Sony xbr65x900c sound yes, no backlight or image.
    • 12330
    • U.S.
    #41
    Re: Sony xbr65x900c sound yes, no backlight or image.
    Took 1 cap out, tested board on the bench, got 167 on main filter cap with just power connected, jumped 5 and 7 stby-poweron, filter cap only rose to 274, isn't that way too low or is it only partially on at that point?
    • Diah
      • Feb 2013
      • 6580
      sound good.. did you messured any voltage on the socket ?
        • 12330
        • U.S.
        #43
        Yes, the 12 volt pins are still 0, still have zener 909 reading short.
        • Diah
          • Feb 2013
          • 6580
          Yes, the 12 volt pins are still 0.
          did you measured the 12V on the socket with references the black probe on the COLD ( secondary ) area chassis ??
            • 12330
            • U.S.
            #45
            For ground I used the ground screw holder thats metal labeled gp4 on the board.
              • 12330
              • U.S.
              #46
              Still wondering why ZD909 reads short in circuit and none of the others do??
              • Diah
                • Feb 2013
                • 6580
                but out of the board it read correct... right?... did you searched on the ic spec close to the zener
                  • 12330
                  • U.S.
                  #48
                  Yes, will retrieve data sheet, thanks.
                    • 12330
                    • U.S.
                    #49
                    It's a a6069h, I think this is the equivalent: https://datasheetspdf.com/datasheet/STR-A6069H.html
                      • 12330
                      • U.S.
                      #50
                      Can I test that in circuit? thanks.
                      • Diah
                        • Feb 2013
                        • 6580
                        its okay, as you have standby viltage
                          • 12330
                          • U.S.
                          #52
                          Thats a relief, don't have to deal with that dam thing, thanks.
                            • 12330
                            • U.S.
                            #53
                            What is a puzzle is that zd909 did not test short in circuit til after the caps blew??
                            • R_J
                              • 9624
                              Is ZD909 across R907A/R907B? I suspect those are the source resistors for the ic's internal mosfet and are usually around 1Ω or less
                                • 12330
                                • U.S.
                                #55
                                Thanks for reply, yes it is across, both are at 2.2 ohms. They both continually beep in diode mode like a fuse does.
                                  • 12330
                                  • U.S.
                                  #56
                                  Of all the little resistors on underside theres 6 that continually beep. The rest don't.
                                  • Diah
                                    • Feb 2013
                                    • 6580
                                    i still think you have open circuit some where.. lets do this beside the jumpers you did STBY3.3V with Power_on, put another jumper between STBY3.3V and BL_ON then measure if you have any voltage over the secondary area not only the socket.
                                      • 12330
                                      • U.S.
                                      #58
                                      I think your right Diah, with those 3 jumped I have 275 v on main filter cap, I checked the 4 electrolytic caps right by the connector but there's 0 volts on all of them, does that make sense? thanks.
                                        • 12330
                                        • U.S.
                                        #59
                                        Still no 12 v, strange because I'm pretty sure I measured once and all the 12's were there with everything hooked up, right after I replaced the blown caps.
                                        • vinceroger69
                                          • Mar 2012
                                          • 6714
                                          #60
                                          on the psu secondary side the 3amp resistor type fuse i guess you have checked that?
                                          • domix
                                            Sony KD - 65XF9005 - No image, sound OK
                                            by domix
                                            at tv KD - 65XF9005 i have a problem.
                                            Afrer a coupe of minutes (10-30) i got black screen, no image. But i have sound.
                                            is this a common problem for this tv?
                                            i attached pictures of inside. Supply board looks okey, no blowed caps....
                                            07-21-2025, 06:37 AM
                                          • rimwall
                                            Sony KD-65x7500D - double image - Tcon or Panel?
                                            by rimwall
                                            This TV was showing a fine image and pulsing with a partial double image (offset vertically) every few seconds. I taped 8 clock pins on one ribbon cable from the Tcon to the panel. It stopped the double image, but some pulsing in intensity was still visible. I then taped another 8 clock pins on the same ribbon cable and the image is now ‘fixed’. Although I understand this results in some loss of resolution, presumably because the clock signal degrades as it passes horizontally across the screen.
                                            I am wondering - do these symptoms and ‘fix’ mean that it’s a Tcon fault or...
                                            11-18-2025, 02:09 AM
                                          • ChaosLegionnaire
                                            by ChaosLegionnaire
                                            09-13-2022, 09:02 AM
                                          • shahnld
                                            Sony kdl 65xg9505 green amber blinking
                                            by shahnld
                                            Good Day.
                                            I just replaced tcon on my sony kdl 65xg9505 and getting green amber leds blinking. all voltages are ok according to working sequence.
                                            i downloaded firmware from sony and there is no .pkg fike.. after extracting it gives another file which contains multiple files like inf, payload.bin and 3, 4 other files. i just did that usb but did not worked. anyone knows anything how to do it..?
                                            green amber blinking stops after while and then starts again. tv responds to remote control on off etc. before installing new tcon backlite was coming on without backlite...
                                            01-03-2024, 03:05 PM
                                          • alegatorul
                                            sony bravia kdl-43w756c, no power, no sound
                                            by alegatorul
                                            the charger brick has 19,2-19,3 vcc
                                            changed the inverter board same result.
                                            where should i start?
                                            cheers
                                            11-15-2025, 10:00 AM
