Honor MagicBook X 16 mod. BRN-F56 dead
  • DrFalken
    • May 2008
    • 122
    Good morning!
    A customer just brought in an Honor MagicBook X 16 mod. BRN-F56, motherboard P/N Fermi_MB NB6269A_MB_V4, not working (no power LED, no charging LED, nothing)
    He said he had been using an aftermarket power supply for a while, but noticed that it suddenly stopped charging and when the battery was completely dead the laptop would not turn on, even with the original (working) power supply.
    On the power connector, on the motherboard side, I measure 20V.
    With the thermal imaging camera I found a component labeled 2920J (TSOP5) that, when I supply power, increases the temperature by 3-4°C: I also noticed that there seems to be a small hole on its surface
    The voltages measured are:
    Pin1 = 19.77V
    Pin2 = GND
    Pin3 = 19.58V
    Pin4 = 1.247V
    Pin5 = 5.207V
    All other components seem cool.
    What else can I check ?
    Thank you !!
    Update: I checked again and what looked like a small hole was just dirt, maybe resin or flux, which I removed with a plastic tab
    Click image for larger version  Name:	2920J.jpg Views:	0 Size:	123.0 KB ID:	3559375
