when i turn on, Philliips TV is not on
  • Nish
    • Sep 2013
    • 124
    Re: when i turn on, Philliips TV is not on
    I test with continuity test The IC901
    Pin 8 is gnd So black probe on it and touch pin3 , it has beep. Also once I plug the board outlet and unplug check pin5 has beep for few min then stop.
    • R_J
      • Jun 2012
      • 9624
      You can't check the ic with a meter.
      • Nish
        • Sep 2013
        • 124
        Quick question R_J: I see too many arduino scope online. Do you think I can use it here? If yes I can build one.
        • Nish
          • Sep 2013
          • 124
          Never mind, arduino is 5v one. I can't use it here
          • Nish
            • Sep 2013
            • 124
            Is it useable to buy?
            https://www.newegg.ca/p/2A7-00BD-00018
            • Nish
              • Sep 2013
              • 124
              I found new IC and replaced it. I got 0.210v at C951A and going down. Now 0.183.
              • nomoresonys
                • 12331
                • U.S.
                #87
                If you had a 5 dollar esr tester you could have taken those caps out and tested them, as it stands you don't even know if they are good or not.
                • vinceroger69
                  • Mar 2012
                  • 6714
                  • uk
                  #88
                  what is the power supply board number?
                  • Nish
                    • Sep 2013
                    • 124
                    dsp-484ap upbpspdel003
                    • Nish
                      • Sep 2013
                      • 124
                      I have one I will test and update soon
                      • Nish
                        • Sep 2013
                        • 124
                        Can I buy this power supply?
                        https://www.ebay.ca/itm/TV-Power-Sup...sAAOSwwqVcD9IR
                        • Nish
                          • Sep 2013
                          • 124
                          C951A = 0.036 (10v 1000uF)
                          C951B = 0.027 (10v 1000uF)
                          C952 = 0.062 (10v 1000uF)
                          C912 = 0.573 (100v 22uF)
                          C906 = 0.042 (35v 220uF)
                          Is it possible to get replacement IC for DNP005 (IC901).
                          • R_J
                            • Jun 2012
                            • 9624
                            Where did you get the ic that is in there now after the original blew up?
                            Maybe that has been the problem all along. There is no datasheet on this ic, so it's hard to know the specs (operating frequency etc.)
                            • Nish
                              • Sep 2013
                              • 124
                              I bought using ebay and from China.
                              R_J: is there any scope that I can get for 200. I know most of it above 350.
                                Post #92
                                "Is it possible to get replacement IC for DNP005 (IC901)."
                                But you said you already replace it, so what did you replace it with?
                                Post #86:
                                "I found new IC and replaced it. I got 0.210v at C951A and going down. Now 0.183."
                                • Nish
                                  • Sep 2013
                                  • 124
                                  Originally posted by budm
                                  Post #92
                                  Post #86:
                                  I bought 3 of DNP005. I blow out and I had extra to replace again
                                  • Nish
                                    • Sep 2013
                                    • 124
                                    Quick question : ZD907 (UDZSTE-17), it's zener diode. Is it 5.6v or 15v? It's in the standby circuit.
                                    • R_J
                                      • Jun 2012
                                      • 9624
                                      ZD907 is a PDZ13b, 13volt zener
                                      • Nish
                                        • Sep 2013
                                        • 124
                                        Sorry I want to know ZD904 (UDZSTE-17). Is it 5.6v or 15v? Near C912
                                        • R_J
                                          • Jun 2012
                                          • 9624
                                          What is the number or letter on the diode? You may need to clean the top with alcohol to read it,
                                          There is no datasheet for the ic, but C912 is rated for 100v so this ic's VCC might be higher than other similar pwm ic's.
                                          • rabsonnjala
                                            LENOVO IDEAPAD 100 works only on bench power supply
                                            by rabsonnjala
                                            Hie I have a Lenovo laptop
                                            Lenovo Ideapad 100-14IBY AIVP1-AIVP2 LA-C771P rev 1.0
                                            it's working only on the bench power supply when I put the battery it doesn't power on. when I also use the original charger it doesn't power. the batter Is fully charged, I used another laptop to charge the battery. but when I use a bench power supply it works perfectly
                                            below are my readings
                                            with the original charger only
                                            JBATT1
                                            PIN1 0.22V
                                            PIN2 0.22V
                                            PIN3 0.45V
                                            PIN4 0.45V
                                            PIN5 O.43V
                                            PIN6 0V
                                            PIN7 GND
                                            PIN8...
                                            11-20-2021, 08:32 AM
                                          • zaurus81
                                            HP 15-cb028nl (dag75ambad0 rev. d) no charge battery
                                            by zaurus81
                                            Hi all, I have a HP 15-cb028nl (dag75ambad0 rev. d) that turns on but does not charge the battery. The laptop arrived with the super I/O (ITE IT8987E BXA) burned. After replacing the EC, it turns on but does not charge the battery. Below are the voltages on the pins of the bq24738h, with and without the battery inserted:
                                            WITHOUT BATTERY WITH BATTERY
                                            PIN1 (ACN)= 19.76 V PIN1 (ACN)= 19.76 V
                                            05-06-2025, 09:48 AM
                                          • nassih
                                            Unknown smd component
                                            by nassih
                                            A component smd code:LX (DRL package 5pin SOT)mounts on a command card including the pin1:nc pin2:1.84v pin3:gnd pin4:1,77v pin5:3,2vcc, the pin4 is connected to the pin 66 of the MCU the pin2 is connected to a 10k resistor to a connector that communicates with another controller motor card. my question is that someone here in the community has already encountered this component, I confirm that it is not a low-power single Schmitt-trigger inverter because I have already tried it. thank you
                                            Yesterday, 10:33 AM
                                          • kalilinux25
                                            Lenovo Thinkpad T410 no power
                                            by kalilinux25
                                            DEVICE: Laptop
                                            Model: lenovo thiinkpad t410
                                            Board Id: 09A33-3 48.4FZ09.031
                                            NZM1H-8
                                            ISSUE: NO POWER
                                            From the first mosfet 20v is not passing through, pin 4 has 19.5v and the first mosfet is a P-CHANNEL mosfet (SI7121DN) i think the pin 4 should be lower to active the 1st mosfet to allow the 20v to pass to second mosfet ive check all for shorting in the board , i did;nt find in rails, so ive check the schematic and im suspecting that, my Q61 is faulty due to its pin 1 is 0.47ohms? im not pretty sure, hope someone can help me figure out this issue.
                                            07-13-2025, 07:56 AM
                                          • DrFalken
                                            Honor MagicBook X 16 mod. BRN-F56 dead
                                            by DrFalken
                                            Good morning!
                                            A customer just brought in an Honor MagicBook X 16 mod. BRN-F56, motherboard P/N Fermi_MB NB6269A_MB_V4, not working (no power LED, no charging LED, nothing)
                                            He said he had been using an aftermarket power supply for a while, but noticed that it suddenly stopped charging and when the battery was completely dead the laptop would not turn on, even with the original (working) power supply.
                                            On the power connector, on the motherboard side, I measure 20V.
                                            With the thermal imaging camera I found a component labeled 2920J (TSOP5) that, when I supply power, increases...
                                            01-29-2025, 03:41 AM
