Factory Resets Listing
This is a sticky topic.
  • randtek
    • Oct 2011
    • 280
    • US
    • Astronomy, Computers
    Over time, I have created a listing of manufacturers and their factory reset/factory mode procedures that may help others. This list is from my own experience, and is by no means complete for any given manufacturer. Some have been found by searching the internet, some by trial and error. I hope some may find this information useful
    **** WARNING!!!! ******
    Some of these procedures may allow you to enter factory service modes. IF YOU DO NOT KNOW WHAT YOU ARE DOING, DO NOT MAKE CHANGES TO SETTINGS IN FACTORY MODES!! Improper settings may cause undesired operation, and could result in a situation where your TV cannot boot/turn on.
    YOU ARE USING THESE PROCEDURES AT YOUR OWN RISK!!
    Factory Resets / modes
    For all listed procedures, start with TV on, in TV mode, unless otherwise instructed. After procedure is complete, unplug set and re-plug in to finish reset.
    If more than one procedure is listed for a given manufacturer, try the different ones until you see which one works for your set.
    Coby:****************************************-
    Enter menu, hi-lite “audio” then enter 8893
    mode/source 2580 select “other setting”,select “shipment” then yes, after it exits service menu you need to power set off.
    Dynex ****************************************-
    source/input 2580
    hold vol down on tv and hold #1 button on remote, vol will jump to halfway and set shuts off. Turn back on have 1st time setup screen.
    source/input 2580
    menu 1999 (tv is on)
    Element ****************************************
    menu 0000
    menu 1147
    Haier ******************************************
    pull up menu, hi-lite “audio” then enter 8893
    Hisense *****************************************
    In customer menu go to”Parental” enter 0000 then select”Clean All” then power the set off and back on and first time setup menu will be there.
    For some models, same as above model except in menu it is labeled “Lock”
    Insignia *****************************************-
    input 2580 (tv is on)
    Mitsubishi ****************************************
    Menu 123 or menu 2470 (tv is on)
    Panasonic
    Hold vol- on TV, press and hold menu button on remote
    Philips ******************************************
    Push menu, select”Features”then select”current software info” push 062596-info on remote then push info again then red”initialize appears and changes color then complete. Push power button to exit
    TV is on,push 062596-info on remote,then push info again, red”initialized”appears it turns green when completed, then push power button to exit
    Polariod *****************************************-
    Hold vol- and chan- or hold vol+ and chan+ (tv is on)
    Proscan ******************************************
    In customer menu go to setup,select parental control menu, enter 0000 then select “clear channel list”.
    RCA *******************************************-
    Menu 1147
    Sanyo *******************************************
    hold vol down on TV, press and hold #1 button on remote, vol will jump to halfway and set shuts off. Turn back on have 1st time setup screen.
    Samsung *****************************************-
    Mute 182 power (tv is off)
    (On some models, Factory Reset is on this menu, on some, you must go into the “Options” submenu
    Seiki ********************************************-
    Menu 0000
    Sharp ********************************************
    (Note – On Sharp models, you will need to look through the menus to find the reset option)
    menu 1999
    menu, 3481
    menu 1147
    while holding vol– & input buttons on tv plug in set when “k” appears push vol– & chan-
    Sony *********************************************
    Hold “arrow up” on remote and push power button on tv (tv is on)
    Symphony *****************************************-
    Source/input 2580
    Toshiba ******************************************-
    on Menu, select “Installation”, then “System Information” press the right arrow button, (“System Information” will change to “Factory Reset” or something similar) follow on-screen instructions
    Vision Quest ***************************************-
    Source/input 2580
    Vizio ********************************************
    In customer menu under “Help” tab is Factory Default enter 0000
  • selldoor
    Slow Learner
    • Dec 2010
    • 7870
    • Repair
    Re: Factory Resets Listing
    Great I think it should be a FAQ sticky
    If you have found our forum useful please consider supporting us. Subscribe for a small monthly fee and receive extra benefits including our bios, boardview & schematic archive.
    Subscribe to support us. It only takes 1 minute:
    https://www.badcaps.net/settings/subscriptions
      Back Again?
      • 32836
      Some of mine:
      Vestel (most):
      Menu 4725 then select "RESET"
      Samsung (European):
      Power off, Info - Menu - Mute - Power, then find factory reset and execute option.
