Hie I have a Lenovo laptop
Lenovo Ideapad 100-14IBY AIVP1-AIVP2 LA-C771P rev 1.0
it's working only on the bench power supply when I put the battery it doesn't power on. when I also use the original charger it doesn't power. the batter Is fully charged, I used another laptop to charge the battery. but when I use a bench power supply it works perfectly
below are my readings
with the original charger only
JBATT1
PIN1 0.22V
PIN2 0.22V
PIN3 0.45V
PIN4 0.45V
PIN5 O.43V
PIN6 0V
PIN7 GND
PIN8 GND
JDCIN1
PIN1 19.8V
PIN2 19.8V
PIN3 GND
PIN4 GND
PIN5 0V
Other Voltages
+3VALW Not present on the Power button and other areas
with the original charger and battery
JBATT1
PIN1 11.23V
PIN2 11.23V
PIN3 0.45V
PIN4 0.45V
PIN5 O.43V
PIN6 0V
PIN7 GND
PIN8 GND
JDCIN1
PIN1 19.8V
PIN2 19.8V
PIN3 GND
PIN4 GND
PIN5 0V
Other Voltages
with the bench power supply only @ 20V 1.5A
JBATT1
PIN1 0.22V
PIN2 0.22V
PIN3 3.03V
PIN4 3.03V
PIN5 2.90V
PIN6 0V
PIN7 GND
PIN8 GND
JDCIN1
PIN1 19.8V
PIN2 19.8V
PIN3 GND
PIN4 GND
PIN5 0V
Other Voltages
+3VALW measuring 3.03V on the Power button but on the battery connector is 2.90v
with the bench power supply only @ 20V 1.5A with battery
JBATT1
PIN1 12V
PIN2 12V
PIN3 3.03V
PIN4 3.03V
PIN5 0.16V
PIN6 0V
PIN7 GND
PIN8 GND
JDCIN1
PIN1 19.8V
PIN2 19.8V
PIN3 GND
PIN4 GND
PIN5 0V
Other Voltages
+3VALW measuring 3.03V on the Power button but on the battery connector is 0.16v
bech power supply reading
with battery connected
when the motherboard is On 20V 0.761A
when the motherboard is off 20V 0.02A
without battery
when the motherboard is on 20V 0.146A
when the motherboard is off 20V 0.016A
i have also noticed that when i switch on the motherboard while battery is connected and remove the charger the motherboard is still powering on from the battery. but if i want to power on the motherboard directly from the battery without the power supply nothing happens
JBATT1
PIN1 0.22V
PIN2 0.22V
PIN3 0.45V
PIN4 0.45V
PIN5 O.43V
PIN6 0V
PIN7 GND
PIN8 GND
JDCIN1
PIN1 19.8V
PIN2 19.8V
PIN3 GND
PIN4 GND
PIN5 0V
Other Voltages
JBATT1
PIN1 11.23V
PIN2 11.23V
PIN3 0.45V
PIN4 0.45V
PIN5 O.43V
PIN6 0V
PIN7 GND
PIN8 GND
JDCIN1
PIN1 19.8V
PIN2 19.8V
PIN3 GND
PIN4 GND
PIN5 0V
Other Voltages
JBATT1
PIN1 0.22V
PIN2 0.22V
PIN3 3.03V
PIN4 3.03V
PIN5 2.90V
PIN6 0V
PIN7 GND
PIN8 GND
JDCIN1
PIN1 19.8V
PIN2 19.8V
PIN3 GND
PIN4 GND
PIN5 0V
Other Voltages
JBATT1
PIN1 12V
PIN2 12V
PIN3 3.03V
PIN4 3.03V
PIN5 0.16V
PIN6 0V
PIN7 GND
PIN8 GND
JDCIN1
PIN1 19.8V
PIN2 19.8V
PIN3 GND
PIN4 GND
PIN5 0V
Other Voltages
without battery
