sony KDL-46S4100 proper voltage
    Re: sony KDL-46S4100 proper voltage
    This training manual may help.
      I was thinking there's supposed to be a red standby light on front, when tv is off and plugged in but none of my working tvs have that, it must be normal.
      See page 26 of the user manual.
        Power supply SCH.
          • 12276
          • U.S.
          yes thats the manual I've been reading, it helps a lot, I think I need a good video tutorial on checking mainboard check points, thanks Budm.
            • 12276
            • U.S.
            was looking at the shopjimmy site, they keep advising people that their panel is probably bad, I'm starting to think this panel may be shot.
              • 12276
              • U.S.
              #26
              can't get a menu, flow chart says if 12 and 3.3 are good at g board then go for the a board but says if no menu seen, then it's lvds cable, tcon or panel, tried a couple different tcons, same results.
                • 12276
                • U.S.
                #27
                seen so many posts by people trying to fix these KDL models, I don't think I'll even attempt to fix another like it. lol.
                  • 12276
                  • U.S.
                  #28
                  sony doesnt show firmware for this KDL-46S4100; but going down the line it does have updates for kdl-46s504 and kdl-46s5100, wonder what do you good folks think of trying one of those?
                    • 12276
                    • U.S.
                    #29
                    thinking its a bad lvds cable maybe.
                      • 12276
                      • U.S.
                      #30
                      I was getting the solid red, green, blue then striped loop on screen, that seems to have went away, I got different a board, with the first one I have to unplug the bl-on connector from a board to g board, then backlights come on, soon as the connector make contact the lights go off, with second a board, I can have the bl-on connected but if everything is hooked up no backlight or anything, if I disconect lvds cable from a board side, backlights come on in 8 seconds BUT if unplug lvds cable from tcon side, no backlighs or anything and whatever I do the sony logo never lights up, not sure if it is suppose to and I never get a menu.
                        • 12276
                        • U.S.
                        #31
                        serial 1231952, says made in mexico, panel # LTZ460HB10.
                        • R_J
                          • 9588
                          I have one of these tv's and the problem was no video, it was a tab bond problem, I repaired it but still is intermitint
                          https://www.badcaps.net/forum/showth...ht=KDL-46S4100
                            • 12276
                            • U.S.
                            #33
                            not sure, was getting a test pattern loop, now that's gone, just solid color screen but only with lvds cable unplugged from the a board side, when lvds cable unplugged from tcon side, no backlight or anything.
                              • 12276
                              • U.S.
                              #34
                              quick question, anyone with a proper working sony kdl model, do you have a red standby light, when tv is off and plugged in?, Thanks.
                                • 12276
                                • U.S.
                                #35
                                have a phillips, jvc and sharp, working proper but none of them have red standby light when off and plugged in.
                                • R_J
                                  • 9588
                                  I just checked my Sony Kdl-46S4100, When it is pluged in there are no led's lit. only when the power button is pushed does a green led light up. when turned off the green led turns off.
                                    • 12276
                                    • U.S.
                                    #37
                                    thanks RJ.
                                    • Rider
                                      • Oct 2014
                                      • 8
                                      I have a kdl-40ex720 and it has a red led on standby
                                        • 12276
                                        • U.S.
                                        #39
                                        hmm, I can't figure it out, unless some models do and some don't, very curious, Thanks Rider.
                                        • splitcrete
                                          • Dec 2012
                                          • 387
                                          • usa
                                          #40
                                          My KDL-46xbr has a green light while on, and no red standby. Same with my KDL-46w4100
                                          • Fernon@Repair
                                            Gigabyte Z490 Gaming X Motherboard No VCORE Voltage
                                            by Fernon@Repair
                                            i have Gigabyte Z490 Gaming X Motherboard .it has a power on no display fault .. no vcore voltage and debug led stuck CPU LED .
                                            VCCIO voltage ok
                                            VCCSA Voltage OK
                                            VCCPLL Voltage OK
                                            Ram Voltage ok
                                            RamVTT OK
                                            VPP 2.5 OK
                                            But No Core Voltage
                                            and i want to this vrm ic datasheet or pinout (ISL69269)
                                            anyone have this ic pinout voltages?...
                                            06-25-2025, 07:19 AM
                                            Trip light 2400 watt line conditioner bought used issue with low voltage oscillation going on between relays
                                            by sam_sam_sam
                                            I found two capacitors on the board and one of the leads on one capacitor had bad soldering joint and the other joint connections not much better and there were several soldering joints that way to much flux around the joint redid several of them
                                            The capacitors were a non brand that I did not recognize they got replaced and now it does not oscillating between relay but what concerns me a little bit is when the voltage is a little bit low the output voltage is around 130 volts and then drops down to 115 volts this happens around 105 to 108 volts if remember correctly
                                            Now...
                                            06-09-2024, 10:57 AM
                                          • Carlos#2003%
                                            Schematic de una Sony VAIO PCG-41217u, Sony VPCSB45FL (MBX-237), 1p-0117j01-a012 mbx-237.
                                            by Carlos#2003%
                                            Buenas mi nombre es carlos me uni al foro porque estoy buscando el schematic de una sony vaio pcg-41217u otras formas de escribirlo son 1p-0117j01-a012 mbx-237 numero de placa revision 1.2 o Sony VPCSB (MBX-237), en fin me gustaria y ayudaria un monton si alguien me puede dar dichi svhematic para hacer las mediciones de una laptop de la mencionada anteriormente(Sony VAIO PCG-41217U) con el fin de repararla dejo de funcionar solo prende el led de la bateria al pulsar el boton de power el disco empiesa a hacer ruido de actividad pero los leds del frontas no reflejan acividad y no enciende la pantalla....
                                            02-15-2024, 07:52 PM
                                            ISL95831HRTZ ISL95831HRTZ-T ISL95831IRTZ ISL95831IRTZ-T Voltage Regulator Datasheet
                                            3+1 Voltage Regulator for IMVP-7/VR12 CPUs
                                            Compliant with IMVP-7/VR12, the ISL95831 provides a complete solution for microprocessor and graphic processor
                                            core power supply. It provides two Voltage Regulators (VRs) with three integrated gate drivers. The first VR can be
                                            configured as 3-, 2- or 1-phase VR while the second output is 1- phase VR, providing maximum flexibility. The two VRs share the
                                            serial control bus to communicate with the CPU and achieve lower cost and smaller board area compared with the two chip approach.
                                            Based on Intersil's Robust Ripple Regulator...
                                            11-05-2024, 03:24 PM
                                          • ruletero
                                            Acer a515-43 low battery charge voltage
                                            by ruletero
                                            Hi
                                            Acer A515-43
                                            LA-H801P
                                            Fail: Does not charge battery, has low voltaje on connector.
                                            Laptop didn't want to turn on, only charge led blinked.
                                            I found PQB5 (mosfet high battery charger) in short, voltaje in +12.6V_BATT was 19 v ...
                                            I changed it, changed PQB6 too and now battery charger voltage is 4.4V but battery is 3 cell, 11.25v, then is very low to charging.
                                            Laptop turns on without battery and works fine, but with battery turns on and turns off inmediately, I suspect battery bad but I don't know...
                                            10-24-2022, 02:31 PM
