Temperature to remove chips from motherboard
+ More Options
Posts
  • asdas09
    • May 2023
    • 19
    • Finland
    What temperature with the heat gun should be use to remove large and small chips from the laptop and mobilephones motherboard? My problem is that the chips not easily remove from the motherboard, example 380°C degrees. I don't know if there is a difference with the devices that the temperature is not stable with them even it shows the right temperature, what should it be? I don't know if I should use higher temperature but the risk of destroying other components?
    I have device Sugon 202. I'm used also normal flux and rosin flux.
