Sony kdl 65xg9505 green amber blinking
  • shahnld
    • Nov 2019
    • 164
    • Netherlands
    #141
    Update.
    Used around 10x usb drives from different brands. 2gb, 4gb, 8gb, and so one til 128gb. all formats used. exfat, fat, fat32, ntfs.. non worked.. tried more than 100 times. pff
    last week sent an email to sony the nederlands. and they also sent a link to the same .zip firmware which i told them not accessable by the tv and i need .pkg file in order for the tv to recognize and utilize it. So they did confirmed that it must be a .pkg and .zip is only for updating a working tv.
    So they said we have elevated your case to the appropriate department and hopefully they will revert to us and as soon as they do it we will let you know and if they have a firmware for you then we will send that along..
    So waiting and hoping they may send the .pkg firmware file.
    Cheers
    • shahnld
      • Nov 2019
      • 164
      • Netherlands
      #142
      Good day..
      i have received Mainboard, Tcon and inverterboard from a same broken tv..
      Now with this new boards tv sound is working. responds to remote inputs, detects and plays hdmi and backlite also goes on but all i get is backlite on screen. no image.. now what...?
      amber green light is gone. but now this new issue pfff.
      • zomi
        • Nov 2011
        • 511
        #143
        disconnect tcon one side and power on
        do for both sides and see if you get display on screen..
        • shahnld
          • Nov 2019
          • 164
          • Netherlands
          #144
          I did. one by one.. no image.
          • shahnld
            • Nov 2019
            • 164
            • Netherlands
            #145
            i did tested one by one but no image on either side
            • zomi
              • Nov 2011
              • 511
              #146
              Do you have 12v on the tcon fuse ?
              • nomoresonys
                • 12306
                • U.S.
                #147
                You did a hardware change, try the update now, use the small usb drive.
                • shahnld
                  • Nov 2019
                  • 164
                  • Netherlands
                  #148
                  Yes. there is 12v on Tcon fuse. i can measure 1.1v. 1.8v around the tcon processors. wel hardware change but all boards are from the same tv.
                  But if it comes down to software update then i maybe back to page 1 for this thread since there is no .pkg available and .zip does not work.
                  So..
                  • nomoresonys
                    • 12306
                    • U.S.
                    #149
                    Well hard to tell, but I would be very surprised if an update attempt would mess anything up.
                    • shahnld
                      • Nov 2019
                      • 164
                      • Netherlands
                      #150
                      I would love to do it and let it mess it all. but sad enough when there is no image i can not perform an update. and while no image only a .PKG file is required which is nowhere to be found.
                      • nomoresonys
                        • 12306
                        • U.S.
                        #151
                        Are there any sony experts here that can verify that he needs a certain pkg file to update this tv? it's a new one on me.
                        • zomi
                          • Nov 2011
                          • 511
                          #152
                          Just had a look
                          On the google tvs the firmware looks to be in a dififerent format.
                          The andriod tvs used pkg files.
                          the google tvs have a payload bin file
                          • shahnld
                            • Nov 2019
                            • 164
                            • Netherlands
                            #153
                            Just had a look
                            Yes.. true.
                            Now. this tv has a firmware on sony site as .zip. when unzipped there is another .zip file. inside the last .zip file there are multiple files. payload.bin, inf, etc .
                            I have tried many many times. with .zip in usb root folder, Its just not picking it up. the tv does reads the usb but no firmware update is performed. unless there is a specific method to do it which is not mentioned on sony site..
                            • zomi
                              • Nov 2011
                              • 511
                              #154
                              you need to unpack the contents of the zip file to the root of the usb
                              • shahnld
                                • Nov 2019
                                • 164
                                • Netherlands
                                #155
                                i have done that already many times.. no succes
                                • zomi
                                  • Nov 2011
                                  • 511
                                  #156
                                  Did you have any success with this ?
                                  • shahnld
                                    • Nov 2019
                                    • 164
                                    • Netherlands
                                    #157
                                    No mate... No success. tv is still standing to the wall..
