Mystery 80s Sanyo cap - perhaps polymer?
  • cj_reha
    • Jan 2023
    • 3
    Hey all I've been working on a 1984 Sanyo 27" color TV which had a smattering of bad caps in the video switching circuit. I found this oddball little 1uF 25V cap which looks to me like an early polymer, but I can't find concrete info proving it. I know Sanyo was a big player in early polymer cap development and this is the time period where they were just getting on the market, so I'm wondering if anyone has crusty old datasheets that could help identify it and determine if my suspicions are right? It has the same epoxy end seal and font/formatting as some old stock Os-Cons I've got laying around, and compared to one of the conventional looking electrolytics I also changed out, the ESR tests much better (2.4 ohms vs. nearly 5 for the black lytic).
    Is this a really early polymer, or just a weird looking electrolytic? I'm more curious than anything - the set works fine with a standard electrolytic in its place. I simply have a fascination with early/oddball cap history and would love to learn more about Sanyo's offerings since information on them seems harder to come by over one of the more commonly seen brands like Nichicon or Panasonic. I've attached photos of all the markings on the cap and comparisons with other caps to hopefully help.
    Thanks everyone
    • 31283
    Re: Mystery 80s Sanyo cap - perhaps polymer?
    i think it's just an electrolytic with a sealed can.
    some american company used to seal all their electrolytics with epoxy too - i used to see them in a lot of arcade gear from the 80's
    • cj_reha
      • Jan 2023
      • 3
      Maybe you're thinking of Illinois Capacitor? I've seen some caps from them from that time period that have the same epoxy seal. Lots of Sprague caps from the 70s had bright red epoxy seals too - I see a lot of those at work in old minicomputer equipment. They're all junk now sadly...the tiny caps just don't hold up.
      It's definitely possible they're plain ol lytics with a weird seal...I'm just curious to see if there's someone in the woodwork somewhere who worked on the design team or something and could say for sure. It's a long shot but curiosity has gotten the better of me
        • 31283
        cut it open?
        • R_J
          • 9623
          Likely just a an electrolytic in a plastic mold vs an aluminum can
          • redwire
            • 3912
            That old Sanyo cap is electrolytic, oddly enough the same construction was used decades later in their polymer lineup.
            In the '80's a few electrolytic capacitor manufacturers went with using hard epoxy instead of a rubber bung. Rubber is not great as a seal technology. Sangamo 301.
            Epoxy didn't really work - I've seen cracked epoxy or the cap has dried out low value. I think the aluminum can thermal expansion, or hydrogen pressure just was more than epoxy could deal with. Although it could be internal corrosion. Take one apart.
            So the industry settled on synthetic rubbers butadiene for the bung, they do much better.
              • 31283
              i like the soviet ones - metal can, plastic bung and a rubber washer or o-ring in the crimp
              they still dry up, but they dont leak around the legs!
              • redwire
                • 3912
                This explains all the unexploded missiles lol.
                But it all comes down to material tech. Rubber dries out and shrinks, epoxy cracks, wax/tar dried out and shrank etc. etc.
                Maybe the electrolyte attacks the seal or something. I think we're at the 100 year mark for electrolytic capacitors.
                • chth96
                  Should I replace polymer capacitor?
                  by chth96
                  a few days ago I finally purchased mser-100 v2 and I tested its abillity of measuring ESR value.
                  I found that It shows pretty accurate ESR value for electrolytic capacitor,But When I measure polymer capacitor of dreamcast game console,I found that one third of polymer capacitor's ESR value is more than twice the value of ESR meter table.(for example, I measured one polymer capacitor of 6.3v 100uf, It showed ESR value of 7.68)
                  Although my dreamcast now turns 20 years old but it still works. I occasionally have played game with it.
                  Is this ESR value of polymer capacitor correct?...
                  11-18-2022, 04:22 AM
                • Perry Babin
                  Derating of polymer electrolytics
                  by Perry Babin
                  There have been suggestions for derating polymer electrolytics to below the rated values. I've seen documents that recommended this and some that indicate that derating isn't required. The documents recommending derating are often old or refer to old documents. Do polymer caps of this type still require derating for reliability?
                  If they require derating, why would the manufacturer give them their rated voltage?
                  This is the basic type of capacitor I'm referring to and included simply to eliminate other caps that use similar names.
                  https://www.mouser.com/datashe...
                  10-24-2025, 11:57 AM
                • Perry Babin
                  How do organic polymer caps compare to liquid electrolytic for reliability
                  by Perry Babin
                  I have a situation where a power supply is commonly abused and the 12v supply caps take a beating. They don't commonly fail but they run hot. I was thinking about going from a liquid electrolytic (Panasonic FC and Nichicon HE) to an organic polymer. The values have been 330uF. I typically use a higher-than-needed voltage to get a lower ESR. The supply is operated from 12v.
                  If not organic polymer, what would be the caps that could take the most abuse?
                  08-18-2025, 04:04 PM
                • OriginalDaggers
                  XBox 360 All Polymer Capacitors
                  by OriginalDaggers
                  As the title says, Xbox 360 Polymer Capacitors, replacing all on a Kronos 1 revision board.
                  I went over a thread here (Xbox 360 with blown caps) and gather some extremely useful knowledge!
                  If I have things right, I can replace them TO
                  x9 : 1500uF 16V 10x20mm
                  TO: 470uF Nichicon FPCAP R7
                  x2 : 820uF 6.3V 8x12mm
                  TO: 2.5V 820uF Nichicon FPCAP R5
                  On this revision, there are other 820uF polymer capacitors for GPU/CPU - I'll be replacing those anyway with the above FPCAP R5
                  What's a good replacement for the smaller...
                  This can be anything from game consoles to arcade games to anything else that doesn't really fit into any of the above categories. When starting a new thread, please put the make AND model of your device in the thread title. Also be VERY descriptive of your issue, that way you'll get the best answer possible!
                  02-20-2024, 12:49 PM
                • Cartel
                  FORD 1996 ECU RECAP: Aluminum - Polymer worth bothering?
                  by Cartel
                  I will be pulling my crown vic ECU and recapping it. 3 in total, 47uf 16v x2 and a 10uf 63v
                  I hope they havent puked yet. I was thinking of replacing them with Aluminum - Polymer thru hole caps. probably 47uf 25v and 10uf 80v
                  They arent cheap. Anyone have any experience with them? Am I wasing my money on premium caps?
                  Nichicon PLV series
                  thanks
                  06-01-2025, 04:58 AM
