LG 70LB7100 no backlight after 2-5 min
  • floki
    • Nov 2018
    • 12
    Re: LG 70LB7100 no backlight after 2-5 min
    Anyone figure anything out with this? I was given this TV for free from a guy and it's doing this exact same thing - backlight stays on for about 45 seconds, then shuts off. Sound continues to work and everything. Replaced the main board, and that didn't fix anything. I'm considering replacing all LED's, but was hoping someone would have confirmation that that's the issue before spending the time and money
      Did you try turning down the backlights level as suggested to see if it will stay on longer?
      • floki
        • Nov 2018
        • 12
        No, i'll try that tonight and post results. Thank you so much for the reply!
        • floki
          • Nov 2018
          • 12
          So unfortunately I don't have the remote for this TV, and it doesn't appear that the little joystick button on the bottom of the TV will adjust brightness.....I'll have to look around for a remote for this model TV so I can try the brightness adjustment. With my TV, it always blacks out at the same time, about 30 seconds without fail, it never changes. It's almost like it might be the TCON board, since when the monitor is lit there is no flickering or dead spots, it looks perfect, then 30 seconds or so, it blacks.
          • budwich
            • Jul 2015
            • 3097
            disconnect the cables from the tcon to panel, one at a time to see if it changes anything, go from there.
            • sintv
              • Feb 2015
              • 37
              • scotland
              #26
              If this model has 2 strips joined in middle, I would hardwire every one.
              • ljintexas
                LJinTexas
                • Jan 2015
                • 669
                Biggest set I have successfully replaced LED arrays on is a 52". That was very trickey and I made a ramp and blocked it up to the right level next to tv on another bench. Anything any bigger is going to be impossible to support the lcd screen without cracks.
                • zomi
                  • Nov 2011
                  • 505
                  #28
                  use suctions cups
                  lift the screen using a second person and place on a table while u work on the set
                  https://www.youtube.com/watch?v=KTPJxkzkaSs&t=689s
                  • floki
                    • Nov 2018
                    • 12
                    i'll try this hopefully tonight. thank you. i got a remote on ebay but the display goes out too quickly for me to be able to see what i'm doing to dim the display down.....
                    • floki
                      • Nov 2018
                      • 12
                      well, i unplugged the ribbon cables going from the tcon to what i believe is called the main board, and the screen has now been on for like 10 minutes...which is WAY longer than ever before. it used to go out in like 5 - 10 seconds maximum. could it be there was a bad connection? gonna let it sit for a while with the screen on and see. i was able to then change the display setting to maximum power save, which dimmed the screen considerably, so not sure if that is helping or not...
                      • bman4
                        • Jul 2015
                        • 210
                        • canada
                        #31
                        Feel for warmth around the frame on right or left might be driver tab. This tv may have the tabs built into the main panel tab bonds so feel what ever side the tcon is on . Also try shining a light to see if you see anything and this will determine if its a back light.
                        • floki
                          • Nov 2018
                          • 12
                          yea, it went out after like 30 minutes. no warmth felt at all, all sides seem cooler than room temperature. i shined a flashlight on the screen while a movie was playing and i COULD see the picture in the backround.
                          Must be the backlight then, eh?
                            Well, did you try turning down the backlights level (not brightness) to as low as possible as I suggested?
                            • floki
                              • Nov 2018
                              • 12
                              The only thing I can find on adjusting brightness on this model is just adjusting the picture to energy saving mode, which I did and the brightness dimmed way down. i did that after disconnecting those two cables I mentioned earlier. after disconnecting the cables and reconnecting the leds stayed on for long enough for me to adjust that setting, and that's when it stayed on for like 30 minutes (which is WAYYYY longer than it had stayed on before)
                              • DXseekerMO
                                • Feb 2018
                                • 1119
                                • US
                                #35
                                Sure sounds like a problem in the LED string to me, like something getting up to operating temperature and going open circuit.
                                They call me......."threadkiller"
                                  Your LEDs are bad.
                                  • floki
                                    • Nov 2018
                                    • 12
                                    Your LEDs are bad.
                                    can you guys recommend a place where I can get replacements? is that a super difficult fix? I've heard it can be tedious handling the screen itself to gain access to the leds
                                    • DXseekerMO
                                      • Feb 2018
                                      • 1119
                                      • US
                                      #38
                                      On a screen that size you're going to need help, steady hands and suction cups. If you've never pulled/handled an LCD Display I STRONGLY recommend you go to a recycle center and see if they have a similar TV with a good display that size and practice on it first. If you're unfamiliar with how a screen that size acts and flexes when lifted out you will surely break it.
                                      This is the listing on those LED strips, one row only and are the only ones available right now from ShopJimmy.com. The full set is out of stock.
                                      https://www.shopjimmy.com/lg-innotek...w-3-strips.htm
                                      • floki
                                        • Nov 2018
                                        • 12
                                        Thanks much for your help. Do you happen to know how many rows this TV takes? I haven't taken it all the way apart yet.
                                        • floki
                                          • Nov 2018
                                          • 12
                                          I wanna say there are 3 rows, but not sure...in other words I think i'd need to order 3 of these strips
                                          • Mgiffune
                                            by Mgiffune
                                            06-09-2024, 10:28 AM
                                          • triplefour
                                            by triplefour
                                            09-13-2023, 10:43 PM
                                          • DanPoka
                                            by DanPoka
                                            02-15-2025, 05:05 AM
                                          • Comp_Pro
                                            No Backlight Macbook A1990 820-01041
                                            by Comp_Pro
                                            Hello all,
                                            Am trying to figure out this backlight issue with this A1990 Macbook Pro.
                                            Tests performed:
                                            There is no backlight even with a good screen.
                                            Backlight IC is receiving the correct support voltages.
                                            Fuse F8400 ok
                                            Current sense resistor R8400 ok
                                            Backlight IC is receiving 3.3V on enable pin.
                                            Backlight IC receiving voltage from PPBUS_G3H, aprox 12.5V.
                                            Backlight IC receiving 5V from PP5V_G3S
                                            Backlight IC BKLT_SCL and BKLT_SDA both measure 0.545V diode mode to ground
                                            I2C_BKLT_SCL and I2C_BKLT_SDA both measure...
                                            05-06-2024, 10:23 PM
                                          • cheebster
                                            iPad Pro 12.9 5th Gen Backlight Issue
                                            by cheebster
                                            Hello, got an iPad Pro A2378 12.9 5th gen with no backlight. Got another test unit without screen, tested the screen, still no backlight with the test unit.
                                            Figured out the backlight on the screen was bad, ordred a new backlight from mobilesentrix, *carefully replaced it* without damaging the lcd, oh well.
                                            Final result, issue is still there, the screen has no back lights. So i'm back to square one, with 3 hours less and 100$ out, issue still on the screen.
                                            The panel is still ok, i can see the apple in the middle of the screen when it kicks in, just no backlight.
                                            Anyone...
                                            05-20-2025, 09:17 AM
