ISL95880HRTZ desoldering temperature
  • Dreigas
    Hobbyist
    • Feb 2023
    • 36
    • Lithuania
    • IT, robotics, fishing, camping
    I bought from China ISL95880HRTZ (3+1+1 Voltage Regulator with Expanded ICCMAX Register Range Supporting IMVP8 CFL/CNL CPUs) chip, which I think is not the original one, but anyway, I tried to resoldering it with a 380C hot air station. Seems soldering is pretty good, but the laptop doesn't work (it worked before, but still had some problems with power delivery).
    Is there any big chance, that they sent me two fake ISL95880HRTZ chips or did I just use too big temperature for desoldering? I will try with another chip, but I can't find any info about the maximum desoldering temperature in the datasheet for this chip. Which temperature is safe for most chips like this?
    Maybe anyone knows? Or have some idea?
  • CapLeaker
    Leaking Member
    • Dec 2014
    • 8724
    I've ordered IC's from reputable sellers and I still got a dud here and there. I am not so worried about the 380C rather the time you blasted it with at that temperature. Then it also depends on if there was a preheat on the bottom of the board or not and other things.
    I usually warm the board and surroundings up, then I hit the chip on 380C and it comes of rather fast. Also depends on chip size and nozzle you use.
    • acedogblast
      by acedogblast
      11-02-2024, 05:13 PM
    • DynaxSC
      ASRock B650M PRO RS - BIOS CHIP 25Q256JW BLOCKED BY STATUS REGISTERS
      by DynaxSC
      Hi
      I have then desoldered the chip, backupped the contents, and tried to earease the chip in order to program stock image, but the chip is locked by status registers SREG2 (TB) and SREG6...
      08-04-2025, 12:20 PM
    • Berun
      HP EliteDesk 800 G6 mini - BIOS Chip (GD25B127DSIG) replacement after epic fail :D
      by Berun
      Hello All,
      I tried to read the the BIOs chip(GD25B127DSIG) on the mainbord of an HP EliteDesk 800 G6 mini, because the BIOs had an Admin Lock and I got the "HP Endpoint Security Problem" Screen at every startup which is not very useful when I want to use the PC as a Compute Unit for my home media system somewhere in the cellar, so it should perform a restart without any interactions.
      I only have the CH341APro Programmer available and did the 3V hardware Mod on it before I tried to read the BIOS chip.
      I read the Chip on board 8 times (with power...
      04-09-2026, 06:24 AM
    • chonkyrabbit
      Need help disassembling xx30 thinkpad battery BMS chip firmware
      by chonkyrabbit
      Hi there,
      I need some help reverse engineering a BMS chip from a battery for an xx30 thinkpad. The Laptop uses a challenge-response type of system to verify if a battery is genuine:
      The laptop writes four bytes to 0x3C and then reads 0x3C. The battery responds with "Lenovo JapanXXXX", with the Xs corresponding to four response bytes. For example "0xDC 0x42 0x5B 0x82" to BMS => "Lenovo Japan0x9F 0x76 0x97 0x2E" from BMS.
      What I know so far:
      • It's an 51F51 BMS chip based on the R2J24020F group. Karosium has already figured out how to dump
      01-21-2026, 10:32 AM
    • BMCappelletti
      Asus Chromebox CN62 - wrong chip put on BIOS reader
      by BMCappelletti
      Long story short:
      - dad converted Asus Chromebox CN62 into Windows compatible, with mrchromebox BIOS, years and years ago
      - gave the computer to his son a couple years later
      - son now decided to revert it to Chrome OS, to sell it as original (re-writing BIOS with the backup one created by his dad)
      - too lazy to remove the board from the case, thought a voltage regulator was the BIOS chip (you know... it has 8 legs)
      (seems like the story was not that short)
      He used alligator clips to read the chip. No luck reading it. Removed chip and placed on a SOC-8...
      01-08-2025, 07:27 PM