      LG/Zenith:
      Hold MENU on TV and MENU on remote for 5~10 seconds, then select reset option.
      NEC:
      While powering on hold "MENU" or "INPUT" on TV, depending on model. (Only disables error lock out/buffer and puts TV in temporary service mode.)
      To reset to factory, on remote, Off Timer - Menu - Exit - Off Timer, then select reset option.
      I vote for sticky!
      For service manual, bios, schematic, boardview (board view), datasheet, cad - use our search.
      Subscribe to support us. It only takes 1 minute: https://www.badcaps.net/settings/subscriptions
      • tibimakai
        • Jan 2012
        • 3681
        • TV repair, audio repair, carpc, VW beetle
        Great info, thank you all. STICKY
          This should be STICKY. Great info.
          Subscribe to support us and access our Bios, Boardview, schematic search. It only takes 1 minute:
            From drpj23:https://www.badcaps.net/forum/showth...483#post296483 post 5
            A little googling to the service mode
            Vizio Service Menu Method 1
            1. Turn The TV off.
            2. Press and hold the {CH +} & {CH -} buttons on the TV.
            3. Then press and release the {POWER} button on the TV.
            4. Release the {CH +} & {CH -} buttons.
            5. Now press the {MENU} button on the remote.
            6. You should get your regular menu up, but with a "F" in the bottom right corner of the menu (This is for factory).
            7. Press and hold the {MENU} button for few seconds.
            8. The Service Menu will be displayed.
            Vizio Service Menu Method 2
            1. Turn The TV off.
            3. Then press and hold the {POWER} button on the TV.
            4. Keep all three buttons pressed for few seconds.
            Vizio Service Menu Method 3
            1. Press and hold the {EXIT} button on the remote for 3 seconds then release it.
            2. Then press the {1} {2} {3} buttons on the remote.
            3. To exit, press the {EXIT} button.
            GV42L FHDTV10A / JV50 / SV42 / SV320XVT / SV370XVT / SV420M / SV470M / SV420XVT1A / SV470XVT1A /
            VECO320L1A / VO22L / VO32 / VO37 / VO47L / VOJ320 / VOJ370 / VP322 / VP42 HDTV20A / VP422 / VS420LF1A /
            VU42 / VW32 / VW37 / VW42 / VX20 / VX32 / VX37 HDTV10A /VX42
            Push "Menu" on remote and then push "Vol-" and "Input" on keypad
            GV46 / P50HDM / P50HDTV10A
            Press "Ch-" and "Ch+" buttons together once on keypad
            GV42 / L42 / VP42HDTV10A / VP50 / VX37
            Press and release "Menu" on keypad. Hold "Ch-" and "Ch+" buttons on keypad, then hold "Menu" on remote.
            P42
            Hold "Ch+" and "Ch-" along with "Power" on keypad. OSD will show "F" on right bottom portion of OSD.
            VM60P
            Press "Info" on remote, then press "Right Arrow," "Down Arrow," "Left Arrow," "Up Arrow," "Right Arrow."
            The TV will show "Enter Factory Mode." Press "Menu" after message disappears and go do to "Setup."
            GV47
            Press "Menu" then press the following combination: "Info," "8," "2," "0," "6."
            SV420M / SV470M / VF550M / VF550XVT1A / VF551XVT / VL260M / VL320M / VL420M / VL470M / VO320E /
            VO320EP8 / VO370M / VO420E / VP504 / VP505
            Press "Menu," and then press "2," "4," "8," "9."
            VA19 / VA22LF / VA220E / VA26
            Press "Menu" and then press the following combination: "0," "6," "2," "5," "9," "6"
            VA320E / VA320M / VA370M / VT420M / VT470M
            Press "Menu" and then press the following combination: "1," "9," "9," "1"
            VW22 / VS370E
            Press "Mute" once OR "-" twice (the dash next to the "0") and then press the following combination: "9," "8," "7," "6"
            • kevinm34232
              • May 2012
              • 1887
              Hi for everyone's info, can you tell us what a factory reset will do and what potential problems it will fix?
                Back Again?
                • 32836
                Just resets all configurations to as they were from the factory. Can fix some picture/sound/interface problems.
