UN55D6000 Blinking Standby Light
    Re: UN55D6000 Blinking Standby Light
    Very unlikely to be bad caps on a new TV like this... not saying it's impossible, but it's unlikely. Startup capacitor if anything could cause fault.
    • mmartell
      • Oct 2013
      • 3189
      Could a bad start up cap cause all voltages to be output AND cause voltage on the input pins ?
      • mmartell
        • Oct 2013
        • 3189
        Originally posted by tibimakai
        If I remember well, there should be a flip up tab and then squeeze and pull.
        Thanks I will try that.
        • mmartell
          • Oct 2013
          • 3189
          Originally posted by tom66
          Some discussion here leading to main board conclusion.
          http://www.justanswer.com/tv-repair/...-warranty.html
          No schematic I'm afraid.
          The guy in the article never came back and confirmed the suspicions of the tech. FWIW the previous owners of this set stated they took it to a local shop and he told them the mainboard needed replacing. Don't know if this is a "common knowledge" thing or what.
          I can understand the possibility of the mainboard being defective but I can't understand why the PS is acting the way it is.
          Perhaps that is its normal operation without load ?
            You could try applying a light load, around a few watts, to see what it does.
            • mmartell
              • Oct 2013
              • 3189
              Does Samsung use active LOW for PSON ? That would explain some of what I'm seeing here. As far as voltage on that line without the mainboard connected I can only guess that PSON is a bi-directional data line for which there is some chatter between the mainboard and power supply at power on. THAT would fully explain what I'm seeing. That and the fact that I may have a defect in my led strip(s) causing the PS to respond with an error back to the mainboard.
              • johnboy1313
                • Nov 2012
                • 1959
                mmartell, I was pointed here by the post you made in the other UN55D thread. As you saw, I have the same set with a cracked screen. If no one else answers your question, I'll try to get the answers tonight.
                • mmartell
                  • Oct 2013
                  • 3189
                  Hi johnboy, I have answered a few myself.
                  There is a tab that flips up on the lvds cable connector nearest the board that allows you to squeeze the connector (as one might expect!) and remove the lvds cable from the socket. With the T-Con disconnected I still had the same symptoms.
                  This set does use an active low for PSON. It is 3.3v in standby and pulled low for power up. Since I see voltage on that pin even with the mainboard disconnected I believe I have at minimum a problem with the SMPS.
                  I'm considering using a PSU from a different Samsung I have here and rigging it to see if I can at least get the mainboard to stop flashing and power up properly. Will have a look more at that tonight.
                  • Ltank
                    • Jun 2013
                    • 776
                    I got this info for a UN55D3003 might help
                    • mmartell
                      • Oct 2013
                      • 3189
                      Thanks tank will have a look.
                      • mmartell
                        • Oct 2013
                        • 3189
                        Ok need some help here thinking this out.
                        I believe I have a faulty power supply. 5V Standby is rock solid. However when the secondary voltages come up the unit shuts down (protection ?) and the cycle starts over again.
                        I think there is a short because I'm reading voltages on the PSON, BLON and DIM pins.
                        Doesn't sound like a capacitor issue does it ? I've heated the board anyway with no change.
                        Where should I be looking ?
                        • mmartell
                          • Oct 2013
                          • 3189
                          Here are some pics of the board. Is there some common area that would leak voltage to the input pins ??
                          • Hudey
                            • Oct 2013
                            • 3
                            Hi, I have a un40d6000 with the same symptoms, all voltages are switching
                            on and off, except for the 5vsb.. , ordered a psu, installed it no change, i also disconnected the t-com still no change, i can't find schematics for it,
                            i ordered a main board will post when i recieve it .
                            Peace.
                            • mmartell
                              • Oct 2013
                              • 3189
                              Hudey do your backlights come on at all when you plug it in with mainboard disconnected ?
                              • johnboy1313
                                • Nov 2012
                                • 1959
                                FYI, yesterday when I was stripping my tv, I had the LEDs unplugged and tried to fire it up. The led on the front flashed over and over and the PSU clicked repeatedly.
                                • mmartell
                                  • Oct 2013
                                  • 3189
                                  Well having bad leds is a possibility too but I don't know how to test the strips when I'm not sure in the first place if my power supply is good.
