And another question, are you absolutely, 100% sure that you purchased a serviceable, working T-CON, the fact is that the update may not take place if this t-con is not working properly and also carefully inspect the contact tabs on the LVDS cables , after experiments they could move, bend, break off.
Sony kdl 65xg9505 green amber blinking
I bought it online from spain and they said pulled out working from a broken tv. Further i have no choice but to trust thier faith.
When the usb is being accessed and then after 30 minuts green yellow is infinit then i switched tv out and pull out the usb.. There there are additional files being created like andoid, camera, pictures misic etc.
Someone replyed to my coment on youtube who make youtube videos on sony tv's, "Nicks TV repair" that this is a new tv and it does not need a pairingš¤
Anyways.. firmware on that archiv is wel an old version but still in .zip. So i think there maybe no .pkg for this tv. so what and how then to be done..Last edited by shahnld; 01-05-2024, 04:38 PM.Comment
In this regard, it will be very difficult here, first of all you need an expensive, good programmer to work with eMMC partitions, and that wonāt help. The firmware is an encrypted partition and only its native processor has the key to decryption (they have an ID binding between the eMMC and the processor) and if you install another eMMC with good firmware, then half of its applications (netflix and others...) will no longer work.Comment
Hi.
i have opened the edge and it has 2 buffer boards. 1 for eacg side. there are 1 winbond on a side and one on the left.
further there are numbers and stickers with long numbers.. so.. i dont know what info i am looking for and what to do with it.Comment
there are wrong call to say Panel ID saved on Panel boards.. there are only buffer to handle display read write and it parameter. this parameter are saved on main firmware GPU section as Panel ID show at service menu...
Sony or any other firmware not that stupid one to make your panel stay blank ( Black) if there issue at T-CON or MB or LCD self... there for there are diagnostic option on any of Sony system / android or Native Linux. so Engineer can handle the parameter when some parts changed..
replacing / working at Sony TV and LG .. worker need to have GND arm band . however this written at any brands service menu.. thought the issue and damage happened in winter more than summer time... just because there are no static cloth in summer normal people wearing.. any one in hurry or not this action in attention took... the price will be very expensive and could also to have no end. ... this not only for this Topic. let see how it happy end.Last edited by Diah; 01-07-2024, 05:56 PM.Comment
Wel you are correct but as i have mentioend before that i am no expert just basic knowledge in tv's and a very good working hand in soldering. So this panel ID, Firmware etc things are new to me..
Today i talked to someone who sold me Tcon for my sharp aquos 5 years back and at that time he was repairing tv's and he said i do no more repairs but he works for Mediamarkt as a field engineer still doing repairs but not like before at home..
I just sent him a message and described the issue.. He told me that Sony tv can create complex issues when something is changed in hardware.. He suggested use different usb sticks and maybe you will get lucky..
He also said that its a pure firmware issue mainboard lacking communication with tcon thus display and in order to restore that you need to flash/refresh the firmware.
[Off topic] Why don't more people put a picture/avatar in their user profile, so it's easy to tell who the posting is from, it's VERY easy.Comment
by YasaChHello...
my tv almost 2 years not powerd on and when i turned it on nothing happened and only 3 red light keeps blinking
i opened the back cover no sign of damage on the powery suply or motherboard
when i plug in the power i hear the reley sound like tik first and another tik..after that only red keep blinking..
another thing is even after i unplugged the power, The tv keeps red blinking 3 times for 2 almost 2 munites2 Photos -
by huzoThe board is daox8cmb6eo and i can't find no boardview or schematics on the forum or anywhere...
So i plug in the charger, amber light starts blinking ,there is 3.3V and 5V present, and 2.4V on the power button,board doesn't turn on, no shorts...
I've tried flashing the bios...
interesting thing is the battery was around 7,8V, and it's 11.1V battery, the mosfet near the battery is open, but not charging,i desoldered it,tested it and it's fine ,but the amber light kept going on the charger so i charged the battery with power supply and got it to about 10.5V... -
by jxrepmanHi there,
I have this ASUS X453MA Laptop that's not turning on. When I plug in the charger, the green light just keeps on blinking and pressing the power button does nothing.
I have checked the charger and it is giving 19+ V
I have disconnected the battery and pressed power button for 30 seconds.
I tried another RAM stick.
Tried disconnecting the keyboard and touchpad.
Tried disconnecting the HDD and the wifi adapter.
The problem persists.
Hope you could help me out on this one. Thank you.12-14-2024, 06:40 AM -
by CSM123Have KDL-55HX850 that seems to have been hit by power surge.
Blinking red 3x - clicks on/off on the power supply board when power is held in.
Replaced Power Supply G board - same response.
Replaced main BAP - no response at all. Seems worse, maybe bad board.
Replaced main BAP with a 2nd board - back to blinking 3x similar to original.
Checked speaker impedances ok 8ohms each.
Where are JL6002, JL6005 test points?
Ideas for what next to troubleshoot?
Could it be T-Conn or LED board? Seems that the troubleshooting... -
by YasaChSony KD-49XF9005 it power up to android boot screen and turns off immediately with continuously 4 red blinks ...
- Loading...
