This is why you don't buy cheap multimeters.
  • mariushm
    • May 2011
    • 3799
    #81
    Re: This is why you don't buy cheap multimeters.
    Go on eBay and buy some probes, they're 1$ or something like that.
    A whole new 830D is 3-4$ on ebay.
    Those probes are AWG18 when pigs fly. They're more like AWG20 or AWG22, they just have thick insulation to fool you into thinking they're better.
      master hoarder
      • May 2008
      • 12170
      #82
      Originally posted by LENOVO-A880
      Any other ways to repair this kind of probes which always come with bad craftsmanship from the factories?
      Given that new probes cost very little money, it doesn't make much economical sense to fix them. However, I often find it faster to fix my old probes than to buy new ones, so I always end up fixing them up when they need it.
      Here's how:
      Strip the insulation on the connector leads you cut off (that is, strip the top only, and strip until you see the metal connector).
      Take the stripped ends of your probes and solder them to the metal connectors your just stripped.
      Insulate with electrical tape, heat shrink tubing, or hot glue (or all three, if you like ).
      Enjoy!
      Once repaired like this, I suggest you don't use the probes to measure high voltage sources. Other than that, they should work fine.
      • lti
        • May 2011
        • 2547
        Originally posted by momaka
        The second thing you have to know is that the dial on these cheaper meters is... well... cheap. Even if you have it on the 200 Ohm setting, it may not be snapped-on perfectly. You will find that if you move it around just a bit, you may get a good connection and low resistance.
        That's actually what's wrong with the meter I have. Turning the dial slightly can make the resistance vary from 0.5 ohms to 8 ohms with the leads shorted.
          master hoarder
          • May 2008
          • 12170
          #84
          ^ Yeah, it's a bit annoying sometimes. But I am pretty used to it now.
          I just bought a second cheap HF multimeter (actually, I didn't buy it - it was free with any other purchase just like the last one), and it has that problem too, depite being a slightly different build. Same crummy leads, though. They read 1.4 Ohms at best when shorted. But it works otherwise. Just another cheap meter to have for general low-voltage measurements (sometimes, I need several multimeters when I'm working on projects on my breadboard).
          • larrymoencurly
            • Oct 2004
            • 960
            When I get a free Harbor Freight multimeter, I've always picked a model #98099 (yellow on/off switch), but last time I instead got a model #98025 (red on/off switch). When I opened it I thought it was better built because I saw a neon bulb for voltage protection, but it turned out to be a soldered-in fuse. The #98099 instead has a regular 0.5A fuse in a snap-in fuse holder.
              master hoarder
              • May 2008
              • 12170
              #86
              The second one I got is with the red switch. I picked it on purpose, since the first one I got had a yellow switch. Just wanted to see if there was any difference. When I have time / feel like it, I guess I will tear it apart and see it for myself as well.
              • retiredcaps
                • Apr 2010
                • 9271
                #87
                It would be interesting to see the differences from modemhead's pictures at
                http://mrmodemhead.com/blog/gallery/cen-tech-92020-dmm/
                --- begin sig file ---
                --- end sig file ---
                • asdas09
                  Temperature to remove chips from motherboard
                  by asdas09
                  What temperature with the heat gun should be use to remove large and small chips from the laptop and mobilephones motherboard? My problem is that the chips not easily remove from the motherboard, example 380°C degrees. I don't know if there is a difference with the devices that the temperature is not stable with them even it shows the right temperature, what should it be? I don't know if I should use higher temperature but the risk of destroying other components?
                  I have device Sugon 202. I'm used also normal flux and rosin flux.
                  09-12-2023, 12:44 AM
                • Dreigas
                  ISL95880HRTZ desoldering temperature
                  by Dreigas
                  I bought from China ISL95880HRTZ (3+1+1 Voltage Regulator with Expanded ICCMAX Register Range Supporting IMVP8 CFL/CNL CPUs) chip, which I think is not the original one, but anyway, I tried to resoldering it with a 380C hot air station. Seems soldering is pretty good, but the laptop doesn't work (it worked before, but still had some problems with power delivery).
                  Is there any big chance, that they sent me two fake ISL95880HRTZ chips or did I just use too big temperature for desoldering? I will try with another chip, but I can't find any info about the maximum desoldering...
                  09-13-2024, 10:59 PM
                • Rayblaster
                  HP RP7 RP7800 from 2012/2013 worst fault - has "character"
                  by Rayblaster
                  Hello friends, I've got a nice toy to play with - it is an HP RP7800 All-in-one POS system. I got it for free and it has one problem - it turns on very rarely, and just for a few seconds. After that it dies and doesn't come on if I don't leave it unplugged for at least 2 hours. I've repaired motherboards before, this is not my first one, but problem with these types of faults is that everything you check on the board will usually be fine. This is the case for me here.
                  I dissassembled it completely, and got my hands on the motherboard. Model No. is PIQ67H/Higgins 11047-I 48.3GD02.011....
                  12-30-2024, 06:28 PM
                • jm1234
                  9V relay temperature 40C
                  by jm1234
                  Hi, I'm seeing one 9V relay having temperature 40C on its 9V (primary) side. Does that seem right? I switched 2 relays on that board and the temperature was the same (on the same position), so I'm sure it's not a faulty relay. I measured voltage on that relay and it was 9.5V DC, so that looks good. I don't see any other relay on that board having that kind of temperature and they have 9V on them too.
                  I thought maybe the transistor that is switching this relay keeps switching on/off, so I also checked for AC and there was almost none: 0.3V using mV range. No steady frequency was shown, but...
                  05-09-2024, 03:03 AM
                • beetle1303
                  EuropAce EWC 3108 Wine Chiller - Seems like no temperature sensor input
                  by beetle1303
                  Received this dual doors dual temperature control wine chiller with some unusual issues:
                  1) On powered up, all the electronics seemed to be working properly - lights, temperature settings, current temperature, etc, all displayed correctly. But sometimes both zones will get chilled, sometimes upper zone only, and sometimes lower zone only. The temperature displays will show the correct temperature as it chilled (I placed a stand-alone thermometer inside and they compared correctly)
                  2) However, the chilling does not stop at the set temperature.
                  3) When both zones are chilling,...
                  12-04-2020, 08:23 AM
