LG 70LB7100 no backlight after 2-5 min
  • madcow007
    • Nov 2010
    • 16
    I have a LG 70LB7100 just a few months out of warranty. When I power the set on it works perfectly for 2-5 minutes then the backlight will go out and audio will remain. I can power cycle the tv again and backlight returns.
    The tv is currently wall mounted so I'm unable to take photos of the boards until I get some help to remove it. I was wondering if anyone could recommend some trouble shooting steps to determine if its the power supply or the LED,s.
  • budwich
    • Jul 2015
    • 3097
    Re: LG 70LB7100 no backlight after 2-5 min
    Put on a uniform "color" test screen (preferably white) and see if you can see any issues on the screen before it goes out.
    • madcow007
      • Nov 2010
      • 16
      Budwich just ran the test with a white image and I seen no distortion then at around the 3 minute mark the backlights shut off.
      • ReeceyBurger123
        Never Give Up !
        • May 2014
        • 7325
        • Britain
        Theres a fault likely in the Led strings possibly with the little connectors that join the Leds breaking down. Check the threads about testing the return line voltage for the Leds see if you can spot anything thats an issue.
        • madcow007
          • Nov 2010
          • 16
          ReeceyBurger123 thanks for the reply I finally got the set down today I can see proper 52v until shutdown the area on the pcb where the fets are located look a bit brown from the top side and it feels warm to the touch after shut down but not HOT
          Photos attached please excuse typos and wall of txt I'm on mobile.
          • jetadm123
            • 2169
            When the set is up and running, you can try heating up the fets with a hair dryer to see if you can accelerate the backlight shutting down. If you're lucky, it might be a failing fet or a bad solder joint. Otherwise, it might be as Reecey suggested.
            • ReeceyBurger123
              Never Give Up !
              • May 2014
              • 7325
              • Britain
              Remove the Pcb and inspect for bad solder joints in that hot area.
              • madcow007
                • Nov 2010
                • 16
                Thanks for the reply guys I stressed the fets with a hair dryer and it seemed to quicken the time to shutdown. I didnt see any bad solder joints the set belongs to a friend and he is impatient so he decided to order a new power supply will update when it arrives.
                • jetadm123
                  • 2169
                  Just a suggestion: While you're waiting for a new supply, grab a soldering iron and touch up all the joints on those mosfets with some fresh solder. If that fixes the problem, then maybe return the supply you bought?
                  • ReeceyBurger123
                    Never Give Up !
                    • May 2014
                    • 7325
                    • Britain
                    Maybe get us an image of the bottom side of the Pcb ? Sounds like cold solder joints to me would have been a good idea to do that before ordering a part IMO but your on the right track at least
                    • thelmores
                      • Feb 2011
                      • 17
                      FWIW, have identical set that has same problem.
                      Replacing main and power supply did not fix problem. Almost certainly a panel issue.
                      Customer said he is going to donate the set, so we are going to see what we can learn. never disassembled panel before.....
                      • ReeceyBurger123
                        Never Give Up !
                        • May 2014
                        • 7325
                        • Britain
                        Hmm sounds like the Led string connectors or even the Leds then buddy. Is this Edge lit or full array ? Also if you take the screen apart be very care of the glass it cracks easy.
                        • DrewBeer
                          • Sep 2016
                          I'm glad i found this thread. Have the same problem with my 70LB7100. Just replaced the power supply, same problem, Sometimes it works for a few hours, and sometimes its a few minutes.
                          I haven't taken it down past the back panel, but i guess i might as well start digging. Did anyone get further with this problem?
                          • Help
                            • Dec 2016
                            • Virgin Islands
                            Any update to this problem?
                            • Help
                              • Dec 2016
                              • Virgin Islands
                              Did you look into the issue with lg70lb7100 no backlight when you got customer TV?
                              • gavric
                                • Jun 2011
                                • 65
                                Bump
                                Interested in any update to this, going thru same issue.
