no idea how long this took.
nice burn in on sanyo lcd at walmart
Re: nice burn in on sanyo lcd at walmart
Walmart is disgusting. Ethical issues aside (China, anti-competitive etc.), they sell a lot of really cheaply made shit and the one near my house always looks as if everything could use a really good cleaning (except the merchandise itself). -
Originally posted by stjwhat would you expect from wallmart with Hitlary Clinton on the board.
1. The company name is Wal-Mart.
2. The lady's name is Hillary
3. She hasn't been on the board of Directors since 1992.
Remember, Google could be your friend. It helps you keep you distinguish between truth and innuendo.
Give my regards to Rush.
PlainBillFor a number of reasons, both health and personal, I will no longer be active on this board. Any PMs asking for assistance will be ignored.
Never be afraid to try something new. Remember, amateurs built the ark. Professionals built the Titanic.Comment
Originally posted by WizardSanyo is low quality and when needs service be prepared to pay wide open even TV is cheap to begin with. Good LCDs don't burn.Comment
Cheers, Wizard
Really? Sanyo is junk? I personally like the Sanyo product and company. Even the crts in the 90's I thought were good value (cheap) products.I agree sir. I believe the problem with your television is that you need the picture tube replaced.Comment
i have seen image persistance on lcd sets.mostly on cheap panels like the chi mei in an audiovox 26" on my bench.
it goes away quickly and is most easily spotted on a still image with a brightly colored area.a negative of that colored area will be seen in some scenes later.
example is a webpage with bluegreen stripes down the sides.on a white screen you will see pink stripes.Comment
I've never seen a LCD burn-in like that.....even at our local walfart, which never shuts theirs off. I've seen burns on some of their plasmas though, all Sanyo's ironically enough. I think our local walmart rotates the stock often enough to prevent most of this. they periodically sell floor models dirt cheap.<--- Badcaps.net Founder
Badcaps.net Services:
Motherboard Repair Services
http://folding.stanford.edu/
Team : 49813
Join in!!
Team StatsComment
I do know that LCDs do not burn in, but plasmas do.
Apparently, they are not aware of the need to prevent this happening!My first choice in quality Japanese electrolytics is Nippon Chemi-Con, which has been in business since 1931... the quality of electronics is dependent on the quality of the electrolytics.Comment
An LCD panel works by using a polarizing voltage across the cells in the panel. Under some circumstances (usually an electronic failure) they will electrolyze the liquid in the cells. It won't happen in a panel that is working properly, but the chearper they build them the more likely it is.
My Sanyo 26" LCD TV also gets image burn in.
At first it would go away after awhile but this last burn in that happened from falling asleep while it was on a show that was 4:3 ratio and the sides are a permanent burn in now.
I always thought LCD's were pretty safe from burn in owning this sanyo has proven different also have seen the old Dell LCD TV's get burn in.
Purchased the Philips 5000 series LCD 4 months ago and noticed right away it does not get burn in like my Sanyo does.Last edited by safesinger; 05-12-2010, 09:23 PM.Comment
I had read on another video forum that people were getting burn-in images on HD sets that were getting 'pillarbox' mode images. Either side of the display would have a different brightness and/or color level displayed by the pixels that had not gotten as much usage when a full-screen HD image was displayed.
tomComment
we do warranty work for sanyo for several walmart stores and i can tell you they are a fine tv set. and very well trouble free. steveComment
PlainBill
I guess the most common fault would be T-con going bad, it's possible it could fail in a way that the picture continues to work but a DC bias is applied. Like some amplifiers can kill speakers by keeping a DC bias across the output terminals - yet you probably wouldn't notice the difference in audio.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
For service manual, schematic, boardview (board view), datasheet, cad - use our search.Comment
by ttmi100xGreetings everyone,
I have a HANNSG Hi221 monitor that exhibits two seconds to black issues (backlight goes off, display is still on as confirmed by shining a flashlight on it) with some additional oddities...
The monitor failed on me with a standard "2 seconds to black" some time ago prompting me to initially replace most of the electrolytic capacitors (some of them were bulging/leaking).
Things kinda sorta worked for a night, then the problem returned along with some flickering and "buzzing" noises.
Upon closer inspection...6 Photos-
by howardc64Eventually discovered a burn mark near lower corner of LCD. Here is a summary
- Backlight on, no image
- Disconnect right buffer board (view from front), left side display comes on
- Masked off pin 7+8 (both ~12,5v on both left and right buffer board) from t-con to right buffer board (view from front) display works but have some lines
- Buffer board is pretty simple
07-11-2025, 04:04 PM -
by cj_rehaHey all
I've been working on a 1984 Sanyo 27" color TV which had a smattering of bad caps in the video switching circuit. I found this oddball little 1uF 25V cap which looks to me like an early polymer, but I can't find concrete info proving it. I know Sanyo was a big player in early polymer cap development and this is the time period where they were just getting on the market, so I'm wondering if anyone has crusty old datasheets that could help identify it and determine if my suspicions are right? It has the same epoxy end seal and font/formatting as some old stock Os-Cons I've got laying...
Channel: General Capacitor Questions & Issues
by ktmmotocrossHello. Have this Dell G15 5511 la-k455p that new gpu fan burn and left pwm sig from sio with 10 ohms.
I read that this sio MEC1515 must be programmed, but someone says dont. My Vertyanov seems dont have this model in it.
Laptop works and can be tricked by split pwm, but i dont want to do this stuff this way.
So anyone really knows if it must be programmed?09-16-2025, 07:11 AM -
by SevilleHello all!
Westinghouse TV WD48FAB100 Not Powering On – Burn Mark Found on Power Supply .
I have a Westinghouse LED TV, model WD48FAB100 that is not powering on. Upon removing the back cover, I noticed a burn mark where the AC cord connects to the power supply/main board. In this model, there is only one board combining the two functions. Previous owner said the TV experienced a lightening strike, but who knows. I checked the main fuse, tested OK. Here are a collection of readings from the power supply ports. Looking for some guidance on what to test/check next.... - Loading...
