Viewsonic VX900 Bad Inverter
  • ZappedAgain
    • Mar 2011
    • 49
    Trying to save a Viewsonic VX900 from the landfill. Monitor will turn on with a green light but there is no backlight. Flashlight reveals that the image is there. Was able to find a service manual and was able to follow a troubleshooting chart which says I have a bad inverter. I believe I agree with this diagnosis. Here is what I have done.
    1. Checked all connections to the inverter.
    2 Checked for 5v and 12v to the inverter at the proper locations.
    3. Checked Q2 Q3 Q11 Q12 no shorts appear to be good.
    4. No bad solder joints
    5. 2 fuses near CN1 are both good 0 ohms
    6. Checked D1 and D2 no shorts.
    A new inverter is available for 35.00 but that is probably about what the monitor is worth. Would love to fix it if I can. Could it be bad caps? They look Fine 100uf 35v KMF x 2
    I am willing to put the time in just too cheap to spend the money on a new inverter.
    Re: Viewsonic VX900 Bad Inverter
    So, you do not notice the backligts ever flash on for seconds if you at it in the dark room?
    • Rtech
      • Jul 2010
      • 1095
      Transformer secondary resistances ???
      • Davi.p
        Hobbist Tech
        • Sep 2009
        • 4367
        • Italy - Milan
        After that if all ok open the screen and watch for damaged solderings at the lamps or darkened ends.
        • ZappedAgain
          • Mar 2011
          • 49
          Budm
          Yes if i Turn the monitor off and back on with a PC connected I get a display for about half a second.
          Rtech
          Secondaries measure .2 ohms between all 4 pins both transformers.
          Davi.P
          I have a ccfl tester. It has the small ccfl connectors. I will get out the alligator clip leads and connect and test the ccfl's
          • Davi.p
            Hobbist Tech
            • Sep 2009
            • 4367
            • Italy - Milan
            lamp connectors are protected, i think there's no space for alligators.. you can solder wires..
            • selldoor
              Slow Learner
              • 7870
              Originally posted by ZappedAgain
              Budm
              That doesnt sound correct did you have your meter on 2000 ohms.
              If not try again - can you see a part number on a transformer
              • ZappedAgain
                • Mar 2011
                • 49
                Ok First Readings on the Transformer Secondaries where made with an autoranging fluke 116.
                Remeasured with a Wavetek
                on 2000 range readings between all four connectors is 0.0
                on 200 range readings are 1.2 ohms on all connectors both transformers.
                Ken
                • selldoor
                  Slow Learner
                  • 7870
                  Cant believe they are all shorted. Must be using the wrong tabs
                  Can you make out the part number.
                  • Davi.p
                    Hobbist Tech
                    • Sep 2009
                    • 4367
                    • Italy - Milan
                    Selldoor if you watch the picture you see that pins on output are united by a track (don't ask me why) , i think this is not new in my memory, maybe lamp connectors are connected 1 pin to the transf. & 1 pin to chassis ground.
                    • Davi.p
                      Hobbist Tech
                      • Sep 2009
                      • 4367
                      • Italy - Milan
                      To the OP: after the ccfl test i think if you have initially worn lamps you can continue to use them by re-trim the feedback, locate D3 and D4 diodies , D3 is to the right of Big L1.. from them 1 leg arrives to a resistor that goes to gnd, that must be swapped with 2 trimmers for measurements, set it to the same value of smd resistor then mount them, switch on the mon. see if lamps works, if not increase a bit the value of both, switch off and on, if it don't stay on repeat, if yes decrease both until ccfl goes off, then increase a bit, see if is a good value then dismount them measure them and replace with same value or a bit higher smd resistor.
                        The inverter transformer drive is ROYER Self Oscillating circuit, the amount of lamp brightness is adjusted by using variable DC feeding the OSC, it is done by the MOSFET Q8, 2, D2 (Q1, L1, D1 for the other channel) the Pulse width signal from the PWM IC is used to drive the Gate of the MOSFETs. If the MOSFET Q1/Q8 has shorted S to D, the lamp will be fully on all the time. The PWM will be not be sending the signal to turn on the MOSFET if it detects open lamp (lamp not connected or will not stay on after firing voltage is applied), or circuit draws too much current. So anything goes wrong in the first 3 seconds, the circuit will go into shutdown (this 3 second time out can be bypass for troubleshooting purpose by grounding one of the pin on the IC).
                        One end of the lamp is connected to the ballast cap then the transformer winding, the other end of the lamp is connected to the resistor/diode network for the lamp sensing circuit.
