The ghetto mod thread
This is a sticky topic.
  • eccerr0r
    Solder Sloth
    • Nov 2012
    • 8711
    Re: The ghetto mod thread
    Fun with hot melt glue...
    • Drack
      Yup it's me
      • Nov 2016
      • 297
      • Venezuela
      #462
      Yes lol, at least is not dangerous, just ugly...
      • eccerr0r
        Solder Sloth
        • Nov 2012
        • 8711
        ugly is in the eye of the beholder, hot melt glue is a staple of ghetto!
          master hoarder
          • May 2008
          • 12175
          #464
          Originally posted by Drack
          https://www.badcaps.net/forum/attach...1&d=1544304317
          in reality you cant actually see the foam unless you get very close
          This actually looks pretty good. Hope you don't mind if I copy your idea. I need to mount a fan on a PC case the same way (it's a very old case with no exhaust or intake fans anywhere other than the PSU fan).
          here you can see the guetto mounted fan using a molex conector cutted from a cd drive and blue leds
          more details later
          Now that is 100% proper ghetto!
          Cool PC, by the way. If I am not mistaken that PSU is a YoungYear / Apevia / Aspire unit. Those green sleeved cables should be UV-reactive - i.e. if you add ultra-violet lighting in the case, it will make those cables and their connectors glow too.
          Good overclock on that C2D CPU too!
          Usually yes. But if you apply it carefully without pulling any strings from it, you can actually make it look pretty well. I do it around the cables of the probes of my cheap HF multimeters to prevent the cables from twisting and breaking. It looks almost like I have transparent sleeves on them. Eventually the glue does crack as I use them. But then all I have to do is re-heat the glue again and everything looks normal again.
            • 31293
            no, i hate re-melt wax.
            for me, a pack of epoxy and a tube of UHU/Bostik clear adhesive is the almost universal fix.
            • eccerr0r
              Solder Sloth
              • Nov 2012
              • 8711
              Recently after trying hot melt glue (they're thermoplastic, not paraffin) I have a decision to use between hot melt vs epoxy... I like being able to reuse/repair hot melt where epoxy is pretty much set in stone after it sets.
              Basically if it has to deal with any sort of heat, epoxy is used. If not, then hot melt glue.
              On the other hand, is epoxy or hot melt glue cheaper per volume if I need to use it as potting material?
              • Drack
                Yup it's me
                • Nov 2016
                • 297
                • Venezuela
                #467
                Thanks, yes it's a nice way to mount a fan on a drive bay.
                Actually I don't think that PSU is made by apevia, is not that good but not near as bad as most apevia I have seen
                This is the PSU, actually you posted a couple times on that thread
                https://www.badcaps.net/forum/showthread.php?t=58330
                From what I saw is a topower or at least based on the design
                Look
                https://www.badcaps.net/forum/showpo...postcount=1931
                He said something about leadman but I don't think they can make something decent lol
                  master hoarder
                  • May 2008
                  • 12175
                  #468
                  Ah you're right. I confused your thread with another one:
                  https://www.badcaps.net/forum/showthread.php?t=73043
                  Look
                  Yeah, he said that only the last batch of Topower PSUs (before Topower seized to exist) were made by Leadman and not Topower. Meanwhile, it's Zumax that was made by Topower. So looking at how close that Zumax PSU is to yours, you probably indeed have a Topower unit.
                  • RJARRRPCGP
                    • Jul 2004
                    • 6304
                    Originally posted by Dan81
                    With 2GB of RAM I felt like Vista/7 is too much for the machine so the best choice was XP (besides Linux)
                    qft
                    ASRock B550 PG Velocita
                    Ryzen 9 "Vermeer" 5900X
                    Arc A770 16 GB
                    eVGA Supernova G3 750W
                    Alienware AW3423DWF OLED
                    • PCTechnics
                      • Sep 2013
                      • 30
                      • Argentina
                      #470
                      No more overheating for this TP-LINK Archer ADSL/Wi-Fi Dual Band modem router
                      • Agent24
                        I see dead caps
                        • Oct 2007
                        • 5095
                        • New Zealand
                        #471
                        Not until that dust catches fire, anyway!
