sony KDL-46S4100 proper voltage
  • splitcrete
    • Dec 2012
    • 387
    • usa
    #81
    Re: sony KDL-46S4100 proper voltage
    Mine is working like new. If you want a working board (needs software download) E-Mail me your address,and I will send it to you on Friday. USPS ground No charge someday I may need some help...
    • nomoresonys
      • 12331
      • U.S.
      #82
      THANK YOU, this tv is driving me bonkers.
      • nomoresonys
        • 12331
        • U.S.
        #83
        I'll send my email address in a pm, Thanks a ton. oh ok I see the email option.
        • nomoresonys
          • 12331
          • U.S.
          #84
          maybe it isn't just the main, tv just shuts itself off, won't turn back on, off for a day maybe an hour, it might turn back on, thinking its a cap issue on the power supply, even tho all the proper voltages are there, does that seem plausible?, Thanks.
          • nomoresonys
            • 12331
            • U.S.
            #85
            anyone know which cap/s on power supply, would make tv just shut off?, thanks.
            • nomoresonys
              • 12331
              • U.S.
              #86
              this tv is strange, on the stand upright, it won't come on or only stays on about 10 minutes, off the stand face down it's been playing fine for about 3 hours now.
              • nomoresonys
                • 12331
                • U.S.
                #87
                wrong post
                • freakaftr8
                  • Oct 2012
                  • 3743
                  I ran into this problem a while ago on an S 4100 and it turned out that if I heat the main I see back side we're all the small SMD components are the TV would stay on. I would think that reflowing the main processor would fix it but I tried and that did not I believe it's a small SMD component on the backside of the processor changing value probably a resistor or a capacitor. But there are so darn many back there but it's hard to tell which one it is
                  But of couse I did have a flashing led error although.
                  • nomoresonys
                    • 12331
                    • U.S.
                    #89
                    have 3 mainboards for this tv acting the same way, thats what makes me suspect the power supply, but the power supply voltages are correct, wondering if it's a bad or weak/intermittent cap?
                    • nomoresonys
                      • 12331
                      • U.S.
                      #90
                      anyone know if this would be good for testing capacitance of capacitors?, thanks. http://www.ebay.com/itm/enhanced-Tra...item4ad9958236
                      • vinceroger69
                        • Mar 2012
                        • 6714
                        • uk
                        #91
                        basically same tester i have got seems to do the job ok but as you know you have to remove each capacitor to test.
                        Regarding your tv it seems odd it only goes off stood up maybe on the psu has it got transistors etc mounted on heat sinks im wondering if when heated up the weight of the heatsink maybe causing a broken solder joint on a transitor/diode/transformer leg etc just a thought.
                        • nomoresonys
                          • 12331
                          • U.S.
                          #92
                          makes sense to me, I'll try running some solder over m, thanks vinceroger69.
                          • nomoresonys
                            • 12331
                            • U.S.
                            #93
                            my original mainboard seems to have problem/s, put that in parts bin, touched up 3 or 4 joints on power supply, they didnt look bad, been running with no problems for a few hours now, might have fixed it, fingers crossed, thanks Splitcrete, Vinceroger69, and everyone who helped or tried to, I hope I can help you guys on something. Remember folks you can buy capacitors and stuff right here at Bad Caps.
                            • nomoresonys
                              • 12331
                              • U.S.
                              #94
                              well was working fine, now I just tried to turn up volume with remote and it shut off and won't restart, it did that before I touched up some joints too, funny it would shut off while trying to adjust volume, anyone have this problem before?, Thanks.
                              • lookimback
                                • Aug 2013
                                • 1489
                                One thing you have to remember on these older Sony's, is that you have to go by your serial number when you order a replacement main board. If you get one from the wrong serial range, you will just get a blank screen. I went through hell with a KDL-40W4100 last spring. Three different mains before I got one which worked. And all the numbers on the boards, even the boards themselves, are all identical. It's a firmware mismatch I think. I tried switching eeproms too, but peeled traces. I won't even try to get a Sony board on eBay. Shopjimmy or nothing. Too many headaches. Next one I get, I'm going to play around with JTAG and see if I can dump the firmware and flash new.
                                ------------signature starts here------------
                                • nomoresonys
                                  • 12331
                                  • U.S.
                                  #96
                                  its like pulling teeth finding firmware, had a long talk with samsung, they said as a rule they only go back 3 years, and most of the time, they don't even issue updates unless theres a well reported problem, couldnt find firmware on sony ether, found some here from capkid, Thanks capkid, now if I could just figure out why it turns off when I try turning channel or turning up volume.