                        So, did you check or replace the two electrolytic caps C1, C24 yet? Try heating them up with hair dryer.
                        C2, C3 of the Royer Osc also need to be checked.
                        You can also have bad lamp assembly that needs to be verify.
                        Bad lamps:
                        http://s807.photobucket.com/user/bud...?sort=3&page=1
                        Test lamps:
                        https://www.badcaps.net/forum/showthread.php?t=19987
                        • selldoor
                          Slow Learner
                          • 7870
                          Like I said, must be using the wrong tabs?
                          • Davi.p
                            Hobbist Tech
                            • Sep 2009
                            • 4367
                            • Italy - Milan
                            i don't know what do you mean..
                            • tron
                              • Apr 2009
                              • 47
                              secondary windings for backlight
                              have high resistance, 200mohm
                              is a low resistance reading
                              tabs are where
                              the transformer
                              pins come out
                              of the secondary
                              (high voltage/resistance side)
                              and go to light up the tubes
                              01 and V1...06 and V6
                              is the row where
                              the secondary side is in this
                              picture:
                              https://www.badcaps.net/forum/attach...chmentid=13909
                              • ZappedAgain
                                • Mar 2011
                                • 49
                                Here is a picture to show where i measured the inverter transformers. Hope this clarifies things. I will work on making sense of the other post to give it a try.
                                I am not a professional at this.
                                • selldoor
                                  Slow Learner
                                  • 7870
                                  You have still not advised the part numbers off the inverter transformers.
                                  and I cant quite read it -its in black on that orangey transparent plastic.
                                    Yes, we need the P/N as printed on the transformer to look up the pin out.
                                      Try this reading, it is similar to one of the transformer I worked on before:
                                      • ZappedAgain
                                        • Mar 2011
                                        • 49
                                        Transformer has the following Numbers on top in two lines
                                        2801947600
                                        DC6M 0313
                                        Thanks Guys and Merry Christmas.
                                        Ken
                                        • AstutePauciloquent
                                          Requesting Help For GA-970A-DS3 rev. 1.0, No Post code, no RSMRST# signal
                                          by AstutePauciloquent
                                          Hi everyone, over the past few months i have taken a deep dive into motherboard diagnostics and I love the challenge. Currently im trying to learn all about the signals that travel around the motherboard, such as frequencies, enable signals High and Low logic states etc. And i have been learning to read and using the Schematics for this board that i requested here on Badcaps forum, from a few months ago, this is such a great place for these.
                                          I’ve been working on a GA-970A-DS3 (rev. 1.0) that does not post. This motherboard has been my main learning board. I would like share...
                                          11-23-2023, 11:02 PM
                                        • lostone
                                          Looking for help with a Viewsonic VP230mb where the backlight comes on only momentarily
                                          by lostone
                                          Hello, I came here after finding some similar questions asked on other monitors and hope someone here can help me get an ancient Viewsonic VP230mp (23" 4:3 LCD) back to working condition.
                                          First a little background, I have a background in computer and electrical engineering, and I'm smart enough to know I know nothing about LCD displays and how they work. For this topic I'm as green as they come.
                                          When the display is turned on the viewsonic logo displays in the uppper left for 2 seconds then the screen goes black, the power LED is green (on) and when a computer is connected...
                                          05-19-2024, 11:40 AM
                                        • x_orange90_x
                                          by x_orange90_x
                                          01-29-2025, 09:24 PM
                                        • valvashon
                                          Insignia NS-LCD19-09 (PS OK, Inverter problem?)
                                          by valvashon
                                          For some reason I'm just not going to let this 19" TV defeat me. I guess because I have a schematic to work from I feel like I'm oh so close.
                                          History- while adding a turn-on circuit I let a small screw roll under the power board. Worked through all of that circuitry, probably replacing a MOSFET and PWM controller that were not bad but I was following the service manual. Finally figured out that the power supply is in working order when the inverter section (for the backlights) is disconnected. When the +12 supply to the inverter is disconnected the +12 and +5 will come up...
                                          01-04-2024, 01:44 PM
                                        • eccerr0r
                                          A modified sine wave inverter + a grid tie inverter?
                                          by eccerr0r
                                          If I had a solar fed grid tie inverter (GTI), a modified sine wave inverter, and a power outage occurred, what would happen if you disconnected mains, backfed the modified sinewave inverter (MSI) into house power, and hooked up the GTI to the output of the MSI, would it work?
                                          Next thing is trying to charge the batteries using solar power, but that's another issue ...
                                          08-31-2023, 09:14 PM
