UN55D6000 Blinking Standby Light
  • Ltank
    • Jun 2013
    • 776
    Re: UN55D6000 Blinking Standby Light
    Was there any part numbers on the led emitters so the bad less can be replaced? I looked online and found no led backlighting strips available. The listings at Mouser with size, wattage, Luminance, voltage, current etc is very long. Makes it difficult to look up the correct ones.
    • mmartell
      • Oct 2013
      • 3189
      It might be tough trying to find drop-in led's so I'm going to try and get a used replacement strip and harvest what I need.
        Show us a picture of the LEDs.
        Then, take your meter and measure the voltage across the LED when it is at room temperature (allow TV to settle down to room temperature first.)
        Then put your multimeter in 10A range across it, shorting it out, measuring current.
        (Both done while TV powered ON.)
        Then the replacement LED may be located.
        • mmartell
          • Oct 2013
          • 3189
          Tom I can't take measurements atm as the tv is deaf dumb and blind because I broke the ir board so needs repair first
          • mmartell
            • Oct 2013
            • 3189
            Ya let me clarify that. I CAN run the leds as the default is ON with main unhooked is that good enough for the measurements ?
              Yes, you can do that. We don't care if main board is working or not.
              • mmartell
                • Oct 2013
                • 3189
                For voltage test black probe ground red probe other side of led ?
                  Measuring across the LED in both instances. Ammeter mode will make LED go off or very dark - this is OK.
                  • mmartell
                    • Oct 2013
                    • 3189
                    That was difficult - very hard to see with the damn light stabbing your eyes.
                    I managed to get this. 3.6v across working led.
                    As for amperage, well... there was a spark and POOF! Lower half of the left string (the portion with 19 out already) has gone dark. The good news is the upper half has gone to full luminosity
                    • mmartell
                      • Oct 2013
                      • 3189
                      Some pics...
                      • Ltank
                        • Jun 2013
                        • 776
                        Wow.If you take measurements and unsolder one there maybe a a mfg part# on the back side next to the board. I have tried to find LED strips because I was currious and there are none to be founf through my normal outels that I use, I can find individual leds.
                        I have followed this thread closely beause I have a set with issues that I have not resolved and I am learning from this.
                        The old question, Is it better to know alot about a little or little about alot?
                        • mmartell
                          • Oct 2013
                          • 3189
                          CCFL Warehouse is getting into supplying finished LED back lights, but their selection is small and they don't have these. I would expect if things go the way they are you will see more of these on the market.
                          There is a little bit of info on the last pic which shows the colour temperature as 6.5K, not sure if anything else useful is there.
                          The discolouration on the led's btw was put there by me with a sharpie to mark bad ones.
                          • Ltank
                            • Jun 2013
                            • 776
                            Found some but dont know their reputation Price $13.98
                            http://www.tvpartsnow.com/product.php?id_product=6073
                            • mmartell
                              • Oct 2013
                              • 3189
                              One step closer...
                              • Ltank
                                • Jun 2013
                                • 776
                                One step closer? What got to that point? Did you replace the LED strips?
                                • mmartell
                                  • Oct 2013
                                  • 3189
                                  Yes I replaced the bad strip. Now I need to replace the ir/button board which I broke (tore off some pads). I have no idea where one pad leads to so I need a replacement.
                                  • freakaftr8
                                    • Oct 2012
                                    • 3743
                                    Oh wow that looks great!! Congrats!!
                                    • mmartell
                                      • Oct 2013
                                      • 3189
                                      Thanky
                                      • mmartell
                                        • Oct 2013
                                        • 3189
                                        I managed to repair the ir/button board and zipped the whole thing back up.
                                        Thanks to everybody for their help and input.
                                        • mmartell
                                          • Oct 2013
                                          • 3189
                                          Wow.
                                          • mecha1166
                                            QN750Q8FNBFXZA Service Error Codes Needed - Error code 1-3-1-2 ? Dead set, only blinking standby light in repeating sequence
                                            by mecha1166
                                            I am working on a QN750Q8FNBFXZA. Dead except the standby light. It blinks what appears to be 1 3 1 2. 1 long blink, pause, 3 short, pause, 1 long, pause, 2 short, pause, repeat. A service manual would be very helpful, or if anyone knows these error codes. Thanks!
                                            03-28-2024, 08:31 AM
                                          • ChristianBr01
                                            LED TV Samsung The Frame 55 inch QE55LS03RAU Standby Light only
                                            by ChristianBr01
                                            I got a Samsung The Frame 55 inch TV for free from uncle cause it is not turning on anymore. I am in the second year of training as an electrician so I have knowledge already but I am far away from to be a pro.
                                            The TV has Standby but ist not turning on. A Friend of mine owns a 50 inch Frame TV so I checked the One Connect Box and the One Connect Cable there. Both are good and working normally. I have opened the TV case and measured some voltages on the Board.
                                            What I already found is that the 12.8V are not an the connector to the main board connector to the power...
                                            04-23-2025, 01:48 AM
                                          • YasaCh
                                            Sony kdl 40p5500 red light keeps blinking 3 times
                                            by YasaCh
                                            Hello...
                                            my tv almost 2 years not powerd on and when i turned it on nothing happened and only 3 red light keeps blinking
                                            i opened the back cover no sign of damage on the powery suply or motherboard
                                            when i plug in the power i hear the reley sound like tik first and another tik..after that only red keep blinking..
                                            another thing is even after i unplugged the power, The tv keeps red blinking 3 times for 2 almost 2 munites
                                            07-07-2025, 11:53 AM
                                          • AleMonti
                                            LG 55EG910V - no power and no standby light
                                            by AleMonti
                                            I'm trying to troubleshoot and repair this old LG OLED curved TV, model 55EG910V.
                                            I did some basic troubleshooting and reviewed most related posts here, but I wasn't able to isolate the issue.
                                            The TV shut itself off during playback and never came back to life - the standby light remains off. My dad claims that it has happened a few times in the past but the issue resolved itself after some time. Not this one.
                                            After checking the basics I did the following:
                                            • I measured all voltages and as expected the only active supply is the 3.5V standby. It
                                            11-04-2024, 05:02 PM
                                          • Kaar3l
                                            Samsung QLED QE65Q7FNAT only standby light
                                            by Kaar3l
                                            TV: Samsung QLED QE65Q7FNAT
                                            PSU: BN4400940A
                                            MB: BN94-12832K
                                            I got the tv in spring 2024. At that time it started, then ran 60 sec and poweroff. Seemed like reboot issue. I didn't have time and room to check it in summer so I plugged it in and now the standby light is on. I press button on remote, standby light goes off and tries to start?. No picture or backlight on LCD. I thought about removing diodes like in this thread: https://www.badcaps.net/forum/troubl...sung-qled-q60r...
                                            09-24-2024, 01:35 PM
