Un50mu6070 Mainboard issue
  • lotas
    • Jan 2016
    • 4459
    • Russia
    #81
    Re: Un50mu6070 Mainboard issue
    For this series, the header (the first bytes) in the Standby power firmware just flies off. And at the same time, even the indicator will not light, verified.
    • lotas
      • Jan 2016
      • 4459
      • Russia
      #82
      Originally posted by crym1111
      again, no...
      Try putting SR first, and then write Dump.
      • Diah
        • Feb 2013
        • 6343
        status reg make conflict always... using the CH341A programmer software V1.4 will be fine... the spi will not change first secor.
        • Davi.p
          • Sep 2009
          • 4266
          • Italy - Milan
          #84
          Hijacking other one's thread does make time wasting from the involved users.. Open your thread please...
          • crym1111
            • Feb 2022
            • 20
            • Romania
            #85
            Hi Lotas,
            For xxMU6xxx series you have to set on the programmer "STATUS REGISTERS"
            0x88, 0x42.
            For xxKU6xxx series is the same rule and the same set for SR (0x88 and 0x42)...?
            Kind regards
            • lotas
              • Jan 2016
              • 4459
              • Russia
              #86
              Hi Lotas,
              0x88, 0x42.
              Kind regards
              Hello, in "MU" the cap in the 25Q40 firmware often flies and so that it does not fly off the first time it is turned on and these SRs (0x88 and 0x42) are put, I don't remember about "KU".
              • crym1111
                • Feb 2022
                • 20
                • Romania
                #87
                Because when i read 25Q40 from KU6xxx series found SR 1 set 0XAC and SR 2 set 0x2; in other case i found SR 1 set as 0x2C and SR 2 0x2.
                Could somebody to confirm how must be set SR for KU series...?
                Regards
                • alltvrepairs
                  • Jan 2014
                  • 211
                  • Malta
                  #88
                  Am following this thread as had issues on MU and KU series. I use the EZP2010 programmer and use new chips as far as possible. On a recent board the issue I managed to fix a no display problem replacing the upper IC 25Q80 (sorry I don't have the IC number here) by copying from a similar working board. I wasn't aware of any protection bits so maybe either I was lucky. After each read and copy I always verify the copy.
                  I have kept copies of both ICs as well if you need.
                  • Techplayer
                    • Apr 2022
                    • 7
                    I have a similar issue with a UN65MU650DFXZA. The tv presents the same symptoms as the original post by Storyteller12. Does anyone has a working bin file for this tv model? I am attaching the original bin file.
                    • lotas
                      • Jan 2016
                      • 4459
                      • Russia
                      #90
                      Someone else's, working firmware (Dump) will not help you, here's your restored one.
                      • Techplayer
                        • Apr 2022
                        • 7
                        Thank you. I will test it and let you know the result.
                        • Techplayer
                          • Apr 2022
                          • 7
                          TV turns on now, but it only shows a blue background and no image. It looks like I have another issue.
                          • lotas
                            • Jan 2016
                            • 4459
                            • Russia
                            #93
                            There was a problem in your firmware, I fixed it, is it your own motherboard or did you buy it from another TV?
                            Check all cables are correctly inserted, without distortions, do all this with the TV turned off.
                            • Techplayer
                              • Apr 2022
                              • 7
                              It's the original motherboard. I did check all the connections and everything is correctly inserted. Also I noticed when I disconnected the the cable from the power supply to the main board, it has the same behavior; backlight turns on but it's all blue. I will order a new set of backlights and I will post the result.
                              • Davi.p
                                • Sep 2009
                                • 4266
                                • Italy - Milan
                                #95
                                The screen is not blue, is dark grey or logically black...
                                  • 12081
                                  • U.S.
                                  #96
                                  by this you mean when you look thru the little holes on the back of the tv the backlights are blue?
                                  • Techplayer
                                    • Apr 2022
                                    • 7
                                    No, the front display is all blue. I found some YouTube videos about that issue and they fixed it by changing the led's.
                                    • Techplayer
                                      • Apr 2022
                                      • 7
                                      Yes, you are right. But that is when the TV is off.
                                      • mtorres927
                                        • Feb 2023
                                        Can someone help with this eprom, My tv has no picture, model No UN50MU6070 ver DE09
                                        I have attached the eprom dump. I'll appreciate any help given
                                        • ducky29
                                          • Dec 2015
                                          • 370
                                          • Europe
                                          #100
                                          @Iotas. Can you please check my dump? I think its ok but just want to make sure.
                                          Thanks in advance.
                                          • Soulzink
                                            Samsug washing machine. Power supply DC41-00189a board issue
                                            by Soulzink
                                            I am trying to fix a samsung washinmachine power supply main board.
                                            I already replaced it with another one to fix the machine but i want to try understand the issue with the old board.
                                            Therefore i hope to be able to get some help to explain what to check in order to troubleshoot.
                                            The power supply board reference is the following: DC41-00189a
                                            I have followed one thread (https://www.badcaps.net/forum/troubl...ingmachine-rel...
                                            04-19-2025, 06:26 AM
                                          • eclectric
                                            Sony Bravia KDL-70W850B T-CON board / software update issue
                                            by eclectric
                                            Hi, I'm hoping someone can help me with this issue before I give up on this TV.
                                            In short, I replaced the T-CON board due to an error code indicating that was the problem, after which it flashed a green and orange LED meaning software update required. I cannot get the tv to do the required update via USB, so I am stuck.
                                            Here is a rundown of the symptoms and the steps I have taken to troubleshoot:
                                            I inherited the TV with the symptom that it would turn on, then turn off after 5-10 seconds and a red LED flashed 4 or 5 times. Sometimes it would be 4, sometimes...
                                            05-23-2022, 01:25 AM
                                          • corrize
                                            Nikon D5 – dead, power board issue ?
                                            by corrize
                                            Hello, the DSLR has heavyly fallen. It is dead : no sign of life and display nothing.
                                            When it worked, it always displayed a card present state on LCD display, even when the battery is empty it display a empty battery symbol.
                                            I found a dead fuse, I replaced it and a mosfet burnt, I changed it and another fuse burned. Nothing burned after. And I can't find any short circuit anywhere, it's weird.
                                            Now, I try to understand how it works.
                                            There is two boards (the little one on pictures has no component) : the first is a « power board » : managing...
                                            04-03-2023, 09:13 AM
                                          • damndenis
                                            ASUS VG32UQA1A t-con board issue
                                            by damndenis
                                            Hello everybody,
                                            This is my first post here, I've always loved to tinker with electronics, but never got in-depth with it. Hope I can learn a thing or two from this forum.
                                            I've got a 31.5" Asus monitor which distorts/flickers at equal intervals of a couple of seconds. From what I've gathered, it's an issue with the T-CON board, but feel free to correct me. Shipping from the manufacturer would cost 3x as much as the part itself. I was wondering, if there is a way to diagnose the board itself and replace the faulty components? I'm good with soldering, but not at all...
                                            11-22-2024, 04:07 AM
