Sony kdl 65xg9505 green amber blinking
  • shahnld
    • Nov 2019
    • 164
    • Netherlands
    #61
    i did that..push and keep pushed power button and put power cord in wall socket. when turns solid green release power button.
    it stays green for a while then restarts and again same green yellow flash..
    • shahnld
      • Nov 2019
      • 164
      • Netherlands
      #62
      • lotas
        • Jan 2016
        • 4803
        • Russia
        #63
        Originally posted by shahnld
        Ok. thats nice. So now it has its own tcon in a way.. so is there a way to resolve the issue.
        Usually updating via usb helps, but with this model it doesn't pick it up. Sometimes Sony service providers have their own updates for such cases, but they are difficult to find in the public domain.
        Here's roughly a quote from Bulletin 17tv25:
        CAUSE
        Communication error between main board and T-CON board.
        SOLUTION
        Before T-CON board, main board or AEP exchange try to recover the TV
        A) with the attached ‘ USB Recovery PKG '
        1) Download the applicable file from the below link, unzip and copy the extracted to the root of an empty
        USB stick.
        Date Chassis Link
        October 2017 GN1G UPGRADE_LOADER_SONY_SAKURA_3925EUA_5XBLINKINGSERVI CEONLY.ZIP
        2) Unplug AC of the TV.
        3) Insert the USB stick into the USB slot located at the side of the TV set.
        4) Plug in the AC of the TV.
        5) The TV will start a recovery process during a few seconds. The below screen will be visible.
        6) When the front LED glows blue and Sony logo is displayed it is safe to remove your USB device from
        the USB slot.
        B) by following the below procedure
        1) Turn OFF TV
        2) Disconnect LVDS cable
        3) Turn ON TV for a few minutes
        4) Turn OFF TV
        5) Reconnect LVDS cable
        6) Turn ON TV
        • shahnld
          • Nov 2019
          • 164
          • Netherlands
          #64
          i will contact sony if they will help in providing the .pkg frimware since there is non on sony sites. they have firmware for this model but its not .pkg which the tv does not utilize..
          • lotas
            • Jan 2016
            • 4803
            • Russia
            #65
            It is unlikely that they will provide you with service firmware; they will rather tell you to contact the Sony service center with your TV and they will repair it for you, of course not for free.
            • Diah
              • Feb 2013
              • 6497
              this mean bootlaoder in tact... you can put the usb fat32 with yours last firmware in .pkg format on it and do the hard reset-
              stand alone test..
              MB discobbected from PSU
              LVDS disconnected from T-CON side
              on PSU STBY3.3V jumper it to power_on and BL_on
              • shahnld
                • Nov 2019
                • 164
                • Netherlands
                #67
                stand alone test..
                that is the problem. i do not have a .pkg file..
                • shahnld
                  • Nov 2019
                  • 164
                  • Netherlands
                  #68
                  all i could find is sony firmware which is not a .pkg file but a zip folder where multiple files are in it.. .pkg worked for all sony as far as i saw. only i couldnt find one since there isnt one..
                  • shahnld
                    • Nov 2019
                    • 164
                    • Netherlands
                    #69
                    thats very true and they will charge almost half of the tv price..
                    • Diah
                      • Feb 2013
                      • 6497
                      do first the stand alone test
                      • lotas
                        • Jan 2016
                        • 4803
                        • Russia
                        #71
                        Yes, the chassis is updated in zip, like smartphones, tablets with Android...
                        • shahnld
                          • Nov 2019
                          • 164
                          • Netherlands
                          #72
                          but isnt that .zip files like an update only within the tv when its on and working.. not for resurrecting from the dead. .pkg is for dead one's i guess.
                          • lotas
                            • Jan 2016
                            • 4803
                            • Russia
                            #73
                            Yes, almost all models came with updates in the “pkg” format, but this particular chassis, and maybe others (new ones), are in zip format. Try downloading the full service manual for your model and see if there is any mystery regarding how the t-con is connected to the motherboard.
