Sony kdl 65xg9505 green amber blinking
  • shahnld
    • Nov 2019
    • 164
    • Netherlands
    #41
    So. if its still giving green yellow light. then what else could it be. firmware remains the only thing which i suspect since there is no sound and also no beeps from tv when remote is used. but that updating does not seem to be going good as i am trying since yesterday.. almost 100 times now i did that usb thing but no succes..
    • shahnld
      • Nov 2019
      • 164
      • Netherlands
      #42
      Soc..? those 2 black processors..?? no.
      • Diah
        • Feb 2013
        • 6497
        please answer my question.. did you replace the 2 CPU Soc too?
        • shahnld
          • Nov 2019
          • 164
          • Netherlands
          #44
          • shahnld
            • Nov 2019
            • 164
            • Netherlands
            #45
            i replaced only those one by one
            • shahnld
              • Nov 2019
              • 164
              • Netherlands
              #46
              no. i have not because i dont have the means to replace those. they were the reason i bought new tcon.
              • shahnld
                • Nov 2019
                • 164
                • Netherlands
                #47
                you saw that picture. those 5 chips i replaced. the Soc's i can not.
                • Diah
                  • Feb 2013
                  • 6497
                  then why on the old T.CON no Soc onstalled? did you remarked pin 1 of the SPI at replacing?
                  • shahnld
                    • Nov 2019
                    • 164
                    • Netherlands
                    #49
                    yes. pin 1 is at place on all 5 chips i replaced. the Soc are missing because i wanted to make sure if the short stays or not after removing the Soc's from old tcon. and yes. before there was 20ohms and after desoldering them it went to kilo ohms. and new tcon has a much higher reading. that was the only reason i removed them from old board
                    • lotas
                      • Jan 2016
                      • 4803
                      • Russia
                      #50
                      After replacing the eeprom, did your error "5" disappear? Or also in emergency update mode?
                      • Diah
                        • Feb 2013
                        • 6497
                        if yours work as you said correct... you need to disconnect the MB from PSU... and disconnect the 2 LVDS from T-CON side.... run the PSU to power on in stand alone mode... check yours screen if it show pattern... in case BL didnt come on.... use flash light to explorer the screen.... one things important the T-CON must have 12V on it fuse from both side... as yours t-con 12V come direct from PSU so we need to do this stand alone test
                        • shahnld
                          • Nov 2019
                          • 164
                          • Netherlands
                          #52
                          will there be something on screen while the green yellow light is blinking..?
                          • Diah
                            • Feb 2013
                            • 6497
                            there will be no green or red or any things.on indicator LED... because MB will be out from the system.... only PSU and T-con and screen
                            • shahnld
                              • Nov 2019
                              • 164
                              • Netherlands
                              #54
                              ok.. let me arrange something to start the psu.
                              • Diah
                                • Feb 2013
                                • 6497
                                yours standby 3.3V more or less go to DRV-on- Power On_ BL on.... etc... check the print charter on PSU boards
                                • lotas
                                  • Jan 2016
                                  • 4803
                                  • Russia
                                  #56
                                  Usually, SONY will not display anything; when turned on, self-diagnosis occurs and if it detects someone else’s T-con or panel (Sony has hardware linked by ID), then it enters emergency update mode.
                                  • shahnld
                                    • Nov 2019
                                    • 164
                                    • Netherlands
                                    #57
                                    Ok. thats nice. So now it has its own tcon in a way.. so is there a way to resolve the issue.
                                    • shahnld
                                      • Nov 2019
                                      • 164
                                      • Netherlands
                                      #58
                                      which 2 pins to short to run the psu stand alone..?
                                      • Diah
                                        • Feb 2013
                                        • 6497
                                        from his first post the issue was easy to handle. by hard reset the android system... plug out from wall joystick push and moved down... keep it in position then plug tv in wall.. remove the push finger only when indicator change from white to solid green
                                        • Diah
                                          • Feb 2013
                                          • 6497
                                          on the psu boards u have print chart... show me it clearly
                                          • YasaCh
                                            Sony kdl 40p5500 red light keeps blinking 3 times
                                            by YasaCh
                                            Hello...
                                            my tv almost 2 years not powerd on and when i turned it on nothing happened and only 3 red light keeps blinking
                                            i opened the back cover no sign of damage on the powery suply or motherboard
                                            when i plug in the power i hear the reley sound like tik first and another tik..after that only red keep blinking..
                                            another thing is even after i unplugged the power, The tv keeps red blinking 3 times for 2 almost 2 munites
                                            07-07-2025, 11:53 AM
                                          • huzo
                                            HP 470 G5 blinking amber light no power
                                            by huzo
                                            The board is daox8cmb6eo and i can't find no boardview or schematics on the forum or anywhere...
                                            So i plug in the charger, amber light starts blinking ,there is 3.3V and 5V present, and 2.4V on the power button,board doesn't turn on, no shorts...
                                            I've tried flashing the bios...
                                            interesting thing is the battery was around 7,8V, and it's 11.1V battery, the mosfet near the battery is open, but not charging,i desoldered it,tested it and it's fine ,but the amber light kept going on the charger so i charged the battery with power supply and got it to about 10.5V...
                                            06-08-2023, 04:08 PM
                                          • jxrepman
                                            Asus X453MA won't turn on and green led light blinking
                                            by jxrepman
                                            Hi there,
                                            I have this ASUS X453MA Laptop that's not turning on. When I plug in the charger, the green light just keeps on blinking and pressing the power button does nothing.
                                            I have checked the charger and it is giving 19+ V
                                            I have disconnected the battery and pressed power button for 30 seconds.
                                            I tried another RAM stick.
                                            Tried disconnecting the keyboard and touchpad.
                                            Tried disconnecting the HDD and the wifi adapter.
                                            The problem persists.
                                            Hope you could help me out on this one. Thank you.
                                            12-14-2024, 06:40 AM
                                          • CSM123
                                            Sony KDL-55HX850 - Blinking 3x
                                            by CSM123
                                            Have KDL-55HX850 that seems to have been hit by power surge.
                                            Blinking red 3x - clicks on/off on the power supply board when power is held in.
                                            Replaced Power Supply G board - same response.
                                            Replaced main BAP - no response at all. Seems worse, maybe bad board.
                                            Replaced main BAP with a 2nd board - back to blinking 3x similar to original.
                                            Checked speaker impedances ok 8ohms each.
                                            Where are JL6002, JL6005 test points?
                                            Ideas for what next to troubleshoot?
                                            Could it be T-Conn or LED board? Seems that the troubleshooting...
                                            02-06-2024, 11:50 AM
                                          • YasaCh
                                            sony kd-49xf9005 4 red blinking problem
                                            by YasaCh
                                            Sony KD-49XF9005 it power up to android boot screen and turns off immediately with continuously 4 red blinks ...
                                            05-05-2025, 08:40 AM
