A2991 Logic Board issue, 20volts 0 amps help!
  • Stephen
    Meow Meow MEOW!
    • Apr 2020
    • 674
    Customer plugged in samsung monitor into the board and used it as a power supply, killed UG800 and UG400. I replaced those two with an exact donor board we had In stock and working, board pulls 5volts and then gets like 2.89 amps on the left side. The singular port is the port that failed. Used a perfectly working chips from donor (board was locked) Now I only get 5volts 0 amps on that power and then 20volts 0 amps on the two left side ports, I checked for DFU and nope nothing, computer not turning on. No shorts present anymore. I am confused as I used the exact components from an identical working board. So I am now stuck tracing the issue. I am only getting 12volts at PPBUS_AON . PP3v3 is present and P1v8 is present but nothing. I also put it into the battery and nothing. So I'm lost now. Very confused where I am missing as there are no present shorts here. Am I missing something?
    sigpic
    MEOWING IN THE IMPOSSIBLE UNIVERSE!
  • mon2
    • Dec 2019
    • 14672
    PPBUS_AON is dialed up / down over SMBUS. Confirm the voltage to ground on the SMBUS lines used by this regulator. Also suggest to measure the voltage to ground of the SMBUS lines used by the battery BMS.
    • Stephen
      Meow Meow MEOW!
      • Apr 2020
      • 674
      Well battery is holding a charge, I tested the lines by itself and the battery is presently sending voltage down the lines. But I will get back with measurements
      sigpic
      • Stephen
        Meow Meow MEOW!
        • Apr 2020
        • 674
        Are we talking the SDA and SCL lines? Because those measured nothing when plugged into that port. I measured them at .45volts SDA and SCL is 0volts. I am missing 3.3 volts for sure.
        sigpic
        • mon2
          • Dec 2019
          • 14672
          Something could be wrong here. Remove all power. Meter in resistance mode. Measure the resistance to ground on each of these SCL / SDA lines. The TVS ESD diode may have triggered. Have not checked the schematic but for a while, the boards contain a small TVS ESD diode on the battery connector.
          • Stephen
            Meow Meow MEOW!
            • Apr 2020
            • 674
            SDA and SCL 1 M ohms on both lines.
            sigpic
            • Stephen
              Meow Meow MEOW!
              • Apr 2020
              • 674
              Any thoughts?
              sigpic
              • mon2
                • Dec 2019
                • 14672
                Would you have the timing diagram for the power sequencing for this motherboard?
                See attached. Can zoom in on any area of interest on this drawing.
                Click image for larger version  Name:	A2991_power_sequence1.png Views:	0 Size:	525.0 KB ID:	3723114
                Click image for larger version  Name:	A2991_power_sequence2.png Views:	0 Size:	402.6 KB ID:	3723115
                • Stephen
                  Meow Meow MEOW!
                  • Apr 2020
                  • 674
                  Awe I do not. I am just using the board schematic and PDF to go off this repair.
                  sigpic
                  • Stephen
                    A2991 logic board issue, 20volts 0 amps help!
                    by Stephen
                    Customer plugged in samsung monitor into the board and used it as a power supply, killed UG800 and UG400. I replaced those two with an exact donor board we had In stock and working, board pulls 5volts and then gets like 2.89 amps on the left side. The singular port is the port that failed. Used a perfectly working chips from donor (board was locked) Now I only get 5volts 0 amps on that power and then 20volts 0 amps on the two left side ports, I checked for DFU and nope nothing, computer not turning on. No shorts present anymore. I am confused as I used the exact components from an identical...
                    09-10-2025, 03:15 PM
                  • m1ch43lzm
                    by m1ch43lzm
                    05-12-2025, 08:37 PM
                  • ohren
                    by ohren
                    09-08-2023, 05:24 PM
                  • Yanleb
                    LG 60PK550 Logic Control Board EBR63450301
                    by Yanleb
                    Hi all, I just want to share the repair of my 60PK550-UA TV set.
                    The TV set was powering on, just no image. After verification, nothing wrong on the YSus or ZSus boards. Nothing wrong on the main board either.
                    But I noticed that the LED was not flashing on the Logic Control Board. This is an EBR63450301. The LED is supposed to flash even with all the flat cables disconnected, with only the power cable attached.
                    All the voltages measured at the electrolytic capacitors on the board were good. From top left to bottom right:
                    C57: 3.30V
                    C61:...
                    07-20-2023, 12:38 AM
