ISL95831HRTZ ISL95831HRTZ-T ISL95831IRTZ ISL95831IRTZ-T Voltage Regulator Datasheet
    • 115474
    3+1 Voltage Regulator for IMVP-7/VR12 CPUs
    Compliant with IMVP-7/VR12, the ISL95831 provides a complete solution for microprocessor and graphic processor
    core power supply. It provides two Voltage Regulators (VRs) with three integrated gate drivers. The first VR can be
    configured as 3-, 2- or 1-phase VR while the second output is 1- phase VR, providing maximum flexibility. The two VRs share the
    serial control bus to communicate with the CPU and achieve lower cost and smaller board area compared with the two chip approach.
    Based on Intersil's Robust Ripple Regulator (R3) technology, the PWM modulator compared to traditional modulators,
    has faster transient settling time, variable switching frequency during load transients and has improved light load
    efficiency with it's ability to automatically change switching frequency.
    The ISL95831 has several other key features. Both outputs support DCR current sensing with single NTC thermistor for
    DCR temperature compensation or accurate resistor current sensing. Both outputs come with remote voltage sense,
    programmable VBOOT voltage, programmable IMAX, TMAX, adjustable switching frequency, OC protection and separate
    Power-Good.
    Key Features
    Serial Data Bus
    Dual Outputs:
    Configurable 3-, 2- or 1-phase for the 1st Output using 2 integrated Gate Drivers
    1-phase for the 2nd Output using an Integrated Gate Driver
    0.5% System Accuracy Over-Temperature
    Supports Multiple Current Sensing Methods
    Lossless Inductor DCR Current Sensing
    Precision Resistor Current Sensing
    Differential Remote Voltage Sensing
    Programmable VBOOT Voltage at Start-up
    Resistor Programmable IMAX, TMAX for Both Outputs
    Adaptive Body Diode Conduction Time Reduction​
    ISL95836 Laptop PWM Controller Datasheet
    The ISL95836 Pulse Width Modulation (PWM) controller IC
    provides a complete solution for IMVP-7/VR12 compliant
    microprocessor and graphic processor core power supplies. It
    provides the control and protection for two Voltage Regulators
    (VRs). The first VR, typical for Vcore, incorporates 2 integrated
    drivers and can operate in 3-, 2- or 1-phase configurations. The
    second VR, typical for graphics, incorporates 1 integrated
    driver and can operate in 2- or 1-phase configurations. The two
    VRs share...
    11-05-2024, 03:31 PM
    NVDC charger configuration...
    11-05-2024, 03:28 PM
  • subroto
    Programmable and non-programmable SIO list
    by subroto
    ene kb9012 programmable
    ene kb9016 programmable
    ene kb9018 programmable
    ene kb9022 programmable
    ene kb9028qc programmable
    ene kb9010 programmable
    ene kb3930qf/b1 programmable
    ite it8585e programmable
    ite it8586e programmable
    ite it8985e programmable
    ite it8587e programmable
    ite it8522 programmable
    ite it8987e programmable
    ite it8589 programmable
    ite IT8380E programmable 192kb
    ite IT8380VG programmable 192kb
    ite IT8995E-128 programmable
    ite it8886H...
    01-13-2018, 09:15 AM
  • disorder
    HP 2311 display, 3.3v regulator fried, need help to replace
    by disorder
    hello,
    i have a hp display 2311 to repair, totaly dead
    on the board, il have 2 capacitor 470µf that are dead and the 3.3v regulator : ax6630-33
    i have no such regulator, can i replace this one with a mic5209-33 (3.3v outpout regulator too) ?
    thank you
    07-27-2025, 04:34 AM
    Richtek RT8205L RT8205M Power Supply Controller for Laptop Computer
    The RT8205L RT8205M is a dual step-down, switch mode power supply controller generating logic-supply voltages in battery powered systems. It includes two Pulse-Width Modulation (PWM) controllers adjustable from 2V to 5.5V, and also features fixed 5V/3.3V linear regulators. Each linear regulator provides up to 100mA output current with automatic linear regulator bootstrapping to the PWM outputs. An optional external charge pump can be monitored through SECFB (RT8205M). The RT8205L/M includes on-board power up sequencing, a power good output, internal soft-start, and internal soft-discharge output...
    10-23-2024, 03:58 AM
