  • DanPoka
    • Jul 2023
    • 39
    • România
    This is where it gets interesting. When I disassembled the monitor to solder leads on c3 capacitor I noticed the backlight flickered at first but mostly it would stay on. What I had expected was that the backlight would turn off as previous but that didn't happen. So I thought what's different.. What was different was that the data cable from video processing board was disconnected from the LCD.
    ​​​​Sure enough when I put the monitor back together, monitor would come on and backlight switched off in a second. Now I could bring the backlight back on by shorting the leads I soldered on C3 and removing the short thus re-enableing INL chip.
    My question is what would cause this strange behavior?
  • DanPoka
    • Jul 2023
    • 39
    • România
    Here is schematic from Electrotanya
    Electronics forum for electronics experts to repair defective appliance.
    • DanPoka
      • Jul 2023
      • 39
      • România
      * I could bring the backlight back on but only for a second.. (By shorting and then releasing C3)
      • DanPoka
        • Jul 2023
        • 39
        • România
        Why would disconnecting data cable would result in different behavior from backlight?
        • DanPoka
          • Jul 2023
          • 39
          • România
          Mea culpa.. I also switched input of lamp 1 with lamp 2. I didn't realize..
          • DanPoka
            • Jul 2023
            • 39
            • România
            Any advice now, thanks..
            • DanPoka
              • Jul 2023
              • 39
              • România
              This morning it would mostly want to stay on. Then after a while hissing sound and won't turn on for more than 1 second. Hissing sound seemed close to inverter circuit. What do you say bad inverter circuit or bad lamp? Hissing sound was like adjusting speaker volume where speaker has defective volume potentiometer.
              • DanPoka
                • Jul 2023
                • 39
                • România
                After more testing I've come to the conclusion it is the lamps or at least one that is defective. I've seen it flicker like a bad neon lamp.
                So I've decided I will replace them with led lights. Which ones to buy? Please help
                • DanPoka
                  • Jul 2023
                  • 39
                  • România
                  Will these be good 19" 417 mm?
                  • Zilicon
                    NEWSYNC B27F165 MONITOR HAS NO BACKLIGHT. board no: JY85QS_UPH_LS_R10.3
                    by Zilicon
                    Greetings everyone.
                    Please I need help with the above monitor.
                    Below is the summary of what happened and what I have done:
                    The monitor started by turning off 2 seconds after it was turned on. It displayed with a backlight when it turned on. However, the standby light remains on after it is turned off on its own, I have to press the power button again to turn it on, but it will go back to standby after 2 seconds.
                    The backlight driver IC is 0b3350cp.
                    I applied a 370k SMD resistor on the CMP pin which is pin 6, while the other...
                    11-07-2023, 09:12 AM
                  • ttmi100x
                    HANNSG Hi221 -- 2 secs to black feat. CCFL flicker & "burn" marks on power board
                    by ttmi100x
                    Greetings everyone,
                    I have a HANNSG Hi221 monitor that exhibits two seconds to black issues (backlight goes off, display is still on as confirmed by shining a flashlight on it) with some additional oddities...
                    The monitor failed on me with a standard "2 seconds to black" some time ago prompting me to initially replace most of the electrolytic capacitors (some of them were bulging/leaking).
                    Things kinda sorta worked for a night, then the problem returned along with some flickering and "buzzing" noises.
                    Upon closer inspection...
                    07-31-2024, 06:36 PM
                    by momaka
                    03-15-2023, 10:17 PM
                  • turmix
                    AOC U34G3XM, new monitor, black screen with backlight on, possible shortcircuit during dissassembly
                    by turmix
                    Hello, I'm working on a new deskmod pc project and have a problem with my monitor, an AOC U34G3XM, well, I may have bricked it.
                    The monitor was dismanteled and the separate parts parts integrated in the desk. the screen panel alone is on the upper part, and main board/video board + power board on the back of the desk (not enough place on the cover to fit it)
                    At first everything was working smoothly, then I decided to change the connexion between the video board and the screen for a longer one. Still working fine
                    During another reassembly, I made a mistake, and...
                    01-29-2024, 03:48 AM
                  • Fernon@Repair
                    Viewsonic VA3209 Monitor Standby Ambler Led Blinking No Display No Backlight Solution pls
                    by Fernon@Repair
                    I attached my viewsonic 32 monitor motherboard image
                    when i connect power monitor blue light power up . when press power button blue led change amber color and continually blinking. no display and no backlight.
                    number 1 and 2 (marked image ) power supplies 1st time generate when press power button and after change led amber color both voltages goes 0V...
                    01-08-2026, 01:53 AM
