Un50mu6070 Mainboard issue
  • Alex Corps
    replied
    Hi, when I want to write the status registers I don't have the same thing at all as in your image.Click image for larger version
  • petersor
    replied
    Updated the firmware on the 24C512 with your file and it's still not working. I'll try the 25Q80 file at some point, but I'm going to shelf this project for now. I started restoring a Pioneer SX-1010 recently and I want to spend time on that. Thanks again for your help. I'll revisit this post when I pick this project back up.
  • lotas
    replied
    Ok!
  • petersor
    replied
    Thanks. I'll give them a try when I get back home . . . travelling this weekend.
  • lotas
    replied
    Not yet, I haven't had time yet, I'll try to look tomorrow.
    For now, try these two dumps for 25q80 and 24c512 for diagnostics.
    Status register for 25Q80 (0x98.0x02).
  • petersor
    replied
    lotas were you able to find anything in the 24C512 dump?
  • petersor
    replied
    Here's the data from the 24C512 eeprom . . .
  • lotas
    replied
    Try reading the firmware from eeprom 24c512 and posting it.​
  • petersor
    replied
    Thanks anyway. It was a good learning exercise and I appreciate all your help. Guess this one is destined for the landfill.
  • lotas
    replied
    Oh, I don’t even know, I don’t have the firmware for your panel (T-CON 25Q80) to compare. The problem may be in the eMMC, or perhaps in the processor itself...
  • petersor
    replied
    lotas - any thoughts on this? Anything else to look at before I scrap it?
  • petersor
    replied
    Reflowed the crystals and processor . . . no change. Maybe one of the boost or buck converters? They appear to be proprietary Samsung ICs so not much else to do at this point, I think. I suppose I could try reflowing those - especially IC401 / VLS1R0A. Voltages are wrong around that one . . . maybe I have a board with that IC on it. to try swapping it out.
Name:	Neg Boost Buck Converter.jpg
  • petersor
    replied
    Panel number is CY-GK050HGAV5H
  • petersor
    replied
    I'll check the panel number when I get back to the house tomorrow. I'll try reflowing the crystals first and if that doesn't help, I'll try the main processor . . .
  • lotas
    replied
    Originally posted by petersor
    Voltages and resistances are the same with the jumper in place.
    This chassis also had problems with the crystal falling off the substrate, remove the radiator and blow on the crystal with a soldering station for 30 seconds at a temperature of 200-250C.
  • lotas
    replied
    What panel do you have, number CY-xxxxxx?
  • Diah
    replied
    from yours measurement and test with Jumper and with out, it tell you have cut off of the I2C from the SoC. its 99% BGA. need to refllow
  • petersor
    replied
  • petersor
    replied
    OK. I'll add the jumper back and test again. Thanks for your patience.
  • lotas
    replied
    It is necessary with a jumper to see the remaining voltages.​
  • Soulzink
    Samsug washing machine. Power supply DC41-00189a board issue
    by Soulzink
    I am trying to fix a samsung washinmachine power supply main board.
    I already replaced it with another one to fix the machine but i want to try understand the issue with the old board.
    Therefore i hope to be able to get some help to explain what to check in order to troubleshoot.
    The power supply board reference is the following: DC41-00189a
    I have followed one thread (https://www.badcaps.net/forum/troubl...ingmachine-rel...
    04-19-2025, 06:26 AM
  • notallbad
    TCL 55RP620K power board issue
    by notallbad
    Originally the tv arrived with dimmed backlights (not failed leds) but everything else worked ok. Adjusting backlight in menu did nothing but voltage changed on dimming control pins,
    0% p_dim at 1.65v and a_dim at 1v
    50% p_dim at 3.3v and a_dim at 1.65v
    100% p_dim at 3.3v and a_dim at 2.88v
    Changed backlight leds anyway as always like to have complete peace of mind they wont fail shortly after selling the tv. No change as expected!
    Leds are 2 rows of 15 6v leds.
    On inspection of the power board found diode MBR3200 shorted so replaced with...
    07-12-2025, 05:45 AM
  • eclectric
    Sony Bravia KDL-70W850B T-CON board / software update issue
    by eclectric
    Hi, I'm hoping someone can help me with this issue before I give up on this TV.
    In short, I replaced the T-CON board due to an error code indicating that was the problem, after which it flashed a green and orange LED meaning software update required. I cannot get the tv to do the required update via USB, so I am stuck.
    Here is a rundown of the symptoms and the steps I have taken to troubleshoot:
    I inherited the TV with the symptom that it would turn on, then turn off after 5-10 seconds and a red LED flashed 4 or 5 times. Sometimes it would be 4, sometimes...
    05-23-2022, 01:25 AM
  • corrize
    Nikon D5 – dead, power board issue ?
    by corrize
    Hello, the DSLR has heavyly fallen. It is dead : no sign of life and display nothing.
    When it worked, it always displayed a card present state on LCD display, even when the battery is empty it display a empty battery symbol.
    I found a dead fuse, I replaced it and a mosfet burnt, I changed it and another fuse burned. Nothing burned after. And I can't find any short circuit anywhere, it's weird.
    Now, I try to understand how it works.
    There is two boards (the little one on pictures has no component) : the first is a « power board » : managing...
    04-03-2023, 09:13 AM