                • nathaniel
                  • 35
                  • israel
                  hello everyone
                  new in this forum
                  i would like to add PANASONIC lcd and plasma TV's service menu (factory reset is done via menu)
                  press and hold volume down (on tv panel)
                  while still holding vol- press i (info botton) on remote three times
                  service menu starts up - scrolling pages is done by color botton (green if not mistaking
                  *usefull for people who know what they are doing (not me at the moment)
                  -i found it usfull only for white wash for plasma TV's (just scroll throuh the menu untill you see the white wash apears
                  exit the menu by turning off the TV
                  • CiGiK
                    • Jan 2012
                    You guys have some strange named sets in the Northern latitudes!
                    Here in South Africa - and I guess most of the Southern Hemisphere - we are reluctantly getting used to a myriad of Chinese sets with Anglic-sounding names like 'Ultravision' and Germanic ones like 'Bauer'.
                    Inside they are mostly Chinese generic boards and most respond to the following for factory mode:
                    Hold down volume minus (Volume down) on set and press 'recall' on remote.
                    'Recall' is the button that activates the channel number and clock onscreen.
                    After you have made your changes, in most cases, pressing 'power' on the remote will clear the factory mode.
                    On some models pressing the 'AV' button will revert things to normal operation.
                    In rare cases, the sequence first described above - (Vol - on set and recall on remote) will have to be repeated at least once more.
                    If none of the above methods works, try using a universal remote - best one that has a LOT of in-built models..!
                    Search through the available models looking for any that suddenly causes the set to change channels.
                    Lock this setting into the remote and press '2'.
                    Factory mode should appear.
                    BE WARNED that NONE of the remote's buttons will function normally!
                    Use the front panel buttons to scroll through available menus and make any changes. Power off set to revert to normal functioning.
                    Hope this is of help!
                    Colin Knight, Cape Town
                      Back Again?
                      • 32836
                      Lamp Error Reset for Sharp LCD TV.
                      With power LED off (TV in fake standby or AC power plug removed) hold Vol- and SOURCE/INPUT.
                      Power on the TV. Do not release the buttons.
                      This may take up to 20 seconds.
                      Look for a letter "K" on the side of the screen when it powers up. If this appears, continue. If not, repeat the above procedure.
                      Press CH- and VOL- to access service menu. See if LAMP ERROR appears in listing. If so, then a reset procedure is necessary
                      Page through the menus looking for "L ERR RESET". Execute the option (highlight and press OK.)
                      Power off the TV (TV in fake standby or AC power plug removed)
                      Hold Vol- and SOURCE/INPUT.
                      No "K" should appear.
                      Power off the TV.
                      The TV should now be fixed.
                      • 3guk
                        • Feb 2011
                        • 5
                        Hey Guys,
                        http://www.factory-reset.com - I've been collecting these and adding to this database for around 2 years now !
                        If anyone wants posting privileges then just give me a shout, had to turn them off due to an influx of spam a few months back !
                        James
                        https://factory-reset.com - Factory Reset / Service Menu guides.
                        • klkmalik
                          seeking Tips
                          • Nov 2011
                          • 68
                          • UAE
                          • repairing electronic.hobby project
                          Thanks for Badcaps Members for posting information about Factory Reset code. But I have SAMTRON 56v monitor showing CONTROL LOCKED problem ,Also screen disply small size, I tested voltage , components was ok. can someone help me REset
                          code or method ? Thanks for help.
                          • Joelito Maderazo
                            • Apr 2013
                            • Philipines
                            Guys!!! Is there any one who knows service mode for Changhong LCD TV
                            I tried this(mute on remote & menu on TVset)but not working..
                            I tried to adjust the gamma setting since the possible problem of this unit was T-Con.tnx.
                            • Ryu74alpha
                              • Jun 2012
                              • 5
                              • Kuwait
                              Hisense TV.....
                              goto menu, sound, balance set to "0" then press 1969
                              be carefull....
                              • santoshpradhan
                                mobile and tv
                                • May 2013
                                • india
                                reset code for lg pleasse
                                sir i had lg tv ra21fa26v with power on problem with long beeps please suggest solution
                                • notallbad
                                  • Oct 2012
                                  • 1206
                                  • Save the techie from asking silly questions giving them more time to solve isuues
                                  It is my understanding that it is impossible to enter the service menu from the stock remote on any LG TV!
                                  But you really need to provide the model number.