                                  • Hudey
                                    • Oct 2013
                                    • 3
                                    Pins 3 and 5 are physically connected on the psu ill try to post a pic
                                    2, led panel will not light , main has to keep the psu fully on, some can be tricked to stay on , i will have to look into it , w/o schematics its kinda hard.
                                    i still have not received the new main yet. will post as soon as its in,
                                    Hope this helps,
                                    • mmartell
                                      • Oct 2013
                                      • 3189
                                      Yes it does help, Hudey, thanks for chiming in and do post back with results.
                                      • Hudey
                                        • Oct 2013
                                        • 3
                                        Hi, the main board fixed it. , un40d6000 . same board different f/was a un55d6000
                                        Good luck , Peace
                                        • mmartell
                                          • Oct 2013
                                          • 3189
                                          Ok thanks for the update. Since I need a mainboard as well I'm tempted to upgrade to a 6400 or even higher if I can confirm compatibility.
                                          I still wonder if the eeprom is messed up. The voltage regs are working - at least during the "on" portion of the cycle.
                                          • mecha1166
                                            QN750Q8FNBFXZA Service Error Codes Needed - Error code 1-3-1-2 ? Dead set, only blinking standby light in repeating sequence
                                            by mecha1166
                                            I am working on a QN750Q8FNBFXZA. Dead except the standby light. It blinks what appears to be 1 3 1 2. 1 long blink, pause, 3 short, pause, 1 long, pause, 2 short, pause, repeat. A service manual would be very helpful, or if anyone knows these error codes. Thanks!
                                            03-28-2024, 08:31 AM
                                          • ChristianBr01
                                            LED TV Samsung The Frame 55 inch QE55LS03RAU Standby Light only
                                            by ChristianBr01
                                            I got a Samsung The Frame 55 inch TV for free from uncle cause it is not turning on anymore. I am in the second year of training as an electrician so I have knowledge already but I am far away from to be a pro.
                                            The TV has Standby but ist not turning on. A Friend of mine owns a 50 inch Frame TV so I checked the One Connect Box and the One Connect Cable there. Both are good and working normally. I have opened the TV case and measured some voltages on the Board.
                                            What I already found is that the 12.8V are not an the connector to the main board connector to the power...
                                            04-23-2025, 01:48 AM
                                          • YasaCh
                                            Sony kdl 40p5500 red light keeps blinking 3 times
                                            by YasaCh
                                            Hello...
                                            my tv almost 2 years not powerd on and when i turned it on nothing happened and only 3 red light keeps blinking
                                            i opened the back cover no sign of damage on the powery suply or motherboard
                                            when i plug in the power i hear the reley sound like tik first and another tik..after that only red keep blinking..
                                            another thing is even after i unplugged the power, The tv keeps red blinking 3 times for 2 almost 2 munites
                                            07-07-2025, 11:53 AM
                                          • AleMonti
                                            LG 55EG910V - no power and no standby light
                                            by AleMonti
                                            I'm trying to troubleshoot and repair this old LG OLED curved TV, model 55EG910V.
                                            I did some basic troubleshooting and reviewed most related posts here, but I wasn't able to isolate the issue.
                                            The TV shut itself off during playback and never came back to life - the standby light remains off. My dad claims that it has happened a few times in the past but the issue resolved itself after some time. Not this one.
                                            After checking the basics I did the following:
                                            • I measured all voltages and as expected the only active supply is the 3.5V standby. It
                                            11-04-2024, 05:02 PM
                                          • Kaar3l
                                            Samsung QLED QE65Q7FNAT only standby light
                                            by Kaar3l
                                            TV: Samsung QLED QE65Q7FNAT
                                            PSU: BN4400940A
                                            MB: BN94-12832K
                                            I got the tv in spring 2024. At that time it started, then ran 60 sec and poweroff. Seemed like reboot issue. I didn't have time and room to check it in summer so I plugged it in and now the standby light is on. I press button on remote, standby light goes off and tries to start?. No picture or backlight on LCD. I thought about removing diodes like in this thread: https://www.badcaps.net/forum/troubl...sung-qled-q60r...
                                            09-24-2024, 01:35 PM
