This is why you don't buy cheap multimeters.
  • b700029
    Banned
    • Sep 2010
    • 640
    #41
    Re: This is why you don't buy cheap multimeters.
    There is no fuse for "10A" jack. To use safely, each measurement can not last for more than 10 seconds, and the interval between each measurement must be more than 15 minutes.
    • Th3_uN1Qu3
      Believe in
      • Jul 2010
      • 6031
      • Romania
      #42
      That's what it says on all meters, including my Uni-T ones which are fused. Never respected that and i haven't gotten a shunt catch fire yet, not sure how it affects accuracy tho. I've actually put 30A fuses in my Uni-Ts instead of 10A to avoid nuisance blowing.
      A working TV? How boring!
      • retiredcaps
        • Apr 2010
        • 9271
        #43
        Originally posted by lti
        My Harbor Freight $3 multimeter
        Apparently, one person thinks it is worth $100 Buy It Now on ebay.
        http://www.ebay.com/itm/110818056416
        Obviously, it didn't sell so he relisted it for $45.
        http://www.ebay.com/itm/110820886299
        --- begin sig file ---
        --- end sig file ---
        • severach
          • Aug 2007
          • 1055
          Originally posted by ebay auction for Cen-Tech DVM
          YOU ARE BIDDING ON A NEW GEN-TECH DIGITAL MULTIMETER NEVER USED IN EXCELLENT SHAPE HAS ON/OFF SWITCH COMES WITH RED &BLACK METER READERS.
          It's Cen-Tech. With spelling like that perhaps he went to the Verizon School of Math and his decimals are off. Could one of those meter readers be Peter the Meter Reader?
          sig files are for morons
          • kaboom
            "Oh, Grouchy!"
            • Jan 2011
            • 2507
            Originally posted by severach
            ...perhaps he went to the Verizon School of Math and his decimals are off...
            Like this?
            "pokemon go... to hell!"
            EOL it...
            All style and no substance.
            guilty,guilty,guilty,guilty!
            guilty of being cheap-made!
            • ratdude747
              Black Sheep
              • Nov 2008
              • 17136
              him:
              me:
              they must be making crack more potent these days...
              sigpic
              (Insert witty quote here)
              • bluto
                • Oct 2007
                • 560
                #47
                Originally posted by kaboom
                Like this?
                At least the place didn't burn. A couple of years ago around these parts, a charter subcontractor managed to burn down a brand new $2.5 million house by drilling into the electrical panel from the outside. It took 6 fire departments to put it out! This is the best link I can find...
                http://www.ksdk.com/news/story.aspx?storyid=88193
                Somewhere else it said the guy worked for 'Sparx' Communications
                  master hoarder
                  • May 2008
                  • 12175
                  • Bulgaria
                  #48
                  After playing a bit more with the probes on my 830D yesterday, I found something very interesting.
                  Up until this point, a short circuit on my 830D would show as 2-3 Ohms (and very rarely 1.8). I though this was just due to my 830D being very cheap - but it's not. Yesterday, I was trying out some spare connectors to see if they can fit in the multimeter plugs so that I could make my own high-current probes (since the original probe wires are obviously too underrated for that). After inserting one of the connectors in 10A jack of the multimeter plug, I selected the 200 Ohm scale and used the red probe (still plugged in its usual place) to see if my connector actually made connection with the multimeter - it did. Not only that, but my multimeter was reading 0.5 Ohms! I though, that can't be right, so I unplugged my black probe, inserted my own connector in the COM plug and measured the resistance again. But once more, the multimeter read 0.5 Ohms. At this point, I pretty much knew what was going on. I swapped the red probe for the black probe, then tested resistance again to my connector in the COM plug... yup, back to 2.2 Ohms.
                  So as it turns out, the wire for my black multimeter probe does actually have about 2 Ohms of resistance. - No wonder it heats up so badly. Also explains why in the past, my multimeter would drop so much voltage when I was trying to measure current. Now I know. Time for new probes.
                  • Agent24
                    I see dead caps
                    • Oct 2007
                    • 5031
                    • New Zealand
                    #49
                    Your original 830D probes are actually still in one piece? Wow. Mine died years ago, so they never had a chance to give me a false reading.
                    -David VanHorn
                    • Krankshaft
                      • Jan 2007
                      • 2328
                      Like this?
                      Do doubt the double insulation on that drill saved the morons life.
                        master hoarder
                        • May 2008
                        • 12175
                        • Bulgaria
                        #51
                        Oh no, of course not. I did fix them (see page 1 or link below):
                        https://www.badcaps.net/forum/showpo...6&postcount=12
                        • LENOVO-A880
                          Not A Bad BIOS
                          • Feb 2014
                          • 79
                          • MALAYSIA
                          #52
                          Fixing DT830D UNI-T DMM
                          First of all, this is a hobby of mine and I'm not a pro where I depend on my equipment. So I have had this cheap and old multimeter to only check fuses, shorts (continuity), Ohm tests, and etc. For me, it doesn't make sense to buy another new multimeter just to repair a $20 residue value monitor or test a faulty transistor. Even $20 would be hard to justify unless I'm trying to fix a several thousand dollar LCD or plasma TV.
