Un50mu6070 Mainboard issue
  • lotas
    • Jan 2016
    • 4744
    • Russia
    #81
    Re: Un50mu6070 Mainboard issue
    For this series, the header (the first bytes) in the Standby power firmware just flies off. And at the same time, even the indicator will not light, verified.
    • lotas
      • Jan 2016
      • 4744
      • Russia
      #82
      Originally posted by crym1111
      again, no...
      Try putting SR first, and then write Dump.
      • Diah
        • Feb 2013
        • 6435
        status reg make conflict always... using the CH341A programmer software V1.4 will be fine... the spi will not change first secor.
        • Davi.p
          Hobbist Tech
          • Sep 2009
          • 4456
          • Italy - Milan
          #84
          Hijacking other one's thread does make time wasting from the involved users.. Open your thread please...
          • crym1111
            • Feb 2022
            • 20
            #85
            Hi Lotas,
            For xxMU6xxx series you have to set on the programmer "STATUS REGISTERS"
            0x88, 0x42.
            For xxKU6xxx series is the same rule and the same set for SR (0x88 and 0x42)...?
            Kind regards
            • lotas
              • Jan 2016
              • 4744
              • Russia
              #86
              Hi Lotas,
              0x88, 0x42.
              Kind regards
              Hello, in "MU" the cap in the 25Q40 firmware often flies and so that it does not fly off the first time it is turned on and these SRs (0x88 and 0x42) are put, I don't remember about "KU".
              • crym1111
                • Feb 2022
                • 20
                #87
                Because when i read 25Q40 from KU6xxx series found SR 1 set 0XAC and SR 2 set 0x2; in other case i found SR 1 set as 0x2C and SR 2 0x2.
                Could somebody to confirm how must be set SR for KU series...?
                Regards
                • alltvrepairs
                  • Jan 2014
                  • 245
                  • Malta
                  #88
                  Am following this thread as had issues on MU and KU series. I use the EZP2010 programmer and use new chips as far as possible. On a recent board the issue I managed to fix a no display problem replacing the upper IC 25Q80 (sorry I don't have the IC number here) by copying from a similar working board. I wasn't aware of any protection bits so maybe either I was lucky. After each read and copy I always verify the copy.
                  I have kept copies of both ICs as well if you need.
                  • Techplayer
                    • Apr 2022
                    • 7
                    I have a similar issue with a UN65MU650DFXZA. The tv presents the same symptoms as the original post by Storyteller12. Does anyone has a working bin file for this tv model? I am attaching the original bin file.
                    • lotas
                      • Jan 2016
                      • 4744
                      • Russia
                      #90
                      Someone else's, working firmware (Dump) will not help you, here's your restored one.
                      • Techplayer
                        • Apr 2022
                        • 7
                        Thank you. I will test it and let you know the result.
                        • Techplayer
                          • Apr 2022
                          • 7
                          TV turns on now, but it only shows a blue background and no image. It looks like I have another issue.
                          • lotas
                            • Jan 2016
                            • 4744
                            • Russia
                            #93
                            There was a problem in your firmware, I fixed it, is it your own motherboard or did you buy it from another TV?
                            Check all cables are correctly inserted, without distortions, do all this with the TV turned off.
                            • Techplayer
                              • Apr 2022
                              • 7
                              It's the original motherboard. I did check all the connections and everything is correctly inserted. Also I noticed when I disconnected the the cable from the power supply to the main board, it has the same behavior; backlight turns on but it's all blue. I will order a new set of backlights and I will post the result.
                              • Davi.p
                                Hobbist Tech
                                • Sep 2009
                                • 4456
                                • Italy - Milan
                                #95
                                The screen is not blue, is dark grey or logically black...
                                • nomoresonys
                                  • 12269
                                  • U.S.
                                  #96
                                  by this you mean when you look thru the little holes on the back of the tv the backlights are blue?
                                  • Techplayer
                                    • Apr 2022
                                    • 7
                                    No, the front display is all blue. I found some YouTube videos about that issue and they fixed it by changing the led's.
                                    • Techplayer
                                      • Apr 2022
                                      • 7
                                      Yes, you are right. But that is when the TV is off.
                                      • mtorres927
                                        • Feb 2023
                                        Can someone help with this eprom, My tv has no picture, model No UN50MU6070 ver DE09
                                        I have attached the eprom dump. I'll appreciate any help given
                                        • ducky29
                                          • Dec 2015
                                          • 369
                                          • Europe
                                          #100
                                          @Iotas. Can you please check my dump? I think its ok but just want to make sure.
                                          Thanks in advance.
                                          • Soulzink
                                            Samsug washing machine. Power supply DC41-00189a board issue
                                            by Soulzink
                                            I am trying to fix a samsung washinmachine power supply main board.
                                            I already replaced it with another one to fix the machine but i want to try understand the issue with the old board.
                                            Therefore i hope to be able to get some help to explain what to check in order to troubleshoot.
                                            The power supply board reference is the following: DC41-00189a
                                            I have followed one thread (https://www.badcaps.net/forum/troubl...ingmachine-rel...
                                            04-19-2025, 06:26 AM
                                          • Stephen
                                            A2991 Logic Board issue, 20volts 0 amps help!
                                            by Stephen
                                            Customer plugged in samsung monitor into the board and used it as a power supply, killed UG800 and UG400. I replaced those two with an exact donor board we had In stock and working, board pulls 5volts and then gets like 2.89 amps on the left side. The singular port is the port that failed. Used a perfectly working chips from donor (board was locked) Now I only get 5volts 0 amps on that power and then 20volts 0 amps on the two left side ports, I checked for DFU and nope nothing, computer not turning on. No shorts present anymore. I am confused as I used the exact components from an identical...
                                            09-10-2025, 03:16 PM
                                          • Stephen
                                            A2991 logic board issue, 20volts 0 amps help!
                                            by Stephen
                                            09-10-2025, 03:15 PM
                                          • notallbad
                                            TCL 55RP620K power board issue
                                            by notallbad
                                            Originally the tv arrived with dimmed backlights (not failed leds) but everything else worked ok. Adjusting backlight in menu did nothing but voltage changed on dimming control pins,
                                            0% p_dim at 1.65v and a_dim at 1v
                                            50% p_dim at 3.3v and a_dim at 1.65v
                                            100% p_dim at 3.3v and a_dim at 2.88v
                                            Changed backlight leds anyway as always like to have complete peace of mind they wont fail shortly after selling the tv. No change as expected!
                                            Leds are 2 rows of 15 6v leds.
                                            On inspection of the power board found diode MBR3200 shorted so replaced with...
                                            07-12-2025, 05:45 AM
                                          • Tynan Dill
                                            by Tynan Dill
                                            Assuming...
                                            11-22-2024, 01:46 PM
