Eeprom dump thread!
This is a sticky topic.
Re: Eeprom dump thread!
Dump for Smart Tech TV, main T.MSD309.BTU87 and panel V580DK1-LS1 58" STAND-BY PROBLEM! THANK YOU!Comment
Uploaded, thanks!Attached Filesif you find these attachements useful please consider making a small donation to the site
Your 25Q32 was damaged, I restored it + two more dumps Q16 and Q32 with a clean NVM.Attached Filesif you find these attachements useful please consider making a small donation to the site
Пытаться.Attached Filesif you find these attachements useful please consider making a small donation to the site
Hello, I sent you a link to the dump you asked for in a private message. You could also try to fix your non-working dumpComment
Thanks for the above file
Looking for Bush 24/207FDVD-S flash ic UF11 dump
Main: T.MSD309.B66B
Screen: BOER236WU1
I have the dump for the Bush 24/207F attached but would like to get the DVD going as well for it.
Attached is the corrupted dump and the Bush 24/207F both with the same screen
Good day to all, I have a big problem. I can't find the eeprom dump for the Eizo CS2740 monitor. The device doesn't turn on, the indicator just lights up. It responded to connecting to the PC once. The update process started with the standard program and then disconnected from the computer. The computer doesn't detect it anymore. If anyone has an eeprom dump, please share.
07-26-2025, 03:24 PM -
by jorpecHi, all
I need the dump/firmware for this tv, it was on a boot loop, i dont have the original corrupted dump because i used a pen drive with a firmware that solved the boot loop, initially it seemed it was ok but the tv has no sound
Thanks -
by my2k2Good day to every one,
I have AVR 171 the IC1504 (24C32) eeprom is corrupted not able to read.
Does anybody have an eeprom dump file? I really appreciate any help.
Thanks in advance.-
07-01-2024, 09:04 PM -
by (0)_(0)Hello, This might be a long shot, but I'm looking for an EEPROM dump for a HP Photosmart C4280 All-in-one printer.
The printer seems to be in cartridge alignment mode. Sometimes it print the alignment page and then hangs during the scanning step, sometimes it hangs during the printing process and sometimes it hangs during the boot process. If I let it idle for a while then it flashes the back-light of the top screen and there's a letter E. Bottom screen is asking me to restart it to no avail. I have to remove the power cable from the printer for a couple of minutes to make it work...02-17-2022, 09:09 PM -
P14s Gen 2
HT4B0/HP4B0/HT5B1/HT4B2
NM-D352 Rev 1.0
sn PF-35P15W
Requesting thunderbolt dump
also attached is the tbt dump. I extracted the bin from the cap file and modified it, not sure if it's correct. also didnt work....-
Channel: BIOS Requests ONLY!
- Loading...