                          This DT830D multimeter from China died off a few years ago due to the LCD problem mainly ICL7106 ic. It doesn't work at all now so what I did was I changed 9V battery together with the 200mA fuse (only one) and same thing I get nothing on the LCD display. Finally I found out that the battery block clip +/- terminal has loose contact inside of it and when I gently pulled the negative lead, it appears to come off. I've ordered several pieces of battery block clips and need to resolder it to the UNI-T multimeter board as a replacement to the bad clip.
                          Questions
                          1. What is the suitable temperature that should be used on this kind of circuit board?
                          2. Can I adjust my soldering iron temperature to 250°C for this kind of soldering job?
                          "If you cannot do great things, do small things in a great way."
                          -Napoleon Hill
                          "The chip that functions abnormally will be desoldered, as they say."
                          -Charles Stross
                          "Why is it you're always too small or too tall?"
                          -The Mad Hatter
                          • Per Hansson
                            • Jul 2005
                            • 5895
                            • Sweden
                            #53
                            It does not depend on what PCB you have, it depends on what solder you use.
                            It's usually written in the specs or even on the roll of the solder...
                              • 31178
                              try not to go over 270 or the insulation on the wire will shrink.
                              • LENOVO-A880
                                Not A Bad BIOS
                                • Feb 2014
                                • 79
                                • MALAYSIA
                                #55
                                Does this type of solder wire suitable for soldering on the UNI-T DT830D circuit board?
                                Specifications:
                                -Alloy Composition
                                : Sn63PB37 (63% Tin, 37% Lead)
                                -Melting Point
                                : 183 ~ 193°C
                                -Flux % In Core Wire
                                : 2.0%
                                Solder Name:
                                -KEWEI Sn63Pb37 Flux Core Solder Wire (0.8mm)
                                Country Of Origin:
                                -China
                                -Napoleon Hill
                                -Charles Stross
                                -The Mad Hatter
                                  • 31178
                                  that will do,
                                  but lead-free stuff would be better.
                                  • mariushm
                                    • May 2011
                                    • 3799
                                    #57
                                    That solder is quite good, if it is what it says.
                                    If it's really 63/37 that means it's eutectic...solder will melt or turn to solid within a very narrow temperature range of about 1-2 degrees C around the 183c value.
                                    To solder you actually need to set the temperature of your iron higher, because when you put the iron on the copper on the pcb and you have the wire from the connector there as well, both will pull heat away from the iron tip and the temperature may drop below that 183c temperature and you won't solder reliably.
                                    You adjust the temperature to be hot enough to warm up everything in 2-3 seconds .
                                    1. Strip insulation from the wires of your connector.
                                    2. Tin the wires :
                                    2.1 Set iron temperature to about 220-250c
                                    2.2 Clean the tip from oxides with a paper handkerchief or some napkin, add a tiny bit of solder
                                    2.4 Make contact between the wire and the tip and then on the opposite side, touch the wire with the solder wire. Flux from solder wire will pour and protect the wire, then solder will melt and tin the wire.
                                    2.5 Move the iron tip back and forth on the uninsulated wire end to tin it nicely.
                                    ( this should take no more than 4-5 seconds, otherwise the insulation of the connector will start to melt)
                                    3. Cut a part of the uninsulated wire, leave just enough to be over that copper pad on the pcb
                                    4. Raise iron to about 250-300c , wait to reach that temperature.
                                    5. Put wire over the pad, or shove it through the hole if there's any
                                    6. Solder wire in one hand, iron in the other
                                    7. Put iron tip in such a way that it touches both the connector wire and the copper pad
                                    8. Bring solder wire to the pcb pad, wait to see enough solder flow to make the connection is made, move solder wire away than a second later remove the iron tip.
                                    Job done.
                                    Here's good video showing tinning of wires : https://www.youtube.com/watch?v=0SnOW2VdCTI
                                    Same procedure as I explained it, but since you probably don't have liquid flux, you're using the actual flux in the solder wire instead so that's why I told you to have the solder wire above, to let the flux flow on wire before solder from the wire actually melts.
                                    • selldoor
                                      Slow Learner
                                      • 7870
                                      #58
                                      Originally posted by stj
                                      that will do,
                                      Just wondering why you would say that? ecological/health view?
                                      its more difficult for a newbie to use?
                                        • 31178
                                        better for health,
                                        cheaper (because it's sold by weight, not length.)
                                        better flux than a lot of older solders,
                                        lower resistance.
                                        stronger joints.
                                        the only reason to use lead is if you have a crap iron,
                                        but they guy asked about the temperature to set the iron - so he has decent kit.
