Sony LED 65X9005A shuts down after few seconds - looking for help
  • tec3000
    • Mar 2024
    • 119
    Ok, I will go ahead and disassemble everything. Let's see what I'll find! I'll let you know. Thank you!
    • tec3000
      • Mar 2024
      • 119
      So I got the cables and the t-con board from China. It came early. I was excited. But somehow nothing changed. What does that mean now?
      • Diah
        • Feb 2013
        • 6446
        did you compare the pins amount of the new and old ribbon cable ??? and also the the zise of wide???
        if they are fit at that measurements .. try them first with yours original t-con
        • tec3000
          • Mar 2024
          • 119
          Diah
          I tried the cables first on my t-con board. Same as with the one from China. BTW: I bought this t-con board: https://de.aliexpress.com/item/1005006203664939.html
          I didn't know but it doesn't look new to be honest...
          And the new cables are a bit wider but the pins are both 80 on each side. I took two pics. Can you have a look?
          • Diah
            • Feb 2013
            • 6446
            compare them in way both contact pins facing each other..not as you did on the top.. . so we will know
            • lotas
              • Jan 2016
              • 4764
              • Russia
              #206
              Well, from the photo you can see that the step does not coincide with the original, there is a shift...
              • tec3000
                • Mar 2024
                • 119
                Yes, that's what I thought. Then I aligned them as Diah said and it looks close. (Pic1)
                But the length of the pins is definitely different. The originals are longer. (Pic2) Is that a problem?
                • lotas
                  • Jan 2016
                  • 4764
                  • Russia
                  #208
                  The thickness of the contact pad corresponds to the original. There are no traces left from the clamping of the connector, as if there is no contact..
                  • tec3000
                    • Mar 2024
                    • 119
                    ah, that's because it was an unused one. I got 10 instead of 4 from China! Here I just de-attached one of the new used one. There you see the marks:
                    • Diah
                      • Feb 2013
                      • 6446
                      they pass..
                      hope you didn't remove or play with ribbon white the TV on..
                      let check from the bottom... show the panel puffer boards if there any sign of burn parts or trace
                      • tec3000
                        • Mar 2024
                        • 119
                        Originally posted by Diah
                        they pass..
                        I have, I have.
                        Since then the TV is like that. It also smelled a bit. I told about this when it happened a couple weeks ago. Remember? But I bought the cables and the t-con board AFTER that. Since then I didn't do any cable detaching while the TV was plugged in. Lesson learned....
                        • tec3000
                          • Mar 2024
                          • 119
                          they pass..
                          and here the pics:
                          • Diah
                            • Feb 2013
                            • 6446
                            photo No 2. there are unclear things to me... check them
                            and you have 2 U ribbon cable connect 2 half on one side together... carefully take them out and inspect them
                            • lotas
                              • Jan 2016
                              • 4764
                              • Russia
                              #214
                              This is more likely a reflection from the flash.
                              • Diah
                                • Feb 2013
                                • 6446
                                if this the case then this line heated and lost the green color,, and maybe cut off ... i hope so
                                • Diah
                                  • Feb 2013
                                  • 6446
                                  there are another way to know why the gamma dead and where the issue.... using the original T-CON and the replacement one we need to do it in points turn on and check the screen
                                  A- with Original T-con in place all 4 ribbon cable connect to panel
                                  1- disconnect only left side U ribbon cable after test if no change put it back
                                  2- disconnect only right side U ribbon cable after test if no change put it back
                                  B. disconnect 2 ribbon from left side after test if no change put it back
                                  C- disconnect 2 ribbon from right side after test if no change put it back
                                  do all points again with replacement T-con
                                  • lotas
                                    • Jan 2016
                                    • 4764
                                    • Russia
                                    #217
                                    Only 1/2 of the slats are visible here, half is hidden behind the body panel...