                                  • lookimback
                                    • Aug 2013
                                    • 1489
                                    I found firmware on Sony's site for the 40W4100 and also , I think a 40SL140. But I think with JTAG you can download the firmware from the eeprom. Unless they have it locked somehow.
                                    • nomoresonys
                                      • 12331
                                      • U.S.
                                      #98
                                      not sure, switched out tcon with spare, tv seems to run ok but when I try streaming thru my android device it goes black, no pic. or sound, it seems like it can't handle the little bit of extra work or something, suspect a marginal cap on power supply, time to quit guessing and get an esr meter, anyone encounter this problem?, thanks.
                                      • nomoresonys
                                        • 12331
                                        • U.S.
                                        #99
                                        must be heat issue, took back off no problems, leaving back off, threw it on the stand, DONE, done messing with it, if something goes out, then maybe I can track down the problem, Thanks for the help.
                                        • Fernon@Repair
                                          Gigabyte Z490 Gaming X Motherboard No VCORE Voltage
                                          by Fernon@Repair
                                          i have Gigabyte Z490 Gaming X Motherboard .it has a power on no display fault .. no vcore voltage and debug led stuck CPU LED .
                                          VCCIO voltage ok
                                          VCCSA Voltage OK
                                          VCCPLL Voltage OK
                                          Ram Voltage ok
                                          RamVTT OK
                                          VPP 2.5 OK
                                          But No Core Voltage
                                          and i want to this vrm ic datasheet or pinout (ISL69269)
                                          anyone have this ic pinout voltages?...
                                          06-25-2025, 07:19 AM
                                          Trip light 2400 watt line conditioner bought used issue with low voltage oscillation going on between relays
                                          I found two capacitors on the board and one of the leads on one capacitor had bad soldering joint and the other joint connections not much better and there were several soldering joints that way to much flux around the joint redid several of them
                                          The capacitors were a non brand that I did not recognize they got replaced and now it does not oscillating between relay but what concerns me a little bit is when the voltage is a little bit low the output voltage is around 130 volts and then drops down to 115 volts this happens around 105 to 108 volts if remember correctly
                                          Now...
                                          06-09-2024, 10:57 AM
                                        • Carlos#2003%
                                          Schematic de una Sony VAIO PCG-41217u, Sony VPCSB45FL (MBX-237), 1p-0117j01-a012 mbx-237.
                                          by Carlos#2003%
                                          Buenas mi nombre es carlos me uni al foro porque estoy buscando el schematic de una sony vaio pcg-41217u otras formas de escribirlo son 1p-0117j01-a012 mbx-237 numero de placa revision 1.2 o Sony VPCSB (MBX-237), en fin me gustaria y ayudaria un monton si alguien me puede dar dichi svhematic para hacer las mediciones de una laptop de la mencionada anteriormente(Sony VAIO PCG-41217U) con el fin de repararla dejo de funcionar solo prende el led de la bateria al pulsar el boton de power el disco empiesa a hacer ruido de actividad pero los leds del frontas no reflejan acividad y no enciende la pantalla....
                                          02-15-2024, 07:52 PM
                                          ISL95831HRTZ ISL95831HRTZ-T ISL95831IRTZ ISL95831IRTZ-T Voltage Regulator Datasheet
                                          3+1 Voltage Regulator for IMVP-7/VR12 CPUs
                                          Compliant with IMVP-7/VR12, the ISL95831 provides a complete solution for microprocessor and graphic processor
                                          core power supply. It provides two Voltage Regulators (VRs) with three integrated gate drivers. The first VR can be
                                          configured as 3-, 2- or 1-phase VR while the second output is 1- phase VR, providing maximum flexibility. The two VRs share the
                                          serial control bus to communicate with the CPU and achieve lower cost and smaller board area compared with the two chip approach.
                                          Based on Intersil's Robust Ripple Regulator...
                                          11-05-2024, 03:24 PM
                                        • ruletero
                                          Acer a515-43 low battery charge voltage
                                          by ruletero
                                          Hi
                                          Acer A515-43
                                          LA-H801P
                                          Fail: Does not charge battery, has low voltaje on connector.
                                          Laptop didn't want to turn on, only charge led blinked.
                                          I found PQB5 (mosfet high battery charger) in short, voltaje in +12.6V_BATT was 19 v ...
                                          I changed it, changed PQB6 too and now battery charger voltage is 4.4V but battery is 3 cell, 11.25v, then is very low to charging.
                                          Laptop turns on without battery and works fine, but with battery turns on and turns off inmediately, I suspect battery bad but I don't know...
                                          10-24-2022, 02:31 PM
