HP 470 G5 blinking amber light no power
  • huzo
    • Sep 2014
    • 187
    • CROATIA
    The board is daox8cmb6eo and i can't find no boardview or schematics on the forum or anywhere...
    So i plug in the charger, amber light starts blinking ,there is 3.3V and 5V present, and 2.4V on the power button,board doesn't turn on, no shorts...
    I've tried flashing the bios...
    interesting thing is the battery was around 7,8V, and it's 11.1V battery, the mosfet near the battery is open, but not charging,i desoldered it,tested it and it's fine ,but the amber light kept going on the charger so i charged the battery with power supply and got it to about 10.5V just for test, put the mosfet back, and now without the charger connected the board does the same...it blinks the amber light... is the EC bad?The EC is npce586ha2mx and there is no datasheet for that also..i don't know is the npce586ha0mx the same?
    so i get the 19V or on battery 10.5V on all the places it should be, 3.3 and 5V present, but the board doesn't turn on...i can't, for now, find the power management chip that probably thinks the battery is empty and there is no charger, but reads the voltage...
    Any simmilar board view or schematics?What to look? Unfortunately i can't flash the EC because i don't have the expensive programmer to test that....
    But i think t's something with the power management chip...
    it's and i7 8 gen board so it would be pitty to throw it away...
  • mcplslg123
    • Jun 2015
    • 7262
    • india
    Re: HP 470 G5 blinking amber light no power
    Check RTC circuit and AD_ID. Which charger chip is used here. Try finding any other schematic with NPCE586XXXX s- that you can check the SIO's requirements.
    • huzo
      • Sep 2014
      • 187
      • CROATIA
      i pulled the RTC battery out so RTC shoulden't matter? AD_ID i get 5V on charger, but also on when on battery there is 5V at the charger connector of the middle pin...that seems a bit strange...i am still looking for the charger chip because it's not near the battery connector...
      i found this schematics for the npce586 so i will investigate...
      so the closest thing to charging circuit i found on the board is ISL95859C or ISL9538H
      • huzo
        • Sep 2014
        • 187
        • CROATIA
        even on usb-c it does the same... i plug in my phone charger and get all the voltages for charging battrery, 3.3V,5V, but the board only blinks the orange light....
        • mcplslg123
          • Jun 2015
          • 7262
          • india
          Does pulling the RTC cell out of mb,fixes RTC circuit issues?
          AD_ID should be close to 1V approx.
          ISL9538H is the charging IC.
          • What?
            Vizio SV422XVT blinking amber/white power light
            by What?
            Good day, hope all are healthy and cozy. I could use some help with my malfunctioning Vizio with a blinking power light. I have narrowed the problem to the main board but not sure what to do next. I guess it would be good to start with what I have done.
            Problem:
            I have no image, no sound, blinking power light. (left it plugged in overnight and it was still blinking the following morning). I tried the Vizio recommendations (hold power button for 30 seconds, press reset button, check the outlet is live)
            Power Board:
            I am getting 5v only. I have unplugged...
            04-27-2020, 06:21 PM
          • PantherDave
            by PantherDave
            Hi all!
            05-29-2024, 02:01 PM
          • zwect
            Dell Latitude 5420 / GDF40 LA-K491P REV 3.0 / Amber / Orange light when power button is pressed
            by zwect
            I have this Dell Latitude 5420 with ST: CMF62F3, board GDF40 LA-K491P REV 3.0 that does not power on, i already searched for some clues about this problem that happens on mine but no BIOS i downloaded and flashed did anything.
            Only when the power brick is connected, when pressing the power button an amber light lights up at the front and slight decreases its brightness, the RAM and the CPU seem to heat up if the laptop is left connected but nothing else, other than USB devices getting powered.
            Here is the original BIOS dump from the 25R256JVEN chip.
            09-11-2024, 05:54 PM
          • ipatch
            troubleshooting microsoft surface pro 4 no power no led charge light
            by ipatch
            hello, �� i have been sitting on some microsoft surface pro 4 tablets for a while now. i was originally tasked with replacing the battery in one of the tablets, and ended breaking the screen and logic board in the process. decided to buy another tablet with the same specs. got that screen off successfully of the second tablet. the logic board appeared good, but i guess i shorted something out in the installation process of the logic which i've read is a common issue if there is no barrier between the logic board and battery pins. all that said, i ate costs of the repair and have...
            10-05-2023, 11:59 AM
          • russpall
            LG 39ln540v - red light flashes twice, no power to LED driver?
            by russpall
            Hi there,
            I've got a 39" LG 39LN540V that's just spontaneously stopped working! The symptoms are - when I plug it in, the red light will flash on twice, then go out, there's no visible picture, and I couldn't see anything using a torch on the panel either. If I press the power button (either remote or on TV), the red light comes on continuously. If I press power again, the red light flashes twice.
            The TV is using a power board EAX64905301. I've attached a diagram of the power output, I've tested the voltages with a multimeter and I'm getting the following:
            08-27-2024, 01:07 PM
