when i turn on, Philliips TV is not on
  • Nish
    • Sep 2013
    • 124
    Re: when i turn on, Philliips TV is not on
    I test with continuity test The IC901
    Pin 8 is gnd So black probe on it and touch pin3 , it has beep. Also once I plug the board outlet and unplug check pin5 has beep for few min then stop.
    • R_J
      • 9517
      You can't check the ic with a meter.
      • Nish
        • Sep 2013
        • 124
        Quick question R_J: I see too many arduino scope online. Do you think I can use it here? If yes I can build one.
        • Nish
          • Sep 2013
          • 124
          Never mind, arduino is 5v one. I can't use it here
          • Nish
            • Sep 2013
            • 124
            Is it useable to buy?
            https://www.newegg.ca/p/2A7-00BD-00018
            • Nish
              • Sep 2013
              • 124
              I found new IC and replaced it. I got 0.210v at C951A and going down. Now 0.183.
                • 12085
                • U.S.
                #87
                If you had a 5 dollar esr tester you could have taken those caps out and tested them, as it stands you don't even know if they are good or not.
                • vinceroger69
                  • Mar 2012
                  • 6714
                  #88
                  what is the power supply board number?
                  • Nish
                    • Sep 2013
                    • 124
                    dsp-484ap upbpspdel003
                    • Nish
                      • Sep 2013
                      • 124
                      I have one I will test and update soon
                      • Nish
                        • Sep 2013
                        • 124
                        Can I buy this power supply?
                        https://www.ebay.ca/itm/TV-Power-Sup...sAAOSwwqVcD9IR
                        • Nish
                          • Sep 2013
                          • 124
                          C951A = 0.036 (10v 1000uF)
                          C951B = 0.027 (10v 1000uF)
                          C952 = 0.062 (10v 1000uF)
                          C912 = 0.573 (100v 22uF)
                          C906 = 0.042 (35v 220uF)
                          Is it possible to get replacement IC for DNP005 (IC901).
                          • R_J
                            • 9517
                            Where did you get the ic that is in there now after the original blew up?
                            Maybe that has been the problem all along. There is no datasheet on this ic, so it's hard to know the specs (operating frequency etc.)
                            • Nish
                              • Sep 2013
                              • 124
                              I bought using ebay and from China.
                              R_J: is there any scope that I can get for 200. I know most of it above 350.
                                Post #92
                                "Is it possible to get replacement IC for DNP005 (IC901)."
                                But you said you already replace it, so what did you replace it with?
                                Post #86:
                                "I found new IC and replaced it. I got 0.210v at C951A and going down. Now 0.183."
                                • Nish
                                  • Sep 2013
                                  • 124
                                  Originally posted by budm
                                  Post #92
                                  Post #86:
                                  I bought 3 of DNP005. I blow out and I had extra to replace again
                                  • Nish
                                    • Sep 2013
                                    • 124
                                    Quick question : ZD907 (UDZSTE-17), it's zener diode. Is it 5.6v or 15v? It's in the standby circuit.
                                    • R_J
                                      • 9517
                                      ZD907 is a PDZ13b, 13volt zener
                                      • Nish
                                        • Sep 2013
                                        • 124
                                        Sorry I want to know ZD904 (UDZSTE-17). Is it 5.6v or 15v? Near C912
                                        • R_J
                                          • 9517
                                          What is the number or letter on the diode? You may need to clean the top with alcohol to read it,
                                          There is no datasheet for the ic, but C912 is rated for 100v so this ic's VCC might be higher than other similar pwm ic's.
                                          • rabsonnjala
                                            LENOVO IDEAPAD 100 works only on bench power supply
                                            by rabsonnjala
                                            Hie I have a Lenovo laptop
                                            Lenovo Ideapad 100-14IBY AIVP1-AIVP2 LA-C771P rev 1.0
                                            it's working only on the bench power supply when I put the battery it doesn't power on. when I also use the original charger it doesn't power. the batter Is fully charged, I used another laptop to charge the battery. but when I use a bench power supply it works perfectly
                                            below are my readings
                                            with the original charger only
                                            JBATT1
                                            PIN1 0.22V
                                            PIN2 0.22V
                                            PIN3 0.45V
                                            PIN4 0.45V
                                            PIN5 O.43V
                                            PIN6 0V
                                            PIN7 GND
                                            PIN8...
                                            11-20-2021, 08:32 AM
                                          • zaurus81
                                            HP 15-cb028nl (dag75ambad0 rev. d) no charge battery
                                            by zaurus81
                                            Hi all, I have a HP 15-cb028nl (dag75ambad0 rev. d) that turns on but does not charge the battery. The laptop arrived with the super I/O (ITE IT8987E BXA) burned. After replacing the EC, it turns on but does not charge the battery. Below are the voltages on the pins of the bq24738h, with and without the battery inserted:
                                            WITHOUT BATTERY WITH BATTERY
                                            PIN1 (ACN)= 19.76 V PIN1 (ACN)= 19.76 V
                                            05-06-2025, 09:48 AM
                                          • DrFalken
                                            Honor MagicBook X 16 mod. BRN-F56 dead
                                            by DrFalken
                                            Good morning!
                                            A customer just brought in an Honor MagicBook X 16 mod. BRN-F56, motherboard P/N Fermi_MB NB6269A_MB_V4, not working (no power LED, no charging LED, nothing)
                                            He said he had been using an aftermarket power supply for a while, but noticed that it suddenly stopped charging and when the battery was completely dead the laptop would not turn on, even with the original (working) power supply.
                                            On the power connector, on the motherboard side, I measure 20V.
                                            With the thermal imaging camera I found a component labeled 2920J (TSOP5) that, when I supply power, increases...
                                            01-29-2025, 03:41 AM
                                          • danro
                                            Owon HDS2202S oscilloscope
                                            by danro
                                            I have this OWON HDS2202S oscilloscope that worked fine until it was used with the wrong probes mounted in the wrong place.
                                            It is not completely dead, it still fulfills some functions. I opened it and found some damaged components inside. I have identified the rest but I cannot identify this IC. I don't think I can find the diagram, but can someone help me identify this component?
                                            It seems to be an LDO regulator. I identified it like this:
                                            Pin1 - Vin
                                            Pin2 - GND
                                            Pin3 - ? (connected with pin1)
                                            Pin4 - ADJ ? (resistive divider between Vout and...
                                            07-25-2024, 10:46 AM
                                          • DriversScrew
                                            Need help to identify SOT23-5 step-down converter to 3.3V marking E16q9
                                            by DriversScrew
                                            Hello everybody,
                                            I need to replace a shorted SOT23-5 step down converter in a consumer audio device marking E16q9. What I found out from the board layout and measurements:
                                            Vin: 5,0V
                                            Vout: 3,3V (connecting to all 3V3 inputs of a N32905U3DN)
                                            Pin1: ? (perhaps enable)
                                            Pin2: GND
                                            Pin3: Vout - connected to 3ยต3 coil
                                            Pin4: Vin
                                            Pin5: Feedback, voltage divider, two resistors connect Vout-Pin5-GND, 680k+133k
                                            I searched many datasheets, but no one seemed to match according the surrounding components.
                                            Best similar parts I found were...
                                            12-21-2023, 07:06 AM