                                    • zomi
                                      • Nov 2011
                                      • 511
                                      #158
                                      did sony come back to you with any news about the pkg. file
                                      • shahnld
                                        • Nov 2019
                                        • 164
                                        • Netherlands
                                        #159
                                        I hoped they will but they sent a link to the same firmware on their website so i contacted again and they said take your tv set to our service center..
                                        So. service center is 200km away from me means 4 hours of travel+ 50 euro on gasoline and they will be charging me 150 as a service charge even if its non repairable. with repair would be around 400 euro which i think too much.
                                        They did not sent me any .pkg file. i did an extensive search asked on every single place even moron youtubers who would sell their videos but wont help when you ask.
                                        Tv is standing to the wall in a corner and i hope some day will be fixed..
                                        Are you having same issue..?
                                        • zomi
                                          • Nov 2011
                                          • 511
                                          #160
                                          Yes i have one here with same issue
                                          it was updating and rebooted and went into this state..
                                          • YasaCh
                                            Sony kdl 40p5500 red light keeps blinking 3 times
                                            by YasaCh
                                            Hello...
                                            my tv almost 2 years not powerd on and when i turned it on nothing happened and only 3 red light keeps blinking
                                            i opened the back cover no sign of damage on the powery suply or motherboard
                                            when i plug in the power i hear the reley sound like tik first and another tik..after that only red keep blinking..
                                            another thing is even after i unplugged the power, The tv keeps red blinking 3 times for 2 almost 2 munites
                                            07-07-2025, 11:53 AM
                                          • huzo
                                            HP 470 G5 blinking amber light no power
                                            by huzo
                                            The board is daox8cmb6eo and i can't find no boardview or schematics on the forum or anywhere...
                                            So i plug in the charger, amber light starts blinking ,there is 3.3V and 5V present, and 2.4V on the power button,board doesn't turn on, no shorts...
                                            I've tried flashing the bios...
                                            interesting thing is the battery was around 7,8V, and it's 11.1V battery, the mosfet near the battery is open, but not charging,i desoldered it,tested it and it's fine ,but the amber light kept going on the charger so i charged the battery with power supply and got it to about 10.5V...
                                            06-08-2023, 04:08 PM
                                          • jxrepman
                                            Asus X453MA won't turn on and green led light blinking
                                            by jxrepman
                                            Hi there,
                                            I have this ASUS X453MA Laptop that's not turning on. When I plug in the charger, the green light just keeps on blinking and pressing the power button does nothing.
                                            I have checked the charger and it is giving 19+ V
                                            I have disconnected the battery and pressed power button for 30 seconds.
                                            I tried another RAM stick.
                                            Tried disconnecting the keyboard and touchpad.
                                            Tried disconnecting the HDD and the wifi adapter.
                                            The problem persists.
                                            Hope you could help me out on this one. Thank you.
                                            12-14-2024, 06:40 AM
                                          • CSM123
                                            Sony KDL-55HX850 - Blinking 3x
                                            by CSM123
                                            Have KDL-55HX850 that seems to have been hit by power surge.
                                            Blinking red 3x - clicks on/off on the power supply board when power is held in.
                                            Replaced Power Supply G board - same response.
                                            Replaced main BAP - no response at all. Seems worse, maybe bad board.
                                            Replaced main BAP with a 2nd board - back to blinking 3x similar to original.
                                            Checked speaker impedances ok 8ohms each.
                                            Where are JL6002, JL6005 test points?
                                            Ideas for what next to troubleshoot?
                                            Could it be T-Conn or LED board? Seems that the troubleshooting...
                                            02-06-2024, 11:50 AM
                                          • YasaCh
                                            sony kd-49xf9005 4 red blinking problem
                                            by YasaCh
                                            Sony KD-49XF9005 it power up to android boot screen and turns off immediately with continuously 4 red blinks ...
                                            05-05-2025, 08:40 AM