                            • Diah
                              • Feb 2013
                              • 6497
                              ht has issue on T_CON VCC12V
                              • shahnld
                                • Nov 2019
                                • 164
                                • Netherlands
                                #75
                                Tcon vcc 12v is present.. on fuse and aslo on 12v logics/transisters..
                                • shahnld
                                  • Nov 2019
                                  • 164
                                  • Netherlands
                                  #76
                                  I will do the standalone test tomorrow..
                                  • shahnld
                                    • Nov 2019
                                    • 164
                                    • Netherlands
                                    #77
                                    I have done the test..light source was not sufficiant from mobile torch so i can not say for sure.
                                    • Diah
                                      • Feb 2013
                                      • 6497
                                      if you have LED tester... power up the BL to see what you will have on the screen
                                      • shahnld
                                        • Nov 2019
                                        • 164
                                        • Netherlands
                                        #79
                                        And. what if i arrange/buy replacement mainboard with its own tcon as pair. ? would it work or i will run in same issue ?
                                        I do not have led tester
                                        • lotas
                                          • Jan 2016
                                          • 4803
                                          • Russia
                                          #80
                                          The panel strips may also contain eeprom or spi flash, inspect these strips for their presence.
                                          • YasaCh
                                            Sony kdl 40p5500 red light keeps blinking 3 times
                                            by YasaCh
                                            Hello...
                                            my tv almost 2 years not powerd on and when i turned it on nothing happened and only 3 red light keeps blinking
                                            i opened the back cover no sign of damage on the powery suply or motherboard
                                            when i plug in the power i hear the reley sound like tik first and another tik..after that only red keep blinking..
                                            another thing is even after i unplugged the power, The tv keeps red blinking 3 times for 2 almost 2 munites
                                            07-07-2025, 11:53 AM
                                          • huzo
                                            HP 470 G5 blinking amber light no power
                                            by huzo
                                            The board is daox8cmb6eo and i can't find no boardview or schematics on the forum or anywhere...
                                            So i plug in the charger, amber light starts blinking ,there is 3.3V and 5V present, and 2.4V on the power button,board doesn't turn on, no shorts...
                                            I've tried flashing the bios...
                                            interesting thing is the battery was around 7,8V, and it's 11.1V battery, the mosfet near the battery is open, but not charging,i desoldered it,tested it and it's fine ,but the amber light kept going on the charger so i charged the battery with power supply and got it to about 10.5V...
                                            06-08-2023, 04:08 PM
                                          • jxrepman
                                            Asus X453MA won't turn on and green led light blinking
                                            by jxrepman
                                            Hi there,
                                            I have this ASUS X453MA Laptop that's not turning on. When I plug in the charger, the green light just keeps on blinking and pressing the power button does nothing.
                                            I have checked the charger and it is giving 19+ V
                                            I have disconnected the battery and pressed power button for 30 seconds.
                                            I tried another RAM stick.
                                            Tried disconnecting the keyboard and touchpad.
                                            Tried disconnecting the HDD and the wifi adapter.
                                            The problem persists.
                                            Hope you could help me out on this one. Thank you.
                                            12-14-2024, 06:40 AM
                                          • CSM123
                                            Sony KDL-55HX850 - Blinking 3x
                                            by CSM123
                                            Have KDL-55HX850 that seems to have been hit by power surge.
                                            Blinking red 3x - clicks on/off on the power supply board when power is held in.
                                            Replaced Power Supply G board - same response.
                                            Replaced main BAP - no response at all. Seems worse, maybe bad board.
                                            Replaced main BAP with a 2nd board - back to blinking 3x similar to original.
                                            Checked speaker impedances ok 8ohms each.
                                            Where are JL6002, JL6005 test points?
                                            Ideas for what next to troubleshoot?
                                            Could it be T-Conn or LED board? Seems that the troubleshooting...
                                            02-06-2024, 11:50 AM
                                          • YasaCh
                                            sony kd-49xf9005 4 red blinking problem
                                            by YasaCh
                                            Sony KD-49XF9005 it power up to android boot screen and turns off immediately with continuously 4 red blinks ...
                                            05-05-2025, 08:40 AM
