BL driver has 25v
Sony kdl 65xg9505 green amber blinking
backlite has no issues. i still can illuminate BL. wel. i am not an expert but the logic should be that a working firmware must be installed on a tv so that the working sequence is in order thus all functions should start as intended.
Once the firmware is ok then atleast it would give correct error codes related to the faulty board. since green yellow is a software error then there is no going forward untill this is fixed.
True..?Comment
You have large USB flash drives, I already wrote that updates will not work for all flash drives, you need to find 2-4GB of the old model, I picked it up once, only on the 8th flash drive 2Gb (I don’t remember the company, maybe Kingston, or else what), but it didn’t work with others!Comment
Ok. i will ask around for a 2 or 4gb flash drive. i was at the market and looked but non was for sale there since no one used those now a daysYou have large USB flash drives, I already wrote that updates will not work for all flash drives, you need to find 2-4GB of the old model, I picked it up once, only on the 8th flash drive 2Gb (I don’t remember the company, maybe Kingston, or else what), but it didn’t work with others!Comment
then keep it disconnected and disconnect the 2 LVDS cable... and do stand alone yours BL will come on ... STB connect to power on ---tcon-on and BL_on interest want to see what yours T-CON will display on the screenComment
backlite does not come on when all is standalone. when mainboard is connected to power and that ribnon is disconnected then comes the backlite on.
But when lvds is disconnected and that flate is also disconnected then backlite comes on and shows nothing but mainboard is also powered onComment
yes. i saw just a video where an sony android is being paired with tcon and it does not go too easy or he shows how and what issues can come up. and there is no backlite untill it boots after being paired..
But again.. he was doing it with .pkg file. no zip were used..F***ing sony made things too difficult.
But the firmware i downloaded is update to android 10. maybe the previous version is .pkg but that is nowhere on there site. i think that must be android 9.Comment
Here there is an archive of old firmware, look, maybe you will find something, they are at the very bottom.
https://www.touslesdrivers.com/index...=26&v_code=682Comment
did you exam the usb of the firmware again on yours PC to see if there 2 files added on it root?
pull out the metainf file and zip it upload it on here.. also the zip of comparable.zip iof yours signed last zip...let see if i can trick the system to accept writing again.... sign no problemComment
by YasaChHello...
my tv almost 2 years not powerd on and when i turned it on nothing happened and only 3 red light keeps blinking
i opened the back cover no sign of damage on the powery suply or motherboard
when i plug in the power i hear the reley sound like tik first and another tik..after that only red keep blinking..
another thing is even after i unplugged the power, The tv keeps red blinking 3 times for 2 almost 2 munites2 Photos -
by huzoThe board is daox8cmb6eo and i can't find no boardview or schematics on the forum or anywhere...
So i plug in the charger, amber light starts blinking ,there is 3.3V and 5V present, and 2.4V on the power button,board doesn't turn on, no shorts...
I've tried flashing the bios...
interesting thing is the battery was around 7,8V, and it's 11.1V battery, the mosfet near the battery is open, but not charging,i desoldered it,tested it and it's fine ,but the amber light kept going on the charger so i charged the battery with power supply and got it to about 10.5V... -
by jxrepmanHi there,
I have this ASUS X453MA Laptop that's not turning on. When I plug in the charger, the green light just keeps on blinking and pressing the power button does nothing.
I have checked the charger and it is giving 19+ V
I have disconnected the battery and pressed power button for 30 seconds.
I tried another RAM stick.
Tried disconnecting the keyboard and touchpad.
Tried disconnecting the HDD and the wifi adapter.
The problem persists.
Hope you could help me out on this one. Thank you.12-14-2024, 06:40 AM -
by CSM123Have KDL-55HX850 that seems to have been hit by power surge.
Blinking red 3x - clicks on/off on the power supply board when power is held in.
Replaced Power Supply G board - same response.
Replaced main BAP - no response at all. Seems worse, maybe bad board.
Replaced main BAP with a 2nd board - back to blinking 3x similar to original.
Checked speaker impedances ok 8ohms each.
Where are JL6002, JL6005 test points?
Ideas for what next to troubleshoot?
Could it be T-Conn or LED board? Seems that the troubleshooting... -
by YasaChSony KD-49XF9005 it power up to android boot screen and turns off immediately with continuously 4 red blinks ...
- Loading...
