0r
    Solder Sloth
    • Nov 2012
    • 8777
    • Fixing Failed Fuhjyyus
    I really don't think there's any issues with USB, as USB-storage is pretty standardized. Most of the issues likely being seen are due to bad connectivity or bad power causing possibly permanent damage to the storage medium. Yes there are some bad USB-ATA bridges out there but other than causing slowdowns and hiccups, shouldn't cause damage to the media except for power.
    I really don't think Linux helps except for the fact that it doesn't care about any windows shenanigans that it tries to write to the disk.
    If you see problems with a direct SATA connection I don't think Linux will have any better luck. However tools like ddrescue and photorec are OSS and you'll be OSS all the way down to the hardware when using them in Linux.
    Anything worth keeping better have more than one copy, and the OS doesn't matter. I don't see why Linux is needed for doing backups, and you're not immune from data loss using Linux either... ask me.
      • 31709
      what type of ssd is it? maybe it uses usb and there is no chip in the enclosure
      • Hondaman
        • Sep 2008
        • 1105
        Interesting......I booted from a DVD of Mint 21.3. After about 8 minutes, the live environment came up. Mint 21.3 was able to read a 1.0 TB WD Black spinning drive (one big NTFS partiiton, backup of documents, spreadsheets, pictures) in 2 different USB enclosures. The 500 GB Samsung EVO 570 SSD is apparently BLANK, and this is why Windows and Linux could not read it (I thought it had Mint 21.3 on it). I'll probably have to use a rescue CD/DVD to format the SSD (no other hard drives present) before I can use the 500 GB SSD. So once again, the problem is my lack of understanding of what's going on.
        Thanks !
        • Hondaman
          Win7 Emulation in Linux
          by Hondaman
          If I install Win7 in VirtualBox or KVM, will Windows be tied to that exact hardware? Can I take the VM and move it to another machine at some point without having to re-activate Win7?
          I bought a replacement board identical to the one Win7 is licensed on. But of course it failed. I have two more identical boards in my basement. Running out of acceptable hardware will not happen for quite a few years, hopefully.
          But I am looking forward to that day when I cannot find any hardware, and I have to use emulation. Does anyone have experience with this?
          07-21-2025, 12:46 AM
        • Hondaman
          Japanese language -- Win7 or Linux Mint?
          by Hondaman
          I ordered a Japanese book, it will never be published in English. A Mr. Fujumoto was a Japanese sushi chef who became a cook for Kim Jong-Il. He was not perceived as a threat to the dictator's power, so he became very close to the dictator. Apparently, the dictator is QUITE hedonistic, with a lot of debauchery. Although he can spend as much as $700,000 per year on alcoholic beverages and this alcohol is NOT actually the highest quality. Also, the dictator has 24 palaces. One of them is as large as TEN YANKEE STADIUMS PUT TOGETHER. Are they all that large?
          Does anyone have experience...
          09-12-2025, 04:32 AM
        • Hondaman
          Backup to USB drive
          by Hondaman
          Okay, I fixed my USB problems discussed in another thread. Now I would like to back up some files. I bought a USB enclosure and a 2 TB SSD (I should have saved $50 and bought one without cache, but I bought the more expensive Samsung EVO 570 instead).
          I seem to prefer Linux Mint, although I could probably use Microsoft Backup for Windows 7. I think it still exists. Here's what I did with Mint 18.3 tonight:
          Code:
          cp * -pR "/mnt/win7-drive/users/mike/My Pictures/" "/mnt/usb-enclosure/My Pictures"
          and
          Code:
          cp * -pR "/mnt/iwn7-drive/users/mike/My
          08-29-2024, 11:32 PM
        • Boardview and Schematic Bot
          HP EliteBook 840 G6 + Qnap 2-Bay Personal Cloud NAS Enclosure Notebook 800 Specification for Upgrade or Repair
          This specification for the HP EliteBook 840 G6 + Qnap 2-Bay Personal Cloud NAS Enclosure Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 840 G6 + Qnap 2-Bay Personal Cloud NAS Enclosure boardview and 840 G6 + Qnap 2-Bay Personal Cloud NAS Enclosure schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant...
          09-06-2024, 07:50 PM
