nice burn in on sanyo lcd at walmart
  • kc8adu
    • Nov 2003
    • 8832
    • U.S.A!
    no idea how long this took.
  • weirdlookinguy
    • Sep 2007
    • 1638
    Re: nice burn in on sanyo lcd at walmart
    Walmart is disgusting. Ethical issues aside (China, anti-competitive etc.), they sell a lot of really cheaply made shit and the one near my house always looks as if everything could use a really good cleaning (except the merchandise itself).
    • Wizard
      • Mar 2008
      • 2296
      Sanyo is low quality and when needs service be prepared to pay wide open even TV is cheap to begin with. Good LCDs don't burn.
      Cheers, Wizard
        • 31294
        what would you expect from wallmart with Hitlary Clinton on the board.
        • PlainBill
          • Feb 2009
          • 7034
          Three errors in one sentence? I'm not sure if that is a record, but it could be.
          1. The company name is Wal-Mart.
          2. The lady's name is Hillary
          3. She hasn't been on the board of Directors since 1992.
          Remember, Google could be your friend. It helps you keep you distinguish between truth and innuendo.
          Give my regards to Rush.
          PlainBill
          • larrymoencurly
            • Oct 2004
            • 960
            Recent Consumer Reports surveys show that Sanyo LCDs have one of the lowest failure rates. Actually I don't think they reveal any statistically significant difference in failures except for Mitsubishi and the worst brands, like Westinghouse and Polaroid.
            • loustvchris
              DLP/Panel Tech
              • May 2010
              • 4
              Cheers, Wizard
              I gotta wonder if that is a plasma and not an LCD. Maybe some employee saw a sticker on the floor and put it on the wrong tv? I have never seen LCDs with burn in. In school they told us that it was impossible, but not everything I learned was totally true.
              Really? Sanyo is junk? I personally like the Sanyo product and company. Even the crts in the 90's I thought were good value (cheap) products.
              I agree sir. I believe the problem with your television is that you need the picture tube replaced.
              • kc8adu
                • Nov 2003
                • 8832
                • U.S.A!
                i have seen image persistance on lcd sets.mostly on cheap panels like the chi mei in an audiovox 26" on my bench.
                it goes away quickly and is most easily spotted on a still image with a brightly colored area.a negative of that colored area will be seen in some scenes later.
                example is a webpage with bluegreen stripes down the sides.on a white screen you will see pink stripes.
                • Topcat
                  The Boss Stooge
                  • Oct 2003
                  • 16959
                  I've never seen a LCD burn-in like that.....even at our local walfart, which never shuts theirs off. I've seen burns on some of their plasmas though, all Sanyo's ironically enough. I think our local walmart rotates the stock often enough to prevent most of this. they periodically sell floor models dirt cheap.
                  <--- Badcaps.net Founder
                  Badcaps.net Services:
                  Motherboard Repair Services
                  http://folding.stanford.edu/
                  Team : 49813
                  Join in!!
                  Team Stats
                  • japlytic
                    • Oct 2005
                    • 2086
                    I do know that LCDs do not burn in, but plasmas do.
                    Apparently, they are not aware of the need to prevent this happening!
                    • Colt45ws
                      • Jan 2009
                      • 174
                      My brother got a 32" Vizio. It likes to ghost through it goes away eventually. Mine does not do that.
                      • kc8adu
                        • Nov 2003
                        • 8832
                        • U.S.A!
                        i have to go to eaton today.i will see if it is still on display and if that burn in is still there.
                        • NxB
                          • Feb 2009
                          • 1595
                          Vizio is horrible, at least they are simple to fix.
                          • PlainBill
                            • Feb 2009
                            • 7034
                            "Burn in", while descriptive of the appearance is probably not a good term, but a permanent image on an LCD panel is possible.
                            An LCD panel works by using a polarizing voltage across the cells in the panel. Under some circumstances (usually an electronic failure) they will electrolyze the liquid in the cells. It won't happen in a panel that is working properly, but the chearper they build them the more likely it is.
                            PlainBill
                            • safesinger
                              • May 2010
                              • 3
                              My Sanyo 26" LCD TV also gets image burn in.
                              At first it would go away after awhile but this last burn in that happened from falling asleep while it was on a show that was 4:3 ratio and the sides are a permanent burn in now.
                              I always thought LCD's were pretty safe from burn in owning this sanyo has proven different also have seen the old Dell LCD TV's get burn in.
                              Purchased the Philips 5000 series LCD 4 months ago and noticed right away it does not get burn in like my Sanyo does.
                              • tmwalsh
                                • Jan 2009
                                • 119
                                I had read on another video forum that people were getting burn-in images on HD sets that were getting 'pillarbox' mode images. Either side of the display would have a different brightness and/or color level displayed by the pixels that had not gotten as much usage when a full-screen HD image was displayed.
