Requesting Help For GA-970A-DS3 rev. 1.0, No Post code, no RSMRST# signal
  • AstutePauciloquent
    • Oct 2023
    • 9
    • New Zealand
    Hi everyone, over the past few months i have taken a deep dive into motherboard diagnostics and I love the challenge. Currently im trying to learn all about the signals that travel around the motherboard, such as frequencies, enable signals High and Low logic states etc. And i have been learning to read and using the Schematics for this board that i requested here on Badcaps forum, from a few months ago, this is such a great place for these.
    I’ve been working on a GA-970A-DS3 (rev. 1.0) that does not post. This motherboard has been my main learning board. I would like share some of my findings to hope that someone can guide me in the right direction as to what the possible reason for this board not having post code could be. As I have 4 other desktop motherboards with the same fault, leading me to believe this problem is common.
    I will start by saying that I have flashed and verified both bios chips. Next, the diagnostic card shows no numbers, no post codes, and the RESET LED just flashes over and over. There is alot here so I will break it down and give what seems to be the most interesting findings.
    The PS_OUT and SLP_S3 are pulsing (repeating) in time with the RESET LED on the diagnostic card. There is no RSMRST# signal before or after the Power button has been pressed. SLP_S5 is signal LOW. CLKIN on the super IO has No Frequency Expected 48Mhz from Clock IC. CPU_PG on Super IO has No signal
    The following is everything i have done/checked far
    . Flashed and verified both bios chips
    . Checked the Clock IC 48MHz clock output on pin 1 is ok. X1 and X2 both have 14.318MHz
    . Checked RTC Crystal, it has 32.768 kHz
    . Checked for shorts on North Bridge, no shorts.
    . Tested all fuses, all are ok
    . Check main power rails for shorts, including 12V CPU input, all ok
    . Checked all Inductors for shorts, no shorts
    . Checked the PCI socket on pin 16, PCICLK 1 for shorts to the Northbridge, no shorts
    . Checked the PCI-e socket on some pins going to the Northbridge, no shorts
    . Check the motherboard using a thermal camera, and i do not see any concerning temperatures
    The Following Signals were Observed using Oscilloscope, or logic probe
    . Tested 3VSB going to the Super IO, it is present
    . Checked for PS_OUT signal on Super IO pin 72, it is pulsing
    . Checked RSMRST# signal, there is nothing, no signal
    . Checked SLP_S3 going to KBC from South Bridge, on pin 71. It is also pulsing like PS_OUT
    . Checked SLP_S5 it is signal LOW
    . Checked PWROK on VRM Controller IC, is it 3.3V
    . Checked EN on VRM Controller IC, is it 5V, and CPU does get warm.
    . Checked PGOOD on VRM IC 1.5V im not sure if this is HIGH or LOW Signal maybe an intermediate state.
    . Checked VCORE_PWOK it is LOW
    . Checked CLKIN on the super IO has No Frequency. Expecting 48Mhz from Clock IC
    . Checked CPU_PG on Super IO No signal
    Thanks for taking the time to read.
  • Fernon@Repair
    MSI mpg b560m bazooka motherboard RSMRST# signal missing
    by Fernon@Repair
    I have MSI mpg b560m bazooka motherboard . this motherboard RSMRST# signal missing . i already reprogram bios but same condition
    My Motherboard this power stages are ok ...but 3vsb voltage have 4.17v (image added)
    VCCRTC ok
    RTCRST# ok
    ATX_5VSB ok
    SIO_3VA ok
    3VDSW ok
    DPWROK ok
    SLP_SUS# ok
    VSB_ENABLE# ok
    5VDUAL ok
    3VSB showing 4.17V
    PCH_1P8_VSB ok
    PCH_VCCIN_AUX ok
    RSMRST# No voltage
    this all voltages are ok but RSMRST# voltage is missing i did try to re program bios and change io but same...
    06-03-2025, 10:49 AM
  • mrugi
    Trying to repair MSI Z270-A PRO motherboard.
    by mrugi
    I have an motherboard that doesn't respond to the power button. It's an MSI Z270-a Pro (ms-7a71). I don't know the history of the board. It looks practically new, with no visible missing components, damage, burns, or PCB damage. I'm completely inexperienced, so please correct me if I'm doing or measuring something incorrectly, or tell me what to measure. I'm trying to learn how to repair stuff in my free time.
    The voltage at the power button is 3.38V.
    ATX 24-pin resistance to ground:
    12V - 4.2k Ohm after a while, after few seconds
    5V -...
    02-24-2026, 07:00 AM
  • CoinCoin88
    Garage door RX unit (Cardin S38C) does not short relay to send opening signal
    by CoinCoin88
    I'm turning to the Badcaps community to help me troubleshoot the radio Rx card from my (old) garage door opener. While I could just ditch that card and replace the whole system, I first would like to understand "why" it suddenly stopped working, because that's just how I am wired...!
    Some basics: the receiver works on a 30.875 Mhz frequency. Yes, I'm aware this is not in use anymore in a looot of places. It does not use any rolling code, it's just a regular dip-switch code that you have to set up on both the receiver and transmitter. The receiver...
    09-15-2025, 03:36 AM
  • howardc64
    by howardc64
    07-24-2025, 05:17 PM
  • reessi
    Acer Alienware Nitro 5 (GH51G LA-L181P Rev: 1C) & Dell Alienware M15 (GDP50 LA-k452P Rev:1) - Both Shorted PCH (SRKMA)!
    by reessi
    Hello:
    I have both these laptops that appeared to have the same fault so I thought I would have a go at replacing the PCH as something to learn, they both are using the same PCH.
    I started on the ACER:
    Up on connecting power no signs of life but current is consumed from the bench power supply and the PCH is hot.
    All the caps on the top of the PCH are showing 0 ohms and the 3.3v rail is shorted.
    I followed the videos from Sorin, Electronics Repair School on Youtube heating from the bottom to install. I practised on around 10 scrap...
    10-29-2024, 11:31 AM