                                  • Clydeuk
                                    • Jan 2012
                                    • 193
                                    I've successfully "emulated" the LG service remote codes using some stuff you can download online, it's not ideal but it will get you in there. Google it and you may find it, they basically upload .wav files which when played through an IR LED (from headphone jack of whatever is playing it) issue that command to the TV. As I said it's not ideal, lots of variables (LED, volume level and so on) some just hook an LED to the headphone jack, others build a simple circuit to drive the LED (more reliable), what I did was use an old working remote control with batteries fitted and attached the wav signal to the base of the transistor that drives the LED (s). It did the job, it's ugly, awkward, but I don't need it much.
                                    • Clydeuk
                                      • Jan 2012
                                      • 193
                                      I will ask on this thread as well if anyone knows any other Vestel codes other than Menu 4725, 7935 and 1325?
                                      I have a feeling the options I need to change may not have a solution that can be done via remote control (recent chassis) most options in regular 4725 menu are read only. If there's no menu option I'm going to have to investigate attaching something to the GPIO to see if I can trace and find the info I want; this is a big learning curve but may be worth it.
                                      • ttt9090
                                        • Apr 2013
                                        • 16
                                        • canada
                                        This may be a dumb question, but I don't how how else to ask it so...
                                        Is it imperative to have a factory remote to apply a factory reset? or...
                                        Is there a way to accomplish the same thing by opening the set and moving jumpers etc.?
                                        • Boardview and Schematic Bot
                                          LCD LED TV Service Menu Codes
                                          TCL LED TV Service Menu Code
                                          LG LED TV Service Menu Code
                                          10-31-2024, 03:58 AM
                                        • RRice25541
                                          Sharp Lc-50UB30U may be locked out of Service Mode and Factory Mode
                                          by RRice25541
                                          So i got this tv from my neighbor, when it wasn't working right for him,, he purchased another tv and gave his old to me.
                                          the color is all outa wack, like the settings have been corupted,
                                          I've already done a firmware search using the wifi connection update from the tv and it didn't find any new update so it's got the most recent version.
                                          so
                                          The issue is i can't get into service mode or factory mode, tried resetiing it from user mode and it didn't change anything.
                                          when i bring up the menu and type the pass codes to access either mode the menu disappears...
                                          05-13-2022, 10:44 PM
                                        • howardc64
                                          M557-G0 no WiFi/Bt no WIFIVendor file?
                                          by howardc64
                                          Thanks to Diah, got M557-G0 LCD panel buffer board repaired and running ( link ) Next challenge is no WiFi/Bt despite module on the main board and getting 3.3v supply (3.45v measured)
                                          • TV Menu shows Network Access Point option (enet unplugged) but menu can't select that entry
                                          • Service Menu shows many Bt/Wifi info missing
                                          • Vizio app shows no WIFIVendor file
                                          Prior owner used enet and said turned off wifi somehow. It seems system config info for wifi might be missing. Anyone experienced this before?
                                          • Tried countless enet unplug (user manual said need to unplug enet to get to wifi menu), factory
                                          10-15-2024, 01:12 PM
                                        • dxz
                                          lenovo thinkpad e480 problem
                                          by dxz
                                          howdy yall,
                                          back in this last december i lost my svp for my thinkpad, then i found this technique and it worked successfully.
                                          the only thing i found weird was that now in the bios menu, specifically under the secure boot configuration in the security tab, it went from mentioning microsoft windows 10 to now showing microsoft windows 8 when i scroll over the restore factory keys option.
                                          and im wondering if my current problem is due to the flash/patch ive done:
                                          im having a hard time activating windows 10 pro :lenovo thinkpad e480 that i purchased...
                                          06-16-2023, 04:10 PM
                                        • Retro140
                                          Unnlock Menu for 2007 DU-27FB32C comerrcial CRT TV
                                          by Retro140
                                          So I was referred here when I made this poste over on AVForums: https://www.avsforum.com/threads/loc...lg-tv.3257234/
                                          To summarize, this is a commercial TV and I can't get a menu of any kind. I know the overlay is working because when I change channel, adjust volume, turn on sleep timer I do see text. But I have not ever seen the user menu nor the installers menu. I've tried a bunch of remotes(more info on the AVF post) and tried every button...
                                          06-18-2023, 06:13 PM