                                tom
                                • sgeorge
                                  • 16
                                  Cheers, Wizard
                                  we do warranty work for sanyo for several walmart stores and i can tell you they are a fine tv set. and very well trouble free. steve
                                    PlainBill
                                    These panels are meant to be driven with a high frequency AC signal, so there is no overall DC bias across each cell. If there is a failure like you mention, DC might be applied to the cells. This happens with LCDs from calculators etc. Try connecting a battery to the segments. They will work but they will be damaged if left for a while.
                                    I guess the most common fault would be T-con going bad, it's possible it could fail in a way that the picture continues to work but a DC bias is applied. Like some amplifiers can kill speakers by keeping a DC bias across the output terminals - yet you probably wouldn't notice the difference in audio.
                                    • Scenic
                                      o.O
                                      • Sep 2007
                                      • 2642
                                      As long as the burn-in isn't really severe, you can usually get rid of it by displaying a solid white picture for a relatively long time (couple hours or more)
                                      • mbates14
                                        • May 2005
                                        • 169
                                        Well I have a friend of mine that has a 27" TV that he uses as a CCTV monitor, its going on 5 years old. the gridlines are burned into the LCD display.
                                        Just so you know ;-)
                                        • ttmi100x
                                          HANNSG Hi221 -- 2 secs to black feat. CCFL flicker & "burn" marks on power board
                                          by ttmi100x
                                          Greetings everyone,
                                          I have a HANNSG Hi221 monitor that exhibits two seconds to black issues (backlight goes off, display is still on as confirmed by shining a flashlight on it) with some additional oddities...
                                          The monitor failed on me with a standard "2 seconds to black" some time ago prompting me to initially replace most of the electrolytic capacitors (some of them were bulging/leaking).
                                          Things kinda sorta worked for a night, then the problem returned along with some flickering and "buzzing" noises.
                                          Upon closer inspection...
                                          07-31-2024, 06:36 PM
                                        • howardc64
                                          Insignia NS-43D420NA20 backlight on no display - LCD panel burn failure
                                          by howardc64
                                          Eventually discovered a burn mark near lower corner of LCD. Here is a summary
                                          • Backlight on, no image
                                          • Disconnect right buffer board (view from front), left side display comes on
                                          • Masked off pin 7+8 (both ~12,5v on both left and right buffer board) from t-con to right buffer board (view from front) display works but have some lines
                                          • Buffer board is pretty simple
                                          Removed the front bezel to examine edge of the glass. Found burn mark on lower right (view from front). Plastic bezel covering the burn mark region shows heat signature on the inside surface facing the LCD panel. Last 2 pics. Bright...
                                          07-11-2025, 04:04 PM
                                        • Tom41
                                          AOC U27G3X strange burn-in
                                          by Tom41
                                          I have an AOC U27G3X 4K gaming monitor that I use both as a TV and for gaming on a Nintendo Switch 2 console. Recently, something very strange has been happening to it. After playing a game that has an on-screen timer for a few minutes, the last digit of the timer (the one rapidly flickering from 0 to 9) appears to burn in on the monitor. Going to a different source or power cycling the monitor does not help; there is a constant flickering area on the screen where that digit was.
                                          It seems strange that only that digit would burn in, and NOT the other digits that are changing less frequently....
                                          10-23-2025, 04:33 AM
                                        • cj_reha
                                          Mystery 80s Sanyo cap - perhaps polymer?
                                          by cj_reha
                                          Hey all I've been working on a 1984 Sanyo 27" color TV which had a smattering of bad caps in the video switching circuit. I found this oddball little 1uF 25V cap which looks to me like an early polymer, but I can't find concrete info proving it. I know Sanyo was a big player in early polymer cap development and this is the time period where they were just getting on the market, so I'm wondering if anyone has crusty old datasheets that could help identify it and determine if my suspicions are right? It has the same epoxy end seal and font/formatting as some old stock Os-Cons I've got laying...
                                          01-06-2023, 09:24 AM
                                        • ktmmotocross
                                          Dell G15 5511 LA-K455P - new gpu fan burn SIO pwm sig. in SIO MEC1515
                                          by ktmmotocross
                                          Hello. Have this Dell G15 5511 la-k455p that new gpu fan burn and left pwm sig from sio with 10 ohms.
                                          I read that this sio MEC1515 must be programmed, but someone says dont. My Vertyanov seems dont have this model in it.
                                          Laptop works and can be tricked by split pwm, but i dont want to do this stuff this way.
                                          So anyone really knows if it must be programmed?
                                          09-16-2025, 07:11 AM