                                    • Diah
                                      • Feb 2013
                                      • 6446
                                      yes indeed...not only this from his last photo it show part of screen are off... like U ribbon... but i think he know now after many fail how to access
                                      • tec3000
                                        • Mar 2024
                                        • 119
                                        Yes, luckily it's just a reflection! I took another pic.
                                        • tec3000
                                          • Mar 2024
                                          • 119
                                          (I wrote it above. It was just a reflection!)
                                          Thank you for the detailed description. I will do this now but before I need to know something: what and where is the U ribbon cable??
                                          • mauda
                                            Sony TV model KD-65XE7005 - only Sony logo for 3 seconds
                                            by mauda
                                            I'm currently working on repairing a malfunctioning Sony TV model KD-65XE7005 with the mainboard 1-981-926-21. I would appreciate your assistance with this issue.
                                            Upon powering on the TV, the Sony logo appears for approximately 3 seconds, after which the backlight remains lit, the screen remains black, and nothing else happens. The TV consumes around 55W initially and then drops to 35W. The indicator LED remains solid white. It doesn't respond to the remote control. When attempting to update the TV using a USB dongle, the dongle briefly flashes but nothing else happens.
                                            05-21-2023, 11:56 PM
                                          • chaos-theory
                                            Asrock z97x starts then shuts off after 4 seconds, sometimes more, no post
                                            by chaos-theory
                                            I have a really weird problem, this motherboard was working normally, someday it just started and all fans were running but didn't want to post, tried resetting bios, checking CPU and it was getting warm tried external gpu, flashed bios with programmer, but same problem.
                                            Next day after several attempts the board goes into protection mode, no more staying on, I turn on the PSU fans starts directly turning, it used to not start until I press the pwr button, now it starts directly and fans spins, and shuts off after 3 seconds sometimes less, then won't start again unless I unplug the PSU and...
                                            03-14-2025, 05:37 PM
                                          • APOPAP
                                            Panasonic National NV-M3 VHS Camera shuts down after some seconds
                                            by APOPAP
                                            Hello everybody,
                                            First post here. I have been reading posts here for some time now, but today I made my first account and post.
                                            The same question is also posted on another site, here it is:
                                            Just found an old Panasonic National NV-M3 VHS Camera without the original charger but with a special bag with a led, switch and fuse that is designed for a lead-acid 12v 6Ah battery. It has two cables coming off the bag that leads to the camera terminals (Only + and - ). Pretty sturdy design I think.
                                            I tried connecting it to a Computer PSU (12.7v) but I get battery error...
                                            08-25-2025, 10:12 AM
                                          • solveit68
                                            Lenovo L580 20LW-0010GE shuts down after a few seconds
                                            by solveit68
                                            Hello together,
                                            I am hoping for some tips here to repair a notebook.
                                            The notebook has following issue:
                                            After starting the notebook it shut down after a few seconds.
                                            Sometimes it is possible to enter the bios but then after, another few seconds it shuts down also.
                                            The time until shutdown varies slightly.
                                            What I've tried so far:
                                            - cmos cleared
                                            - removed all components that are not essential for motherboard testing including keyboard and touchpad
                                            - ram exchanged
                                            - same behaviour with power supply or battery...
                                            07-21-2023, 01:04 PM
                                          • doejohn11
                                            Lenovo Legion 5 17ach6h shuts off after 70 seconds.
                                            by doejohn11
                                            Hello guys. I have a legion 5 17ach6h with Ryzen 7 5600h and RTX3060.
                                            It was working perfectly fine but the cpu was overheating so i decided to replace thermal paste. I bought one from local hardware store and replcaed. it looked fine then the fan started to spin at the full speed after about 1 minute and then immediately shut off after 10 seconds. Then I though if i have done something wrong, so i cleaned up everything with IPA and put new thermal paste. but the issue was still there. After that, I came across this article where he had similar issue and he was able to solve it by replacing...
                                            04-19-2025, 07:38 AM
