This is why you don't buy cheap multimeters.
  • retiredcaps
    • Apr 2010
    • 9271
    Re: This is why you don't buy cheap multimeters.
    Originally posted by momaka
    What were you trying to measure? The explosion does look pretty spectacular.
    Details at
    http://www.eevblog.com/forum/index.php?topic=2585.0
    A few times I tried to measure DC on the AC mains - again, no explosions. Perhaps I've been lucky?
    See the very popular $4 or less Harbour Freight multimeter on Fluke's test and safety promotional video.
    http://assets.fluke.com/video-MULTI/...afety_lab.html
    The above multimeter is shown near the end of the video. Unfortunately, there is no timestamp that I can see on where it starts, but you get to see the flames in slow motion.
    I think the Harbour Freight multimeter is set to 200 ohms when it is fed with 300+ DC volts.
    --- begin sig file ---
    --- end sig file ---
    • severach
      • Aug 2007
      • 1055
      The same way everyone ruins their first meter:
      "So this plug can supply 15 amps, eh? I can check that with this amp scale."
      Then you learn that measuring amps is not like measuring volts.
      sig files are for morons
        I can't remember, might have been some high current or voltage. I was just shocked when smoke started pouring out the back of it. It might have been a manufacturing defect because I've still got one of those meters and it's survived many more abuses.
        Originally posted by Retiredcaps
        Did it look like this? I got this one free, but not working.
        Nope, it was this one: http://www.rapidonline.com/Tools-Equ...st-leads-31052
        • 999999999
          • Sep 2006
          • 774
          Sometimes the problem is poor knob contacts, you might try popping it off and cleaning the areas.
          • Agent24
            I see dead caps
            • Oct 2007
            • 4950
            • New Zealand
            Well, since a couple weeks ago it started working erratically on resistance. More specifically, on the low ranges it reads in the hundreds of ohms even if there's a short, then it slowly counts down to the real value...
            I noticed a similar problem (though not as bad) with my meter (it's one of the better-built 830B types)
            Turned out to be dirty contacts on the rotary switch.
            I cleaned the copper springs on the knob and the gold contacts on the PCB and haven't had the problem since.
            -David VanHorn
            • Th3_uN1Qu3
              Believe in
              • Jul 2010
              • 6031
              #26
              Well, since then, i have dropped it (a few months ago) and it now displays entirely rubbish. So it's definitely not the range switch which is the problem on mine.
              A working TV? How boring!
              • Agent24
                I see dead caps
                • Oct 2007
                • 4950
                • New Zealand
                #27
                Maybe the spring-contacts went out of alignment from the drop? They just sit there on a little plastic ledge (Though you probably already know and have checked that!)
                -David VanHorn
                • PeteS in CA
                  • Aug 2005
                  • 3579
                  • USA, Unsure of Planet
                  #28
                  This is normal for the 830B and part of it is due to the crummy probes it comes with. With good probes it should read 0.6 to 0.9 ohms when shorted.
                  This is a prime suspect - both the probes (either end) - and the banana sockets into which they plug. I'm spoiled rotten - HP 73As are the "worst" DMMs in my test area, plus some Fluke 187s and some top-end Agilent handhelds. When you're trying to set voltages in the 4000 volt range to +/- 1 volt, a +/-1%, 3-digit meter is not adequate. I'm not the paying for the meters I use, while you guys are. Still, cheap @#$% meters will cost you more in the long run - in $$ and time wasted - than a Fluke 10, 20, 70 or 80 series DMM (also, look into Extech, which seems less expensive, but still decent quality). This is in the US ... not sure what's commonly available in EuroLand and Asia.
                  PeteS in CA
                  • Th3_uN1Qu3
                    Believe in
                    • Jul 2010
                    • 6031
                    #29
                    In EU you can find Uni-T meters. Uni-T makes pretty good stuff. From bottom-of-the-barrel to Fluke level accuracy, they got everything covered. What you pay for is what you get. Uni-T is from China so no problems getting them in Asia either.
                    • retiredcaps
                      • Apr 2010
                      • 9271
                      #30
                      Since my 99 cent 830 variant from ebay arrived DOA back in June 2010, these probes were NEVER used and have been put away. I took them out last week due to some of these threads and it literally fell apart in my hand.
                      Evidence.
                      And yes PeteS, I have much better quality name brand multimeters now.
                      • retiredcaps
                        • Apr 2010
                        • 9271
                        #31
                        I'm thinking of getting a low end one (at the right price) just to see myself first hand what they are like. I have read most of the reviews here and at eevblog.
                        • mockingbird
                          • Dec 2008
                          • 5484
                          #32
                          I have a DM210 and DM350, two real low-end meters... The DM210 works fine and I have had it now for a while... The DM350 I got recently. I turned it on and it was giving me very erratic readings. I opened it up, just to peek inside, and then I put it back together. I don't know what I did, but nothing comes up at all now. The LCD has some really weird connection, like some sort of plastic block with black things sandwiched in-between that somehow links it to the PCB... Does anyone know how that works?
                          Oh yea, the difference between them is that the 210 has only voltage and Ohm, and the 350 has a diode finction, so I have been using the 210 as a glorified battery tester.
