Eeprom dump thread!
This is a sticky topic.
So what does the firmware have to do with it? If it doesn't work for you via the remote control, check the remote control, try via a universal remote control. If it doesn't work, replace the IR receiver, make sure the pulses reach the processor...Comment
probao sam, ispravan daljinski, nece ni univerzalni. a ir prijemnik sa 4 pina,( 2 gnd, na jednom stalnih 5V, a na drugom 5V koji opada na 3,5V kada koristim daljinski), nemam takav ir da bi testirao ,mada sumnjam da je do njeg jer reagujeComment
Pozdrav prijatelji,
imam Toshiba 32el933g TV. Samo crveno svjetlo svijetli, ne pali se ni ništa. Kada sam ažurirao firmware, otkrio sam da se TV uključuje, ali nema slike. Mislim da se matrica ne podudara. Moja matrica je LG. Za drugu ne znam. Objavit ću originalni firmware od TV-a i novi ako netko zna kako ih uskladiti.Attached FilesPremium supporters get full download access and other benefits.
1 PhotoComment
Try.Pozdrav prijatelji,
Hi everyone, I have a 65" Philips TV, it turns on and after a while it restarts endlessly, I checked the power supply and everything is ok, I disconnected all the devices and the panel but it continues to restart, I assume it is a dump problem, below is the original dump
TV model 65PUS6523/12
Board model 703TQHPL433 715G8709-M0B-B01-005K
ThanksAttached FilesPremium supporters get full download access and other benefits.
Here is the dump for the Hisense 70H6570G and 70A6G. It fixed the corrupted EMMC issue that put the TV into a loop.
Board RSAG7.820.9783/ROH
https://****************/file/d/129h...usp=drive_linkComment
Hi does anyone have the firmware for a Panasonic 50lx650 main board 17mb185
Screen ves500qnzh-n2-z01
23798312
ThanksComment
by bhangal.05Hello everyone,
I am looking for a verified EEPROM .bin dump for a Canon LBP 2900B printer.
Device: Canon Laser Shot LBP 2900 / 2900B Logic Board / Formatter Part Number: RM1-3078 EEPROM Chip: (Look at the 8-pin chip on your board and type its number here, e.g., 24C64, 93C46, or W25Q32)
The Issue: Replaced the formatter board because the original was not recognized by USB. The new board takes print commands and the mechanics/lasers spin up normally, but it outputs a completely blank page. I strongly suspect the firmware inside the BIOS/EEPROM on this replacement...08-29-2026, 04:19 AM -
by holidayyyI am in desperate need of an EEPROM dump for a Sony Trinitron KV-9AD1 (Japanese model) or its North American equivalent, the KV-8AD10.
micom - Mitsubishi M50439-715SP
jungle - Sanyo LA7655N
eeprom - OKI MSM16911RS
If anyone happens to have this specific dump file or owns one of these models and is able to perform a dump for me, it would be a huge help.
I've been searching for this for a long time, so any leads or assistance would be greatly appreciated. Thank you so much in advance!01-03-2026, 06:08 PM -
by GjjgfjHi everyone,
I'm re-celling a Dell Latitude 505 battery (C1295 / NF398 - 11.1V, 4700mAh) and accidentally corrupted the EEPROM. I used the wrong I2C settings on my programmer instead of Microwire, overwriting my factory code with garbage.
I need a working donor .bin dump.
Board Specs:- PCB: Sony 1-684-189-41
- MCU: M37516 (Mask: G02)
- EEPROM: 93C56
Channel: BIOS Requests ONLY!
07-16-2026, 03:25 AM -
by ElectricManHello everyone,
I am working on an older Insignia NS-32E400NA14 LCD TV.
The Problem: The TV will not turn on and only displays a solid red standby light.
Troubleshooting done: I have successfully narrowed the issue down to a corrupted SPI flash chip. To test this, I swapped in a flash chip from a different, similar donor board. With that donor chip, the TV successfully powers on! However, because the donor chip came from a board configured for a different screen size and display interface, the resolution and display mapping are completely scrambled.
...09-04-2026, 06:41 PM -
Good day to all, I have a big problem. I can't find the eeprom dump for the Eizo CS2740 monitor. The device doesn't turn on, the indicator just lights up. It responded to connecting to the PC once. The update process started with the standard program and then disconnected from the computer. The computer doesn't detect it anymore. If anyone has an eeprom dump, please share.
07-26-2025, 03:24 PM -
- Loading...
