Sony xbr65x900c sound yes, no backlight or image.
  • Diah
    • Feb 2013
    • 6390
    Re: Sony xbr65x900c sound yes, no backlight or image.
    if it read zero ( nothings ) at the opposite way measure try it.
      • 12206
      • U.S.
      #122
      yes 850, switch leads and it's 1, like most diodes, read in diode mode, most standard diodes I read are usually 5xx or close to it.
      • Diah
        • Feb 2013
        • 6390
        did yours meter read 1 when there are nothings connect to the probe at this diode mode ???
          • 12206
          • U.S.
          #124
          Yes it does.
          • Diah
            • Feb 2013
            • 6390
            maybe its L not 1 LOL
              • 12206
              • U.S.
              #126
              Lol
                • 12206
                • U.S.
                #127
                Startin to think I'll need a hammer to fix this one.
                  • 12206
                  • U.S.
                  #128
                  Is 1n4732 ok to replace 1n4732a and nz4v7d I wonder?
                  • Diah
                    • Feb 2013
                    • 6390
                    if with nothngs on probe read L or 1 what ever.. i think yours original zener read same or ?
                      • 12206
                      • U.S.
                      #130
                      Yes the old one reads the same as the new one, 850 and 1 in reverse.
                      • Diah
                        • Feb 2013
                        • 6390
                        did you messure other at the pack u bought all read 850 ?
                          • 12206
                          • U.S.
                          #132
                          Read all 20 of the 1n4732, all read around 850, read about 40 of the others all read about the same 840 to 860 or so, gave up at that point, there is 200 zeners in all, from 1n4728 to 1n4737.
                          • Diah
                            • Feb 2013
                            • 6390
                            i would put the original back. and the way you did only cap 220 change it to 2 of 110uf or 3 of 78uf.. it may now the currents low amp. dive in your scrap and look if you find main caps
                              • 12206
                              • U.S.
                              #134
                              Ok, I'mado it.
                                • 12206
                                • U.S.
                                #135
                                Thinking about using two of these three: 450v 160uf, 450v 47uf and 400v 180uf, looks like closest match is 450v 47uf and 400v 180uf.
                                • Diah
                                  • Feb 2013
                                  • 6390
                                  should the 2 botth same value so use 2 of 450V 160uf
                                    • 12206
                                    • U.S.
                                    #137
                                    Well I don't have two that match in the whole mess, guess I'll have to buy some, will two 450v 110 or 120uf be ok for permanent replacement? thanks.
                                    • Diah
                                      • Feb 2013
                                      • 6390
                                      2X 110uf 570V or 500V and above
                                        • 12206
                                        • U.S.
                                        #139
                                        Ok, thanks, did anyone measure one of these zener diodes 1n4728 thru 1n4737? still not sure if I got a bad batch, they all read 840 to about 860.
                                          • 12206
                                          • U.S.
                                          #140
                                          None, nobody has a zener 1n4728, 1n4729, 1n4730, 1n4731, 1n4732, 1n4733, 1n4734, 1n4735, 1n4736, or 1n4737, they can test in diode mode??