                                        incidentally, leaded solder from china should be dirt cheap, because THEY cant use it under the chinese regulations that are more strict than RoHS.
                                        they are just clearing old stock.
                                        • mariushm
                                          • May 2011
                                          • 3799
                                          #60
                                          better for health,
                                          NOT better for health : due to higher melting temperature, lead free solder has stronger fluxes, which are more toxic - the flux smoke hurts you infinitely more than the presence of lead in solder (you don't get lead in your body from soldering, the temperature is not big enough for lead to become "airborn")
                                          NOT cheaper in all cases, at least if you want to get a good lead free solder (the one with 2% silver and/or 0.5-1% copper)
                                          It's debatable. It's not necessarily better, but it's STRONGER, more acid, more toxic for your lungs. It has to be because due to the higher melting temperature of lead free solder, most people keep the soldering irons at much higher temperatures, which gives flux less time to activate and work before it's boiled/evaporated by the iron tip.
                                          As I already said, the flux smokes are much worse than lead free solder fluxes, and since most people don't have a ventilator on their desk, you can safely say lead bases solders will be better.
                                          lower resistance.
                                          stronger joints.
                                          I don't feel like checking, but i doubt in practice it makes a real difference.
                                          If anyone cares to search and compare, he/she can start from here:
                                          https://cdn.badcaps-static.com/pdfs/...26c4cf2bd9.pdf
                                          • asdas09
                                            Temperature to remove chips from motherboard
                                            by asdas09
                                            What temperature with the heat gun should be use to remove large and small chips from the laptop and mobilephones motherboard? My problem is that the chips not easily remove from the motherboard, example 380°C degrees. I don't know if there is a difference with the devices that the temperature is not stable with them even it shows the right temperature, what should it be? I don't know if I should use higher temperature but the risk of destroying other components?
                                            I have device Sugon 202. I'm used also normal flux and rosin flux.
                                            09-12-2023, 12:44 AM
                                          • Dreigas
                                            ISL95880HRTZ desoldering temperature
                                            by Dreigas
                                            I bought from China ISL95880HRTZ (3+1+1 Voltage Regulator with Expanded ICCMAX Register Range Supporting IMVP8 CFL/CNL CPUs) chip, which I think is not the original one, but anyway, I tried to resoldering it with a 380C hot air station. Seems soldering is pretty good, but the laptop doesn't work (it worked before, but still had some problems with power delivery).
                                            Is there any big chance, that they sent me two fake ISL95880HRTZ chips or did I just use too big temperature for desoldering? I will try with another chip, but I can't find any info about the maximum desoldering...
                                            09-13-2024, 10:59 PM
                                          • Rayblaster
                                            HP RP7 RP7800 from 2012/2013 worst fault - has "character"
                                            by Rayblaster
                                            Hello friends, I've got a nice toy to play with - it is an HP RP7800 All-in-one POS system. I got it for free and it has one problem - it turns on very rarely, and just for a few seconds. After that it dies and doesn't come on if I don't leave it unplugged for at least 2 hours. I've repaired motherboards before, this is not my first one, but problem with these types of faults is that everything you check on the board will usually be fine. This is the case for me here.
                                            I dissassembled it completely, and got my hands on the motherboard. Model No. is PIQ67H/Higgins 11047-I 48.3GD02.011....
                                            12-30-2024, 06:28 PM
                                          • jm1234
                                            9V relay temperature 40C
                                            by jm1234
                                            Hi, I'm seeing one 9V relay having temperature 40C on its 9V (primary) side. Does that seem right? I switched 2 relays on that board and the temperature was the same (on the same position), so I'm sure it's not a faulty relay. I measured voltage on that relay and it was 9.5V DC, so that looks good. I don't see any other relay on that board having that kind of temperature and they have 9V on them too.
                                            I thought maybe the transistor that is switching this relay keeps switching on/off, so I also checked for AC and there was almost none: 0.3V using mV range. No steady frequency was shown, but...
                                            05-09-2024, 03:03 AM
                                          • Windows8RTMUser
                                            Repair knowledge for -55c CPU temperature on AMD Ryzen CPUs in bios, the AMD Sideband temperature sensor interface (SB-TSI)
                                            by Windows8RTMUser
                                            Recently I came across an x570 Aorus Elite where the temperature in bios was reporting -55c, i had checked the CPU_TEMP line connected to the IT8688
                                            In my particular case, the SIC line going to the X570 chipset (PM_SIC) was shorted to ground, so far disconnecting the 0 ohm resistors connecting APU_SID and APU_SIC to the chipset has fixed my -55c issue, it seems like -55c is the fallback reading for CPU_TEMP which is just pulled up to VREF on most gigabyte motherboards
                                            I wanted to post this as even the ever-reliable vlab forum was stumped on this issue
                                            tags:...
                                            07-28-2025, 07:26 PM
