Sony xbr65x900c sound yes, no backlight or image.
    • 12206
    • U.S.
    #41
    Re: Sony xbr65x900c sound yes, no backlight or image.
    Took 1 cap out, tested board on the bench, got 167 on main filter cap with just power connected, jumped 5 and 7 stby-poweron, filter cap only rose to 274, isn't that way too low or is it only partially on at that point?
    • Diah
      • Feb 2013
      • 6392
      sound good.. did you messured any voltage on the socket ?
        • 12206
        • U.S.
        #43
        Yes, the 12 volt pins are still 0, still have zener 909 reading short.
        • Diah
          • Feb 2013
          • 6392
          Yes, the 12 volt pins are still 0.
          did you measured the 12V on the socket with references the black probe on the COLD ( secondary ) area chassis ??
            • 12206
            • U.S.
            #45
            For ground I used the ground screw holder thats metal labeled gp4 on the board.
              • 12206
              • U.S.
              #46
              Still wondering why ZD909 reads short in circuit and none of the others do??
              • Diah
                • Feb 2013
                • 6392
                but out of the board it read correct... right?... did you searched on the ic spec close to the zener
                  • 12206
                  • U.S.
                  #48
                  Yes, will retrieve data sheet, thanks.
                    • 12206
                    • U.S.
                    #49
                    It's a a6069h, I think this is the equivalent: https://datasheetspdf.com/datasheet/STR-A6069H.html
                      • 12206
                      • U.S.
                      #50
                      Can I test that in circuit? thanks.
                      • Diah
                        • Feb 2013
                        • 6392
                        its okay, as you have standby viltage
                          • 12206
                          • U.S.
                          #52
                          Thats a relief, don't have to deal with that dam thing, thanks.
                            • 12206
                            • U.S.
                            #53
                            What is a puzzle is that zd909 did not test short in circuit til after the caps blew??
                            • R_J
                              • 9551
                              Is ZD909 across R907A/R907B? I suspect those are the source resistors for the ic's internal mosfet and are usually around 1Ω or less
                                • 12206
                                • U.S.
                                #55
                                Thanks for reply, yes it is across, both are at 2.2 ohms. They both continually beep in diode mode like a fuse does.
                                  • 12206
                                  • U.S.
                                  #56
                                  Of all the little resistors on underside theres 6 that continually beep. The rest don't.
                                  • Diah
                                    • Feb 2013
                                    • 6392
                                    i still think you have open circuit some where.. lets do this beside the jumpers you did STBY3.3V with Power_on, put another jumper between STBY3.3V and BL_ON then measure if you have any voltage over the secondary area not only the socket.
                                      • 12206
                                      • U.S.
                                      #58
                                      I think your right Diah, with those 3 jumped I have 275 v on main filter cap, I checked the 4 electrolytic caps right by the connector but there's 0 volts on all of them, does that make sense? thanks.
                                        • 12206
                                        • U.S.
                                        #59
                                        Still no 12 v, strange because I'm pretty sure I measured once and all the 12's were there with everything hooked up, right after I replaced the blown caps.
                                        • vinceroger69
                                          • Mar 2012
                                          • 6714
                                          #60
                                          on the psu secondary side the 3amp resistor type fuse i guess you have checked that?