                        -David VanHorn
                          master hoarder
                          • May 2008
                          • 12175
                          #472
                          Haha!
                          Looks like that fan's been running for a long time in there now.
                          • RukyCon
                            A Fake Rubycon
                            • Jan 2017
                            • 816
                            Here is a test board i made of a copper-dot PCB.......
                            It may not look too bad but the bottom is where the 'fun' is.
                            As you can see, the soldering looks like it was done by someone who did not know what they were doing.
                            Note; I'm usually better than this (at least i hope i am) but this was a case where i wanted to get it done ASAP even if it meant cutting a few corners on soldering (which i usually don't do). This will not be going into use.
                            BTW: can anyone guess what this board is doing.
                            I'm not a expert, I'm just doing my best.
                            • eccerr0r
                              Solder Sloth
                              • Nov 2012
                              • 8711
                              Not enough light in picture
                              i've done worse i think
                              looks like a capacitive dropper power supply
                              • PCTechnics
                                • Sep 2013
                                • 30
                                • Argentina
                                #475
                                Haha!
                                Hahahaha, 6 years running, a good old Sunon MagLev fan oh and the mod is not just the cooler or the dust only, 4 aluminium heatsinks added made from a southbridge HS fixed with hot glue like it should be for a proper mod )
                                • RukyCon
                                  A Fake Rubycon
                                  • Jan 2017
                                  • 816
                                  Here is a brighter image of the underside. (i thought the top side photo looked ok despite it being darker)
                                  https://www.badcaps.net/forum/attach...1&d=1545440608
                                  I probably should have been a bit more specific with that last line (maybe some along the lines of 'what is the circuit powering' or something like that, oh well).
                                    • 31293
                                    it's not really ghetto, it's how everything used to be done, that and with stripboard.
                                    the chinese even sell a deluxe variant of that board, double-sided through-hole plated fiberglass!!
                                    • eccerr0r
                                      Solder Sloth
                                      • Nov 2012
                                      • 8711
                                      Yeah the radio shack copper ringed perfboard is pretty crappy (FR2 and not plated through). Veroboard is more sturdy but requires careful planning else a lot of cuts are needed.
                                      The chinese plated through, FR4 double sided copper ringed perfboard is indeed the deluxe bee's knees ... though I would really rather have a real PCB done, cutting veroboard or adding wire links is a major PITA.
                                      This I did just to play with capacitive droppers... crappy soldering. That cold joint soldered LED is going to disconnect and the electrolytic capacitor will blow up
                                      Oh... and do notice I reused this board. I think I used this board for something else, then ripped all the components out and built this on it. I wonder when it comes time for me to disassemble this and build something else
                                      • Agent24
                                        I see dead caps
                                        • Oct 2007
                                        • 5095
                                        • New Zealand
                                        #479
                                        Speaking of that, does anyone on eBay sell double-sided protoboard without PTH? I wanted some a while ago where I would have had to drill out the plating from about 80 holes...
                                        -David VanHorn
                                        • eccerr0r
                                          Solder Sloth
                                          • Nov 2012
                                          • 8711
                                          Not sure, honestly I hate perfboard. If the board design is complicated at all, I would rather do a homemade single sided where tracks are only where I want it to be...
                                          I think the most complicated no-link perfboard design I've put together was a small DDS, and "never again!" *sigh* Then again part of the problem is that I was reducing the BOM to the parts I had on hand... having to use two 10K resistors instead of a 20K complicated things.
                                          Here's a piece of double sided perfboard with PTH and GOLD PLATING ?!?!? (BTW, other side looks the same) ... I do NOT like.