                          • retiredcaps
                            • Apr 2010
                            • 9271
                            #33
                            Post some pictures please. I'm always curious to see the insides of any meter.
                            • mockingbird
                              • Dec 2008
                              • 5484
                              #34
                              And here is the PCB (Full size 300+ KB version is attached to this post)L
                              Fuse is ok... Could it be the custom IC or you think it's a diode or transistor?
                              • retiredcaps
                                • Apr 2010
                                • 9271
                                #35
                                That black/pink thing is a zebra stripe.
                                http://www.repairfaq.org/REPAIR/F_au...#AUDIOFAQC_012
                                For those curious, I figured out these are Sperry brand multimeters through some searching. Sperry DM-210A and DM350A.
                                • retiredcaps
                                  • Apr 2010
                                  • 9271
                                  #36
                                  If you are talking about that black circular blob, that is a chip on board (COB). It is probably a ICL7106
                                  http://www.hobby-hour.com/electronics/icl7106.php
                                  • mockingbird
                                    • Dec 2008
                                    • 5484
                                    #37
                                    Thanks for the model... Yea, I knew it was the IC, I was asking if he thought the IC was the culprit or maybe a diode or resistor was shot. I've read about transplanting these ICs, but like Unique said, for a $5 DMM... I dunno.
                                      master hoarder
                                      • May 2008
                                      • 12170
                                      #38
                                      Yep, cheap probes are cheap.
                                      I was measuring some current last week with my 830D. After measuring about 1.7A for over 2 minutes, the wires on my probes were actually warm to the touch!
                                      ... and to think the meter can measure up to 10A. I bet the probes will melt at 5A.
                                      • Th3_uN1Qu3
                                        Believe in
                                        • Jul 2010
                                        • 6031
                                        #39
                                        4A actually. Melted a few myself.
                                          master hoarder
                                          • May 2008
                                          • 12170
                                          #40
                                          No wonder they don't put fuses for the 10A current setting - it's just not needed when the probes are acting as a fuse .
                                          • asdas09
                                            Temperature to remove chips from motherboard
                                            by asdas09
                                            What temperature with the heat gun should be use to remove large and small chips from the laptop and mobilephones motherboard? My problem is that the chips not easily remove from the motherboard, example 380°C degrees. I don't know if there is a difference with the devices that the temperature is not stable with them even it shows the right temperature, what should it be? I don't know if I should use higher temperature but the risk of destroying other components?
                                            I have device Sugon 202. I'm used also normal flux and rosin flux.
                                            09-12-2023, 12:44 AM
                                          • Dreigas
                                            ISL95880HRTZ desoldering temperature
                                            by Dreigas
                                            I bought from China ISL95880HRTZ (3+1+1 Voltage Regulator with Expanded ICCMAX Register Range Supporting IMVP8 CFL/CNL CPUs) chip, which I think is not the original one, but anyway, I tried to resoldering it with a 380C hot air station. Seems soldering is pretty good, but the laptop doesn't work (it worked before, but still had some problems with power delivery).
                                            Is there any big chance, that they sent me two fake ISL95880HRTZ chips or did I just use too big temperature for desoldering? I will try with another chip, but I can't find any info about the maximum desoldering...
                                            09-13-2024, 10:59 PM
                                          • Rayblaster
                                            HP RP7 RP7800 from 2012/2013 worst fault - has "character"
                                            by Rayblaster
                                            Hello friends, I've got a nice toy to play with - it is an HP RP7800 All-in-one POS system. I got it for free and it has one problem - it turns on very rarely, and just for a few seconds. After that it dies and doesn't come on if I don't leave it unplugged for at least 2 hours. I've repaired motherboards before, this is not my first one, but problem with these types of faults is that everything you check on the board will usually be fine. This is the case for me here.
                                            I dissassembled it completely, and got my hands on the motherboard. Model No. is PIQ67H/Higgins 11047-I 48.3GD02.011....
                                            12-30-2024, 06:28 PM
                                          • jm1234
                                            9V relay temperature 40C
                                            by jm1234
                                            Hi, I'm seeing one 9V relay having temperature 40C on its 9V (primary) side. Does that seem right? I switched 2 relays on that board and the temperature was the same (on the same position), so I'm sure it's not a faulty relay. I measured voltage on that relay and it was 9.5V DC, so that looks good. I don't see any other relay on that board having that kind of temperature and they have 9V on them too.
                                            I thought maybe the transistor that is switching this relay keeps switching on/off, so I also checked for AC and there was almost none: 0.3V using mV range. No steady frequency was shown, but...
                                            05-09-2024, 03:03 AM
                                          • beetle1303
                                            EuropAce EWC 3108 Wine Chiller - Seems like no temperature sensor input
                                            by beetle1303
                                            Received this dual doors dual temperature control wine chiller with some unusual issues:
                                            1) On powered up, all the electronics seemed to be working properly - lights, temperature settings, current temperature, etc, all displayed correctly. But sometimes both zones will get chilled, sometimes upper zone only, and sometimes lower zone only. The temperature displays will show the correct temperature as it chilled (I placed a stand-alone thermometer inside and they compared correctly)
                                            2) However, the chilling does not stop at the set temperature.
                                            3) When both zones are chilling,...
                                            12-04-2020, 08:23 AM