                                I actually opened screen up and glued up some led bulbs lenses that fell off and made bright spots on the screen and seen that one of the led strips was not lighting up. It was odd because first 8 leds were out then last 8 would work. power comes from side that is on non working leds side. Its exactly half of string 8 bulbs that are out of 16 in a row. There is 8 rows on leds. I messed with it some and led string came alive. I left tv on for a while, no problem. Tv worked for long time and all leds worked.
                                When I finally assembled tv without breaking glass tv decided to start shutting down random led strings on right side of screen only, sometimes after 15 minutes, sometimes 5, sometimes 2 minutes. Power cycling instantly turns screen nice and bright and all leds work until it acts up again. Each row of leds is separately powered by its own power input with three wires + - -, 52 VDC. Power supply looks burned up some just like poster above.
                                I did not trouble shoot power supply yet because i am so pissed of at it.
                                Anyone solved it?
                                • bult
                                  • Jun 2016
                                  • Sweden
                                  Bump!
                                  I would also know if anyone of you solved this issue with this model? I have the exactly same issue with mine. Backlight stays on for a while and then goes black. I was just about to order a new powerboard but then I stumbled upon this thread... So before i take the panel apart i would be nice to know if it is worth the effort.
                                  Thanks!
                                    I would try lowing the Backlights level to as low as possible first to see if the backlights will stay on longer.
                                    Providing the pictures of the whole backside of the TV showing all the boards will also help so we can see what we are dealing with.
                                    • truep
                                      • Aug 2010
                                      • 373
                                      As a general rule, NEVER run the backlights at 100% I set mine at 75, MAX of 80%. set it around 70% and it may work fine for a while. ( my 65" lasted 2 years till I found a new LED strip.
                                        BTW, turn them down on ALL inputs.
                                        • Mgiffune
                                          by Mgiffune
                                          06-09-2024, 10:28 AM
                                        • triplefour
                                          by triplefour
                                          09-13-2023, 10:43 PM
                                        • DanPoka
                                          Guide me through repairing a Dell p2210f LCD ccfl backlight monitor
                                          by DanPoka
                                          I bought this p2210f dell monitor to fix. Schematic is the same as p2210.
                                          Behaviour is that monitors comes on but then backlight switches off almost instantly. If I look with flashlight I can still find the "No signal message". So definitely a backlight issue. Trying to advance the issue I proved that the protection circuit is switching off the backlight by shorting out C3 and resistor to disable the INL chip then re enable by removing the short.
                                          This is where it gets interesting. When I disassembled the monitor to solder leads on c3 capacitor I noticed the backlight flickered...
                                          02-15-2025, 05:05 AM
                                        • Comp_Pro
                                          No Backlight Macbook A1990 820-01041
                                          by Comp_Pro
                                          Hello all,
                                          Am trying to figure out this backlight issue with this A1990 Macbook Pro.
                                          Tests performed:
                                          There is no backlight even with a good screen.
                                          Backlight IC is receiving the correct support voltages.
                                          Fuse F8400 ok
                                          Current sense resistor R8400 ok
                                          Backlight IC is receiving 3.3V on enable pin.
                                          Backlight IC receiving voltage from PPBUS_G3H, aprox 12.5V.
                                          Backlight IC receiving 5V from PP5V_G3S
                                          Backlight IC BKLT_SCL and BKLT_SDA both measure 0.545V diode mode to ground
                                          I2C_BKLT_SCL and I2C_BKLT_SDA both measure...
                                          05-06-2024, 10:23 PM
                                        • cheebster
                                          iPad Pro 12.9 5th Gen Backlight Issue
                                          by cheebster
                                          Hello, got an iPad Pro A2378 12.9 5th gen with no backlight. Got another test unit without screen, tested the screen, still no backlight with the test unit.
                                          Figured out the backlight on the screen was bad, ordred a new backlight from mobilesentrix, *carefully replaced it* without damaging the lcd, oh well.
                                          Final result, issue is still there, the screen has no back lights. So i'm back to square one, with 3 hours less and 100$ out, issue still on the screen.
                                          The panel is still ok, i can see the apple in the middle of the screen when it kicks in, just no backlight.
                                          Anyone...
                                          05-20-2025, 09:17 AM
