Sony KDL-55HX850 - Blinking 3x
  • CSM123
    Have KDL-55HX850 that seems to have been hit by power surge.
    Blinking red 3x - clicks on/off on the power supply board when power is held in.
    Replaced Power Supply G board - same response.
    Replaced main BAP - no response at all. Seems worse, maybe bad board.
    Replaced main BAP with a 2nd board - back to blinking 3x similar to original.
    Checked speaker impedances ok 8ohms each.
    Where are JL6002, JL6005 test points?
    Ideas for what next to troubleshoot?
    Could it be T-Conn or LED board? Seems that the troubleshooting
    guide is focused on G or BAP for this 3x blinking.
Name:	Screenshot 2024-02-06 at 12.46.15 PM.png
  • Davi.p
    Hobbist Tech
    • Sep 2009
    • 4399
    • Italy - Milan
    Disconnect the tcon or frc or other boards and check again
    • m1ch43lzm
      by m1ch43lzm
      05-12-2025, 08:37 PM
    • jb_Bak
      by jb_Bak
      CN6401
      Pin 01 NC
      Pin 02 NC
      Pin 03 "BL_ON": 0V
      Pin 04 "N/C"
      Pin 05 "STBY 3.3V": 3.5V
      Pin 06 "GND": N/C
      Pin 07 "AC_OFF"...
      09-27-2021, 04:52 PM
    • delpiero3
      Sony Vaio SVS MBX-261 board failure
      by delpiero3
      Hi everyone, newcomer in this forum, i watched tons of video from Sorin, i like the way i calmly explain things, i did quite some console repair, i am not that bad at micro-soldering, but troubleshooting where the issue is, is definitely where i still have progress to make. Usually i was able to fix the console because the failure was obvious, or because i was able to find someone with similar measures on the board and was pinpointing what to replace that way.
      Nevertheless, let's say, i don't come as a total beginner.
      I have this old laptop, which suit perfectly my needs, with the...
      10-29-2024, 06:16 AM
    • huj3r
      Sony KDL-40Z4500 LCD with stripes and 9 blinks (possible BGC board or harness problem
      by huj3r
      Hi there!
      I have a Sony Bravia KDL-40Z4500 which shows a colored vertical stripes pattern when turning on, with a central black shadow that slowly dissipates within the first 10 seconds.
      Photo of the situation after the black shadow dissipates:
      After this behavior the red LED will blink 9 times, then pause for a bit, and blink again 9 times, in a loop.
      I checked the manual (available here) and this corresponds to "HFR error", quoting from the manual:
      > This indicates HFR Communication error. [ HFR Communication...
      08-15-2023, 10:55 AM
    • Tynan Dill
      by Tynan Dill
      Assuming...
      11-22-2024, 01:46 PM
